is heavier better on gravel?
Quoted: 1218 Post(s)
Liked 298 Times
Meaning , heavier frame, heavier bikes in general.
Do heavier bikes get bounced around less. Thus more efficient by keeping the rubber on the surface. Huge advantage in supple tires.
I do understand that in a real world it's not all flat and not all gravel is the same.
Just something I thought about. Based on having an interest in 2 bikes that are similar yet in two total differnt worlds. Kona Unit X for the Utility side.
And, carbon Scalpel HardTail with a normal fork. And no bs aiOffset. It would definitely make the climbs enjoyable!
Both bikes land between my RLT9 and my Trance 29er. Which is exploring bike, commuter ish bike, camp bike, gravel bike for when its too rough for skinny 40s but not yet in trance territory. I'm also finding it much more fun to explore towns on flat bar.
I've never ridden steel on gravel. I'm curious though on the Unit x
Quoted: 431 Post(s)
Liked 460 Times
I only notice heavier bikes being better on descents. I'm not talking about the heavier weight being slightly faster due to gravity; heavier bikes tended to feel more planted to me and better able to plow through technical sections going downhill. On flat terrain this is a wash because being heavier and more planted is offset by the lack of responsiveness.
Likes For tFUnK:
Quoted: 286 Post(s)
Liked 262 Times
My last two bikes were about the same weight. Former was cx geometry, it was suspect on loose descents. Current bike is slack/mtb-like geometry and it’s a night-and-day improvement. Weight may be one factor, but I would think geometry is more important.
Quoted: 3242 Post(s)
Liked 2,089 Times
No heavier just rides like a truck. My gravel/easy dirt trail bike had been my lugged steel tourer, with no racks, gravel tires, etc…. It weighed 26 lbs stripped down and was a beast to ride, especially up hills. I added a C-Dale Topstone to the stable in ‘19, much lighter aluminum, lighter wheels, wider tires that I could run at lower pressure. 22 lbs, was a really good ride on gravel/easy dirt trails.
Likes For Steve B.:
Quoted: 446 Post(s)
Liked 1,045 Times
Sunshine
Quoted: 10969 Post(s)
Liked 7,495 Times
Yeah, OP is onto something here.
It's why I ride 15# over ideal weight, so I can have a better ride on gravel. Yep, that's it. That's why I don't lose weight!
A heavier bike isn't better on gravel compared to a lighter bike. A heavier bike is just heavier.
I could cut 3# off my bike if I swapped my stout 853 steel frame for a light carbon frame, swapped wheels for some lighter carbon wheels, and got a lighter saddle.
My bike doesn't ride better now than a bike that's 3# lighter.
Likes For mstateglfr:
Not really. Most of what the rider has to deal with it stuff that's low-frequency for the tires to filter out, so heavier just means more mass for you to wrangle.
It's often worth paying a price in weight for something, but the weight generally isn't a benefit in its own right.
Randomhead
Liked 3,699 Times
My gravel bike isn't heavy enough to avoid being thrown around, so I gained weight to compensate.
But really, it's not going to help.
Likes For unterhausen:
