Disc brake pad durability
Old 06-10-19, 11:26 AM
MarcusT
MarcusT's Avatar
Quoted: 765 Post(s)
Liked 615 Times in 343 Posts
Just a simple question:
How far do your disc brake pads last?
I am pretty much an uphill/ downhill rider and my pads are getting pretty thin at 200 km.
Who are the longer lasting brake pad producers? Without giving up braking power.
Thanks
MarcusT is offline
Old 06-10-19, 11:27 AM
MarcusT
MarcusT's Avatar
Quoted: 765 Post(s)
Sorry, forgot to mention, Resin pads
MarcusT is offline
Old 06-11-19, 07:43 AM
Leebo
Bikes: Kona Dawg, Surly 1x1, Karate Monkey, Rockhopper, Crosscheck , Burley Runabout,
Quoted: 854 Post(s)
Liked 111 Times in 66 Posts
Use sintered , not resin. Add in rider weight, conditions, mud, dust, and how much you use the brakes for variables.
Leebo is offline
Old 06-11-19, 08:17 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
and, logically, a 4 piston brake has a longer pad , so more friction surface , than a 2 piston caliper ..
fietsbob is offline
Old 06-11-19, 09:30 AM
MarcusT
MarcusT's Avatar
Quoted: 765 Post(s)
I am 230lbs, road conditions are normal off road, not much mud. Just a lot of downhill.
Discs say "Resin Only", so, what will happen if I use sintered?
MarcusT is offline
Old 06-11-19, 09:43 AM
Cyclist0108
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times in 1,164 Posts
It will make more noise, have less modulation, and work better under wet conditions.
I blow through mine pretty quickly, it is of any consolation.
Cyclist0108 is offline
Old 06-11-19, 09:50 AM
HerrKaLeun
Bikes: Giant Toughroad SLR1 and Motobecane Sturgis NX
Quoted: 900 Post(s)
Liked 231 Times in 168 Posts
Sintered pads are more expensive and put more wear on the rotor, even on rotors rated for them. so not a way to save $. Where they shine is fade resistance on long descents, not on saving cost.
Dragging brakes also will wear them more everything else being equal. And other general conditions and riding styles. YMMV.
HerrKaLeun is offline
Likes For HerrKaLeun:
Old 06-11-19, 11:21 AM
Leebo
Quoted: 854 Post(s)
More expensive than replacing resin ones? Not. Never worn out a rotor, ever. 235 lb bikepacker and mt biker.
Leebo is offline
Old 06-11-19, 11:22 AM
Leebo
Quoted: 854 Post(s)
Pics of set up, make and brand of brakes? Rotor size?
Leebo is offline
Old 06-11-19, 11:35 AM
tyrion
tyrion's Avatar
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times in 972 Posts
It will explode.
tyrion is offline
Old 06-11-19, 11:48 AM
fietsbob
Bikes: 8
Discs say "Resin Only" ..
so? fit new disc rotors too..
fietsbob is offline
HerrKaLeun
Quoted: 900 Post(s)
Same manufacturer and quality level, yes metallic pads will cost more. Maybe they last equally longer, don't know. In my case it was between $5 and $25 for same manufacturer and I didn't want to try that out.
For that reason I once tried off brand metallic pads, but they squeal whenever the rotor is wet. Not sure if the $25 brandname wouldn't swueal when wet, but I didn't want to pay to find out.
YMMV.
Old 06-11-19, 05:30 PM
Leebo
Quoted: 854 Post(s)
How will they cost more if the resin ones only last 200K? Would need to replace them more often, yes? Off brand, well there is your answer. Yikes.
Leebo is offline
Old 06-11-19, 05:58 PM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
Liked 70 Times in 63 Posts
Thanks
which brakes and bike? when you say downhill, you mean lift assist right?
qclabrat is offline
Old 06-11-19, 06:03 PM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
I've worn a few down to where the braking felt wavy. Seen this more with older hydros, the new brakes do a much better job spreading the heat. Perhaps that's a reason for the better wear.
qclabrat is offline
Old 06-11-19, 10:12 PM
MarcusT
MarcusT's Avatar
Quoted: 765 Post(s)
The bike is new, so I am going to stick with original spec. The price for resin pads is cheap enough where I don't mind changing them out every couple months.
I was hoping to hear about after market brands like Kool Stop or Clark's for a longer life.
Maybe when the rotors wear out, I'll switch sintered /metal.
Thanks for input
MarcusT is offline
Tandem Tom
Bicycle Mechanics
2
04-24-19 09:38 AM
CanadianBiker32
Bicycle Mechanics
13
12-05-14 05:35 PM
kardar2
Bicycle Mechanics
0
03-29-13 07:34 PM
Lawrence08648
Mountain Biking
10
10-27-10 05:15 PM
