Connecting Axa Slim Steady rear light
Fed up with battery changes, I bought a dynamo wheel (Amazon) that came with LED lights. Front light connected no problem; rear light, no idea. The blurb says: “The practical push connections makes the Slim Steady easy to connect to both side running and hub dynamo’s.” But to my untrained first time eye, it is not practical. I assume cables need to be exposed at the ends (maybe) but after that, no idea. AXA manufacturer customer service is no use. First post here so unable to attach a picture. Any hints or solutions?
Quoted: 3459 Post(s)
Liked 1,465 Times
Without seeing it or seeing a link to it I will just make the generic comment that dyno powered taillights are almost always wired to the headlight. So, look to see if there is a place on the headlight to connect your taillight wires.
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
https://www.axasecurity.com/bike-sec...im-steady-80mm
It's not entirely clear from the 360 degree animation what the connectors are. Was there nothing in the package it came with?
Regardless there is a + and a - so make sure you get the polarity correct.
Maybe the nice lady doesn't speak english?
Reply
@ Tourist in MSN. Thanks. The connection from the headlight is fine, nice and easy. Unfortunately the wires are not currently in the rear light. Maybe a job for LBS.
Reply
@ znomit. No docs with the light. I will go back through Amazon 🤭 and see what can be achieved.🤞LBS might be best.
I think you are right. Light was made in France for a Dutch company with customer service in Poland sold through German Amazon to an English man.
Quoted: 551 Post(s)
Liked 722 Times
Strip the ends, push down the connector and poke in.
