12 spd upgrade
Quoted: 257 Post(s)
Liked 70 Times
12 spd upgrade
Has anyone upgraded to 12 and have some feedback? Thinking of this just because and why not. I was a late adopter to 11spd but I'm bored...
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
I’m pretty happy with 1x11 on my budget trail bike. I don’t think I’ll upgrade the drivetrain on the bike I’ve got. I’d rather shop for a better fork. But when it comes time to get a new bike I’ll take what’s on it.
Genesis 49:16-17
Genesis 49:16-17
I've gone from a 3x10 to a 1x12 with a 10-51 cassette. It works really well, but I miss the range when going down and there's a couple of gears where the step between them is too big for my taste. 11sp, with even less range and/or bigger steps, I'd probably hate it.
Quoted: 257 Post(s)
Liked 70 Times
which cassette did you use? I know when going to 11 spd, lowest gear jumps for a shimano cassette were too great for my liking. So all my 11spd cassettes are either SRAM or Sunrace
Quoted: 257 Post(s)
Liked 70 Times
bike which will get the 12 is a full rigid Carver with a Whiskey carbon fork, do you recommend another? I considered upgrading the full suspension bike but like the current setup with 11speed SRAM at the moment, its got a Pike with a Luftkappe upgrade
I'm using an XT 10-51 cassette. I specially hate the jumps between the lowest sprockets as that's what I use when riding fast on flattish areas and I can't find a comfortable gear. I don't notice the jumps all that much when doeing real climbing or when I'm descending. The 10 to 12 jump is clearly too big and makes me uncomfortable when riding fast in the flats.
When descending, my 30t chainring combined with the 10t sprocket is clearly insufficient over 35kph on rough terrain, or 40kph on smooth terrain where I can pedal faster. It doesn't bother me all that much when riding on the mountains as I rarely go at such a high speed while peddalling, but on the ocassional downhill on a road or smooth trail is a PITA.
I know I could use a bigger chainring, but I want the low-end as I use it. IMHO, it's always better to loose top speed than being unable to climb comfortably. It never ceases to amaze me that with my 10 year old 3x10 setup didn't have to make a tradeoff between climbing gears and top speed. TBH, my old bike had the occasional chain drop, but it was less of an issue than the lack of range on current drivetrains.
Likes For Amt0571:
SRAM has a huge gap at the low end. The gap to the last sprocket makes it feel out of place and is an atrocious design. I specifically bought a bike with Shimano for this single reason.
I would go for a quality fork first, assuming your bike has an entry level fork. If it's an older fork that hasn't been overhauled and rebuilt, get a new fork. It can change the way you ride, not just the rough stuff, but the cornering as well.
Look out for hub compatibility. If you have Shimano 11 speed, the NX cassette can fit since it uses the same hub, but not the GX or above, those require XD hubs. The new 12 speed Shimano won't fit either, those use MicroSpline hubs.
I just upgraded to a 10-52t SRAM 12 speed cassette to go with my 32t chainring, and I couldn't imagine anything lower. 30t and a 51t combo is overkill on the lowend. I couldn't imagine going slower than what I already do, keeping the front end from wandering about is enough of challenge. Going slower will make the wander even worse.
If you don't need that sort of gearing, you don't have climbs steep enough. I prefer to pedal at 5kph if necessary rather than walking carrying a bike.
Advanced Slacker
Quoted: 2761 Post(s)
Liked 2,534 Times
1x11 to 1x12 on an MTB just for the extra gear sounds like a total waste of money to me.
Surely there is better bang for the upgrade buck elsewhere.
Likes For Kapusta:
Yeah I say forget going to 12 speed, go Box Prime 9 instead. You will get more neato comments with that than 12 speed unless that 12 is AXS. 11 and 12 is so common place meh.
But really as it is with 11 and even 10 speed I'm skipping 2 or 3 gears nearly ever time I shift. I'm rarely in 1 gear long enough to worry about perfect cadence unlike my road bike.
We have plenty of steep climbs here. Enough that it necessitates some good technical skill to prevent the bike from wheeling up. But you do need to maintain some sort of speed to prevent front wheel wander. I couldn't imagine the cadence needed with a 30t chainring.
If your front wheel wanders maybe you need to improve your position on the bike. I've had my front wheel wander lots of times, but never on a climb in which I could maintain 80rpm.
Advanced Slacker
Liked 2,534 Times
A 30/51 gear with a 29x2.3 tire like the one that my bike has, rides at 6.5kph at 80rpm. That's a perfectly rideable speed.
Disco Infiltrator
Liked 2,102 Times
Aside: there's a real proliferation of 1x rear drivetrains right now. Box is a few years old now and Microshift has been around too. Sunrace and TRP are both having a go.
Genesis 49:16-17
Genesis 49:16-17
Advanced Slacker
Liked 2,534 Times
It is a total non--issue, IMO. Heck, the jumps could be a lot larger as far as I am concerned. Were this a road bike I might feel differently.
It's not a dealbreaker, but a 20 year old 3x9 didn't have this issues.
Advanced Slacker
Liked 2,534 Times
For me it's mostly a non issue, except when I want to go fast on flat terrain and can't find a comfortable cadence between the 10t and 12t sprocket. Also it's a PITA on the ocassional downhill on paved roads or really smooth doubletrack where it's impossible to pedal at more than 40km/h.
Out of curiosity, what size ring and cassette are you running?
I can see that 1x is not ideal for people needing wider range and tighter spacing.... and every gear that can be added to the cassette makes the switch more doable. For me that could have happened with 9 speed if they had made 11-46 cassettes back in the day. For others, it may take 11, 12, or more to make it work.
Huh. 20 years ago I had already ditched the big ring from my 3x9 mtb setup. Only time I miss anything higher than 32/11 is going downhill on pavement or a smooth gravel road. Otherwise, anytime I am going fast enough to spin out 32/11, it is steep enough that my speed is determined by my braking, not my pedaling. I am sure there have been exceptions to this, but it is not something I would ever make an equipment change over.
To be honest, 1x is perfect 80% of the time, but on flat land and fast downhills it doesn't have enough range or a tight enough spacing for my taste. On flat land I'm capable of spinning out my 30-10. With my old 3x10 I always had one or two cogs to spare when pushing at my max on flat land.
