Weinmann 605 Pad Replacement
Bikes: 1973 Schwinn World Voyageur | Francesco Moser SL | 1984 Ross Utopian | St. Etienne 531 | 1981 Peugeot PK10 | 2015 Cannondale SuperSix | 2012 Felt F65X
Quoted: 54 Post(s)
Liked 51 Times
So my new Koolstop pads came for the Weinmann 605 brakes on my PKN10. It is clear they pads want/need to be slid into the 605 cartridge. Of course both ends have a tab bent over and they don't use a screw to lock pads like new models. Before I start jimmying the tabs with a screwdriver and pliers, am I missing the easy way to swap these?
Quoted: 1639 Post(s)
Liked 828 Times
Are the current pads original or replaced long ago? All the pads that I have replaced have had one open end on the holder.
Quoted: 54 Post(s)
Liked 51 Times
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
Depending on whether or not the bent tab still seems strong after bending, I would consider drilling a small hole for a tiny retaining screw, in the manner of modern pad holders.
Having the screw threaded into rubber should act as a retaining elastomer, so the hole for the screw seemingly wouldn't need to be tapped.
