10-11 speed crank, chain and cassette issues
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,054 Times
I bought a 10-11 speed Cobb crankset, 145 mm length because of mobility issues. Can I pair this crankset with any 7/8/9 speed cassettes and if so, with what chain? If not, whats the cheapest way to get the bike on the road without buying a new wheelset? Current wheel has old 105 freehub with 8 speed cassette. Can a 10 speed cassette fit?
Not worries about the shifters, it will be friction, either downtube or bar-ends. The bike has 130 mm spacing at the back. Thanks.
Quoted: 2026 Post(s)
Liked 1,096 Times
If you use a 7,8 or 9-speed cassette a 10-speed chain will work fine. I had a bike with an 8-speed cassette and a 10-speed cranks and shifting was very satisfactory.
Your 8-speed 105 hub will accept both 9 and 10-speed cassettes so the choice is yours. However, friction shifting of 9 and 10-speed cassettes requires a deft touch since the cogs are so close together so you may find an 8-speed cassette more forgiving.
Phyllo-buster
Liked 2,054 Times
Liked 1,096 Times
A 7-speed freehub isn't wide enough for an 8 or 9-speed cassette either. You will have to change the freehub body to an 8/9/10-speed body or stay with 7-speed.
Quoted: 1109 Post(s)
Liked 1,200 Times
I don't think there's any reason that you can't use your 10/11 speed crank with a 7 speed cassette on your existing hubs. I think you should use a 10 speed chain.
Is that 7 speed hub wheel currently being used in the frame?
Phyllo-buster
Liked 2,054 Times
It is. I guess I can grab a 10 speed chain and try it before a wheel/hub swap.
