Aerodynamics of Road vs. Cross bikes
Not a gripe, just curious. I've been kicking around the idea of buying another bike. Not just because of 'slowness' issues, moreso its just, well, I like buying bikes.
Anywho...the reason (most recent one anyway...) I've been contemplating it...I ride in group rides on the weekend, using my CX bike (GP4000 tires...I'm not huffing and puffing trying to keep up running knobbies or anything truly stupid...). I'm one of the stronger riders in the group. However, I HAVE noticed that I definitely do not have the same top end speed as a few of the strongest riders. I'm wondering how much of this is due to me just being less fit (eminently possible and extraordinarily likely), but also how much of a handicap I've given myself when out in the wind and moving over 25mph or so (when I really start to feel like I can't hang with these strongest guys).
Obviously this is all going to be conjecture. I'd be curious for some input as to how much of a disadvantage people think I'm at. I've got a cross bike, fairly aggressive position, 28mm gp4000 tires, shallow rims. What kind of difference between that and say, a standard road bike with deep section wheels and aero cockpit?
Quoted: 1186 Post(s)
Liked 289 Times
Fat tires and shallow rims could cost you 10-20 watts, an aero frame might gain 5-10.
Chases Dogs for Sport
I'm going to agree that it's mostly (if not entirely) a matter of riding position. Deep section wheels really aren't all that beneficial -- certainly not beneficial enough to make the kind of difference you're talking about. (The marketeers have interesting ways to make miniscule benefits look significant.) "Aero" bikes and cockpits aren't really of much benefit when compared with body position and clothing and helmets.
On bikes, surface area is a big deal. A slightly more upright position adds DRAMATICALLY to surface area. So does added tire width.
Quoted: 1814 Post(s)
Liked 923 Times
Do you wear a race cut jersey? Tuck elbows in?
Handlebar width makes some difference,
& # of spokes as well as rim depth, so wheels do make a difference,
but even if you gain 3%, there will always be riders who are 20% stronger.
That said, I don't take the cross bike on fast group rides because it's more work & I have little hp to spare.
Perceptual Dullard
Quoted: 918 Post(s)
Liked 1,152 Times
A friend has a cross bike and an older aluminum Cervelo Soloist, and a couple of years ago he did some field tests on them. His "standard hoods" positions were different enough that there was a considerable difference in CdA between the two. IIRC, his CdA on his cross bike was almost .05 m^2 higher than his CdA on his (then old but now ancient) Soloist. There must have also been some difference in Crr but I don't recall what they were. He didn't look at CdA in the drops position.
I'll second what others have said about riding position, but the gearing truly will also make a big difference. It sounds like you're fit enough to reap the benefits of a true road bike. Aerodynamics will be a factor to a lesser degree than (and mostly because of) riding position, gearing and stiffness of a road bike that makes it jump on acceleration and maintain speed more easily than a CX bike. Depending on the geometry of the kind of road bike you're looking at, it will probably also descend more stably = faster.
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
+1 for position and kit, that is the bulk of your aero. But when in doubt, always get another bike, right?
I've seen a couple of the really strong guys bring their cx/gravel bikes out to a fast group ride, it's a bit demoralizing watching them breakaway on 40mm knobbies.
Well for the purposes of discussion...I think we can exclude rider position from (at least this..) the discussion. That's something that is adjustable, and not tied to the particular bike. Cross bikes are roughly a centimeter higher, centimeter shorter at the front. I've had a professional fitting...any road bike I got would have the exact same setup as my cross bike right now in terms of rider position...wouldn't want to go any longer or lower. Not at the moment, anyway.
Also...gearing is not a factor either. I'm in Chicago...it's not like we have descents haha
So really...most things could be fairly standardized...wheels, tires, position, etc. The things specific to a cross bike that would slow the bike down IMO would be the width of the frame...big wide fork, round tubes, but round downtube, wider chain and seat stays...
I've seen some fairly large differences in independent testing of AERO frames...20 watts plus at around 30mph. That sort of leads me to believe an aero frame benefit relative to a totally UNaero cross bike could be upwards of double that. But of course I'm just wildly speculating.
I’d look at power data if I were you. If the pack is cruising along at 25mph (assuming flat terrain) that shouldn’t be too hard, assuming you position yourself properly. Let’s say you’re putting out 225-240 watts, but you know you can hold 275 for 20 min, you should be fine. Usually there will be lulls in the pace when you can recover. OTOH if you’re redlining a new bike isn’t going to save you. I’d look at position on the bike, tires, kit/clothing/helmet, and finally, your frontal area. If you’re round line a huge Krispy Kreme donut, I’d invest on fitness first. But if you just like to buy bikes and have the means to experiment that way, why not? It’ll be the shortest way to answer your own questions. And if it gets you motivated more power to you. Good luck!
Quoted: 18883 Post(s)
Liked 10,646 Times
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
Also cross bikes handle like crap at road speeds. The longer stays and higher bottom bracket places you higher up.
You can ponder it all day or get on a road bike and go faster. There's a reason we have them and there's a reason we have road gearing.
Doubt me? Enter my race. It's at Fox River Grove on May 19. I will comp your entry. I mean it has a hill so your low gears will be an advantage right?
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Quoted: 2952 Post(s)
Liked 3,106 Times
[edit to add photo]
I'm not too concerned about how this affects cruising in the paceline...besides, the proportion that rolling resistance accounts for rises significantly when you're drafting anyway.
Gearing is 100% the factor. I've known plenty of riders around here that do great riding with others but those gears don't pay the bills when it comes to actual speed. They're not supposed to.
Hah, jokes on you! I was planning on coming to that race anyway
See you there
Liked 3,106 Times
Me too. It had such a short head tube that you could get long and low. And damn was it stiff. Awesome crit bike, but I could barely ride it for more than 90 minutes on the roads around here because it would just beat you up.
I eat carbide.
Liked 1,306 Times
Jokes on you - road is dead and no one is racing anymore so you might be the only one.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Maybe see if you can rent a more aggressive road bike for your next outing? Maybe it'll tell you before splurging on your own.
Liked 10,646 Times
This is really awesome. I give you crap sometimes (because we're all passionate about this bike stuff and disagree at times) but I've got to say, you're a stand up guy.
Likes For Seattle Forrest:
I eat carbide.
Liked 1,306 Times
Thanks - I try. It's all there is that's left in this industry. It's all doom and gloom and if I'm going to drive myself into the poor house and destroy my own and my family's future financially I might as well help a few people have fun riding bikes.
Likes For Psimet2001:
Except, I'm going to pay anyway and thwart his attempt at good will. That'll teach to be a spreader of good will
Likes For Abe_Froman:
Quoted: 73 Post(s)
Liked 41 Times
On nice road tires, my cross bike cost a ton more energy to keep up on the fast flat rides
No problems in the hills, even with the extra 2lb convenience fee
Well I don't have any issues keeping up with the group. I'm strong enough to pull (for short stretches...) at 25-27mph when I need to. But not NEARLY as long as the few noticeably faster guys, and I also get outpaced when we're both in the wind sprinting.
Liked 10,646 Times
For what it's worth, the OP basically spent the whole winter on a trainer doing erg mode intervals.
Saying this because it's relevant to the question.
