Ok, so cantilever brakes suck.
Kid A
Liked 5 Times
Tektro oryx - spent 2 hours carefully seating the housing, picking out the ends until the cable slid inside the housing with absolutely no resistance, aligning the pads (new avid v-brake pads) symmetrically on each side...etc.
I've tried tektro oryx, an older set of shimano's, and even a third set I had laying around (no name).
They still suck - my v-brakes went back on in 2 minutes and have more power already....the oryx had "ok" power, but still not like the v-brakes do. You don't even have to align the pads perfectly and they still work better than cantilevers.
I just can't see using these pieces of crap when they pale in comparison to linear pulls.
Oh, and the lack of easy to use barrel adjusters is stupid too. Having to use in-line adjusters, or introducing sharp bends in the housing at frame stops sucks.
Dead technology!
The only reason these things still exist is because their mating with drop bars....that's it. No one would use them otherwise...ok, I'm done.
Dead technology!
yep, I agree. Does anyone know what the best brakes are aside from disc brakes? Are the Avid Digit 5 Linear pull brakes good? I've seen good reviews about them. I've got a rim that's 1 1/4" wide and my cantilever brakes won't work on them because the rim is too wide. I had to take a hack saw and shave off 1/8th inch off each brake pad to get them to work.
Quoted: 19 Post(s)
Liked 7 Times
The best cantis currently available are Tektro cr720. They are much wider design than Oryx and have more powerful braking.
They work well with my Campy Mirage levers.
Compared to the old Diacomp 987 cantis, these are much lighter, simpler, easier to adjust and more powerful.
Gouge Away
I run Cane Creek CSX-5 cantis with Kool Stop pads on my Trek 520 just fine. Took a little time to get them adjusted properly.
Bikes: Specialized Rock Hopper, Felt F-70, lemond Buenos Aires, Trek T900 Tandem, Bianchi Volpe
I am pretty sure that you need different levers to get the correct mechanical leverage when using cantis vs. v-brakes.
I am not surprised that they didn't feel right.
Steve
Steve
Call me The Breeze
Try again on the install. For a beginner it's pretty hard to set up cantis, but once you get some practice it will get easier.
Bikes: 2006 Bianchi 928 Record and 2002 Bianchi Axis 1x9
I have Tektro Oryx canti's and have ZERO problems with them. They stop me as good as my road calipers. I run the Kool-Stop Moutain pads and they were very easy to setup with no squeal and minimal shuddering on my cross bike.
I agree with Stevetone about needing different levers for canti's and vee's. It seems that at least half the time that people jump on a forum to bash something, it turns out to be user error.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
+10 I like cantis, but Vbrake levers are not going to work well on cantis.
Quoted: 12195 Post(s)
Liked 1,497 Times
I like the looks of the IRD canti, and Pauls makes a couple different cantis, including a frog leg design. Still looking, tho.
Bikes: Surly CC, Raleigh Team Pro, Specialized Rockhopper with an xtracycle
Search the forum in the cyclocross section for more details, but the key really is to have the arms parallel with each other when the pads are touching the rims. Once you have the pads aligned properly, then you can work on the traverse length and main cable placement. In fact, I find that I can have the traverse cable any length once the pads placement is correct. This is going to sound obvious, but the key is to get the pads to make contact with with slight movement of the canti as it pivots.
Jet Jockey
Disc brakes.
The option that no one in CX seems to want to hear.
Once you go with, say, an Avid BB7 mechanical setup, you'll never have a desire to go back to cantilevers.
Good night...and good luck
Guppy
Bikes: 2003 KHS Flite 500, c1973 Batavus Tour de l'Europe FW conversion, 2010 C'dale CAAD9 'cross
@gene: steve is right, you need different levers.
@morph: there are a lot of good linear pull brakes out there, I have Shimano Deore XT one one of my bikes and I'm always impressed by the stopping power (especially when compared to road brakes, which are on my main bike).
Kid A
Liked 5 Times
you can replace all the pads you want, but I'd rather have v-brakes with crappy pads than cantilevers with kool stops any day.
And the need for sudden housing bends hasn't even come up yet.
I'm not saying that some other brand might not be better, but v-brakes are just a better technology IMO...and you don't have to spend an extra $30 on pads to "get them to work acceptably".
I'd love to see a test of a set of cantilevers, with the best pads, adjusted with TLC vs. a $15 set of no-name v-brakes with stock pads, assembled by a kid in a test.
Dead technology.
Dog Chaser
Bikes: Trek Emonda, Seven Evergreen, Merlin Cyrene, Trek TCT 5000, Trek Checkpoint
I bought a Kona Jake the Snake last summer. It came with cantis. I use the bike for trail/night riding, plus shorter group rides with a spare set of road wheels. Love the bike but the braking was so poor it was almost dangerous. I replaced the brakes this fall with Deore V brakes and threw on some travel agents for good measure. Stops on a dime, on par with my regular road bike.
According to the articles I've read, the exact opposite is actually true. Wide profile cantilevers have less mechanical advantage than low profiles, but supposedly have better "feel". I'd bet they still require spending $30 on decent pads to get any power out of them though.
In fact, your 720s are LESS powerful than narrower cantis - see https://sheldonbrown.com/cantilever-geometry.html. They do have superior mud clearance, which is this design was/is favoured by cyclocrossers (which often race in seas of churned up, deliberately hose-softened mud) but NEVER (ok, virtually - I'm sure some idiot must have fitted them some time) used on MTBs, which need maximum braking power.
You might have read the Brown article, but you certainly didn't adjusted your brakes properly. For which I don't blame you at all, because SB's article is rather complex. Go to the cross forum and search for old threads there - especially the ones that reference Bontrager's *much* simpler guide to tuning cantis. (Basically: set the pads for minimum clearance and then set the straddle cable as flat as you can - if you want maximum power).
*However* even if you get your cantis into high power mode, you may then suffer from irritating squealing or even fork shudder. You can avoid this by fitting Mini Vees - they're pull compatible with road levers, don't squeal or cause fork judder, and require zero adjustment skill. They're cheap too.
Cantis still exist because they're more versatile - you can tune them to trade clearance for power, which is great for cross. But they're really an advanced tool for specialist riders. Most people would be better served by Mini Vees - I really think they should be fitted to all but high end cross bikes as standard. It's especially irritating when bikes with under-engineered forks and headsets are sold with cantis, so that hard braking throws him into judder mode, lousing up control. (Personally I just wish the idiot UCI would legalize disc brakes for cross racing, than cantis would disappear. But they're too bust defending Lance Armstrong's right to stall drug testers...)
From what I've read, in addition to feel, the other big benefit of wide profiles is supposed to be mud clearance for CX. They allow you to set the pads far away from the rim but still have enough cable pull to cover the distance while retaining good modulation and adequate stopping power. I too have experimented with wide profile brakes and could never get the supposed massive power out of them that everyone raved about..at least not without setting the pads so close to the rim that rubbing was a problem.
Wide profile cantilevers have a cantilever angle much greater than 90 degrees. The best example of this type is the old Mafac cantilevers, in which the anchor arm actually sloped downward from the boss in some installations. This design is now pretty much obsolete. Wide profile cantilevers have rather low mechanical advantage, and work well only with levers with a high mechanical advantage.
Gouge Away
No, man. I thought I made it clear that I used a drop bar (and hence road levers) but I used shimano 105 road levers on the drop bar for the cantilevers. I use linear pull mountain levers on a flat bar for my v-brake. This is not a cable pull issue, it's a cantilevers are weaker than v-brakes issue.
Tried this, believe me. I read all of the Sheldon article about 10 times, and the cool geometry article posted recently with the schematic and everything. I had to remove my fenders to "see" the cantilever arms to make sure they were aligned properly....still suck.
Dead technology.
Dead technology.
Quoted: 140 Post(s)
Liked 163 Times
Kid A
Liked 5 Times
How old you btw?
If installing these things exceeds the ability of so many people, I see this as a disadvantage - not something I need to spend more time working with to master.
My experience is just that these brakes require more technical expertise than probably 98% of cyclists have. I've just given up on them after seeing how a poorly adjusted v-brake can crush the power these things have after an hour of work.
Once again, this doesn't even touch on the idiocy of cantilevers requiring extra bends and threaded stops for barrel adjusters (when using road brake levers). Less power and more crap running along the housing to introduce more problems.
I can't argue with this, since a lot of people seem to like their cantilevers just fine.
I recently converted a sport/touring bike from road calipers to cantis. I am using Avid Shortys. I can't believe how far along cantis have come since I used last had them on a bike 15 years ago.
I am amazed at how much easier the Avid Shortys were to setup. I cannot use linear pull (or V-brake) type because of the road STI lever. For now, these have plenty of stopping power and setup seems fine to me.
Again, one's perception or experience will be a factor. I have used Tektro disc brakes on a MTB bike, which were crap and I replaced them with Avid BB5s. I also have a set of Tektro road calipers on my commuter, not as good as Shimano calipers, but will stop the bike.
