Tire Blew off no clue why.
Quoted: 680 Post(s)
Liked 949 Times
this is a DT Swiss 540 rim with maybe 4000 miles on it with tubed tires. our tandems front wheel was getting rebuilt with this exact setup so I put this wheel on ran tubed tires but then realized it will be the same setup so made it tubeless. two layers of dt-swiss tape pulled snug and pressed down very well with the rim cleaned tin alcohol first. the tires went on with no tool like it did on my other rims. brand new Scwalbe marathon almotion tubeless tire on its a 700x38 tire. I have used two of these tires on velocity cliffhangers just fine.
the tire sealed well I used muc-off sealant. set the bead added sealant went riding 20 minutes later it had not lost any air before we rode. 7 miles to the store came out and t was at 30 psi used co-2 rode home. it was low this afternoon like expected filled it to 60 psi (its 50 to 70) and we hoped on got maybe 100 feet and the tire totally blew off the rim. took about 10 feet to stop the bike rolling on the rim. for some reason sealant doesn't to work well on a disc. wife and I hauled the bike back home. I checked I don't see anything wrong with the rim but the damage from rolling on the pavement and the tire looks perfect.
Quoted: 140 Post(s)
Liked 163 Times
Too much air pressure for the tire/rim interface to remain air tight, which tubeless tires absolutely require. That's the simplest explanation there is, and it's accurate. As for a more specific cause, there are lots of variables and possibilites.
But back to the basics, I'll add the inevitable anecdote. I run 38mm tubeless tires at 50psi or less, depending on the application, and I've never had one blow off the rim.
edit: I'm gathering from your original post that you were riding a tandem. I love the advantages of tubeless tires, but I don't think I'd run tubeless on a tandem. Two riders, two tires, the requirement for somewhat higher psi in the tires, to me, says says tubeless is not the way to go for tandem riding. YMMV.
Quoted: 680 Post(s)
Liked 949 Times
Quoted: 140 Post(s)
Liked 163 Times
the minimum is 50 so I keep it at 60 as I accidentally ran the back at 45 thinking the mim was 45 and got a cut in the bead. been running 60 on the cliffhangers for several months. this rim is a far higher psi rating and the tire is rated to 70 psi. I was thinking heat the wheel was around 80 or so degrees and the pavement was I would say around 90 thats what my Garmin was showing. but on the cliffhanger I have had them to far hotter then that.
Expired Member
Quoted: 3677 Post(s)
Liked 5,441 Times
Sounds as if it's time to rethink the tubeless choice. It doesn't work out for everyone.
Likes For shelbyfv:
Quoted: 4806 Post(s)
Liked 3,932 Times
Did you check to make sure the bead line was a uniform height above the rim? (I don't do tubeless but I assume that bead line is there on those tires like it is on all regular clinchers.) That bread line check is the single best way to ensure the bead is sitting a uniform distance below the rim edge. The fact that this tire went on easy means the bead is sitting closer to the edge and that check is more important.
When you first seated the tire, did you make sure that the bead was seated very evenly around the outside perimeter of the rim? If it wasn't, it might not have been snug enough to prevent the bead from crawling... any motion it can make down or toward the rim center can allow the bead to rise up off the rim elsewhere. In that case, the solution is to use a thicker wrap of tape.
Also, did you use wide enough tape? It's a bit hard to tell from the photos, but it looks as though the tape isn't reaching the tire beat seat shelf. On most tubeless rims that need tape, the tape should cover the entire width of the inner bed; DT Swiss recommends using 27mm-wide tape on rims with an internal width of 24mm.
Likes For fooferdoggie:
Quoted: 680 Post(s)
Liked 949 Times
Quoted: 680 Post(s)
Liked 949 Times
Should I just have their rim replaced or sand it down? I think replace it then take change. it's not too bad but still. how about the tire?
its strange that the fire is rated at 70 psi I doubt that would work with many rims. much below 50 on the back of the tandem was an issue so there is not much room there for air loss.
I may have been fine if I ke[t the psi around 55 but who knows?
Really Old Senior Member
ONLY ARTICLES 11654230, 11654059 AND 11654060 ARE TUBELESS COMPATIBLE.
https://www.schwalbetires.com/Marath...otion-11654230
That tire appears to come in a tubed AND tubeless version.
Do you have the correct one?
Quoted: 1088 Post(s)
Liked 1,026 Times
To echo Bill, the Schwalbe tires I run have TCS included with the make/model name, yours doesn't, but it should be labeled on the tire somewhere or it isn't. A regular folding bead tire can have the bead stretch without the tube there to hold it.
I've ridden home with a flat before, just take a small file if you have one and hold one hand gently against the rim and lightly spin it with the other hand so you can feel any spots that are sharp or somewhat sharp and give those spots a quick swipe with the file, not need to sand the whole edge.
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
looks like the rim tape is too darn wide, filling up part of the groove that holds the tire in the rim, foofy.
bummer.
start trimming.
or replacing with fresh expensive plastic rim tape.
all to make a super stiff tire feel a tiny bit more compliant... smh.
bummer.
start trimming.
Quoted: 2333 Post(s)
Liked 2,097 Times
Your pressure gage can be inaccurate. Pavement can be 140F and your tires can heat close to that temperature with pressure increasing. Bottom line, you exceeded the pressure limits of the rim.
Quoted: 6197 Post(s)
Liked 4,814 Times
I question the two layers of tape. Where they the same width tape? Perhaps the second layer didn't let the tire bead lay properly in the bead seat.
But then again, if you were over the pressure recommended, that's the thing to correct first. If it happens again, we all can wonder and speculate some more.
Expired Member
Liked 5,441 Times
Wrong pressure, wrong tape, likely wrong tire. Three strikes. A cavalier approach to stuff just isn't right when someone is depending on you for their safety. JMO.
Quoted: 680 Post(s)
Liked 949 Times
my makita seems to be the same as my topeak and my park tool filler. I know the temp of the pavement as I was kneeling on it and I know the hard way that it has to be 115 degrees to have 135 degree pavement here. yes but why is the tire rated for 70 psi as that seems pretty high for a tubeless tire?
Quoted: 680 Post(s)
Liked 949 Times
I know that tire was a issue at 45 psi. I wanted them at 50 but that does not give any room for air loss. How would I know its the wrong pressure if your within the tires range? I doubt many people go check on what the pressure range is for a rim.
Quoted: 680 Post(s)
Liked 949 Times
Liked 3,932 Times
Idea. Go to a tandem forum and ask what tubeless rim/tire combos. pressures etc. other tandem owners have had good experience with. Tandems are a different beast. Folk who ride them know what works.
Likes For 79pmooney:
Why don't you answer the question I asked in post #12?
Quoted: 680 Post(s)
Liked 949 Times
Quoted: 680 Post(s)
Liked 949 Times
looks like there is no TLE or such label on the tires. my g-1s dont have them either. so there is no way to know if the first ties I bought are tubeless. the tubed version is a tiny bit lighter.
