Best Touch-Up Paint?
Quoted: 325 Post(s)
Liked 109 Times
I am in the process of over-hauling my touring bike, and after years of all-weather riding, a few falls, and the other usual abuses, there are some minor chips in the paint. I don't want to let the steel frame rust too much, so I'd like to bust the rust and then paint over the bare areas with some touch-up paint.
I'm not going to strip down the frame and rattle-can it or do anything else that silly to this bike. I am just looking for touch-up paint that will work well on a steel bike frame. I'm not even concerned about the color, I just want something that is easy to apply and will be durable. Any good product recommendations?
Quoted: 1438 Post(s)
Liked 1,092 Times
Fingernail polish. It comes in many different colors and has a handy applicator. Most stores will not object to you bringing your bike in to check the color match, although you should verify under sunlight as artificial light can be deceiving.
Quoted: 6178 Post(s)
Liked 4,796 Times
Auto parts stores have touch up paint in all sorts of colors. I've seen some other's talk about using nail polish as it comes in every imaginable color. Not sure about the UV resistance of it, but might not matter much if you don't leave your bike in the sun every day of the month.
If you aren't really worried much about looks, just deal with the rust, prime it with a zinc or red oxide primer and be done.
Quoted: 325 Post(s)
Liked 109 Times
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Auto touch up paint should work great. You should be able to find something pretty close and you can get those things that look like a big pen that have the paint and a clear coat in one container.
Quoted: 567 Post(s)
Liked 563 Times
^ THIS ^ and when I have tried it due to a perfect "teal" color and thinned and laid it on in many coats to get it smooth it faded in a couple years and needed to be completely redone.
Go to your local flea market, find the guy that is selling cosmetics, look in his fingernail polish rack. You'll find a color you like for a few bucks. It can also be used to paint accents on your bike.
Quoted: 3352 Post(s)
Liked 1,056 Times
If you only have a scratch or a small chip, the best place to go is a hobby store that sell small bottles of paint for model cars and planes. Very inexpensive.
Liked 4,796 Times
Well I didn't mean to imply that nail polish wasn't a good touch up paint. Just mentioning that I didn't know how UV resistant it was. Model paints might be good too as another just posted.
I'm sure all are different, but some nail polishes my wife uses seem to have many of the same easy and forgiving characteristics that old fashioned nitro-cellulose paints from way back when used to have. And if you top coat with a clear automotive or other clear for outdoor use, maybe just as good as anything else.
Re nail polish. About 25+ years ago I had some little dings and paint rubbed off a few places of my touring bike, put some clear nail polish on them and it's still doing fine, no rust ever appeared.
Sure, the bike doesn't sit outside, but the stuff has held up fine.
I still have the little bottle in one my parts and bike stuff boxes.
Quoted: 5888 Post(s)
Liked 3,471 Times
I just dealt with paint issues on a 1992 Specialized Stumpjumper I'm rebuilding. The frame is sound but it was roughly handled and missing paint in a lot of areas. I got rid of the rust, painted over the bare patches with flat white rustoleum, and then found a model paint that was close enough. The bike doesn't look bad.
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
Liked 3,471 Times
I may try to mix that model paint eventually to try to find a better match but there is no way this will ever look "right" given how much paint the bike lost.
Likes For bikemig:
Quoted: 836 Post(s)
Liked 1,059 Times
Yeah, don't waste your time trying to make it look any better. Nearly impossible for even the pro painters to make it perfect. You accomplished your goal of preventing rust so just ride it and enjoy. Consider the dings badges of honor as an experienced tourer.
Likes For Crankycrank:
Liked 3,471 Times
Oh yeah. I like to think this is just the right look for a gravel/mtb drop bar bike.
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
I always think of the old Testor's brand paints, though they don't get mention much. They seemingly also make enamel paint pens, which strikes me as probably about the easiest thing one could use for small touch up areas.
