Can I repair this or should I replace it immediately? [Side of rear tire]
Average commuter joe
Bikes: Specialized Sirrus Sport Disc 2016
Just noticed this today, a litte tear on the sidewall tan of my tire (Specialized Infinity Reflective Tan). How problematic is to keep riding it? Is there a fix or I just lost this tire?
Quoted: 5224 Post(s)
Liked 3,581 Times
that's certainly something to replace. kinda don't know how long it would last. I once rode a '70s era bike w/ possibly original tires. I did a test commute & about 3/4 the way there the sidewalls started popping & looked a little worse that yours. I turned around & made it back approx 13 miles. you tire is probably newer but they don't make them as durable these days, I don't think. change it before your next ride if you can. have no idea what you could do to "repair" it
Oh wel, that's a bummer. The previous owner barely used it, and I do really short commutes, so not many KM under it's belt. Anyways, not worth risking a crash, right? Thank you!
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
There is a definite bulge there too. Replace it. Sorry
Likes For alcjphil:
Liked 2,963 Times
time to retire that tire.
-Oh Hey!
-Oh Hey!
Mad bike riding scientist
Quoted: 6212 Post(s)
Liked 4,210 Times
Although it doesn't look like a rim brake (the rim is unscratched), you might want adjust the brakes as well. That looks like a classic brake rub on the tire. If it's not a brake rubbing on the tire, you should find out what is wearing through the tire and prevent it from doing it again since you'd just have to replace a new tire rather quickly.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 1818 Post(s)
Liked 1,693 Times
Non omnino gravis
No to sound too much like a crotchety old guy-- I mean, I'll do almost anything I can to squeeze a few more miles out of a tire-- but the tire in question costs around $17.
Just buy a new tire.
Optically Corrected
Yep, time for a new tire. Put the new one on the front and rotate the older tire to the rear wheel.
Best practice to always have the “freshest” rubber on the front.
That is a good call, maybe not applicable in this case, but perhaps something that other people looking at this thread should look into. Sidewall failure close to the rim when you don't have rim brakes is almost always about tires that have simply dried out and can't hold together any longer.
Thanks for the tip, will do it!
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
Maybe not many kms, but you can tell by how dried out the sidewall looks that it is at least a few years old, or is left in the sun a lot.
Anyhoo, replace. No repair advisable or possible.
