Converting to Tubeless
I just bought a Trek Procaliber 6 with Bontrager Kovee 28-hole Tubeless Ready rims and Bontrager XR2 Team Issue, Tubeless Ready tires. What do I need to do to convert these wheels to tubeless? I have a pair of Stan's tubeless valves from an old road wheelset that I converted back to tubes (don't ask!) and sealant. Do I need rim strips? Not sure what else would be required. Thanks in advance.
Quoted: 2975 Post(s)
Liked 1,181 Times
If they are labeled as tubeless ready rims then you need nothing other than valves and sealant. Tape should be on the rim already.
Quoted: 257 Post(s)
Liked 70 Times
If there is no tape, rolls of tape like Stans is relatively inexpensive. Are the tires tubeless ready? Also may need an air compressor to seat the tires correctly
So does that mean my Stan's tubeless valves won't work? Thanks.
If you have issues fitting the tubeless valves, using some rubber o-rings might help. (I had to use some 6x2 rubber o-rings to help seal the valve).
