Problem with new wheels please help.
I've just had some wheels built up with Zipp Flash Point rims. I just have a few questions. Is it normal for the rear wheel to flex a little? I stood up to sprint up a hill and my wheel would scrub my rear brake. We opened up my brakes and the rubbing stopped. The wheel appears to be true.
Also my rear wheel looks like rocks have hit the side of it. There's a bunch of what appears to be little chips on the carbon part from the spokes to half way up the rim. Not right at the spokes but half deep in the rim toward the spokes. My front wheel still looks brand new. I'm just worried since the rear wheel takes all the abuse.
My wheel build is 09 Zipp Flashpoint rim. Speedcific hubs. Sapim CX rays with a tougher Sapim spoke on the driveside. We also used tougher nipples on the driveside as well. I'm also heavy weighing 215lbs.
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
Some people that I know that have Zipps complain about them flexing. My Reynolds don't flex much but I'm not very heavy or powerful. I think given your weight it is normal that they are flexing.
Dirt-riding heretic
Bikes: Lynskey R230/Red, Blue Triad SL/Red, Cannondale Scalpel 3/X9
Quoted: 5 Post(s)
Liked 8 Times
Check the bearings, make sure the spokes are properly tensioned (although this sounds like a Mike Garcia build, so that's unlikely).
Which Flash Point rims are you using? IIRC many of them have a max rider weight of 200lb.
"Unless he was racing there was no way he could match my speed."
They are a Mike Garcia build. I'm pretty sure all the spoke tension would be correct. All I know is they are the latest clincher 404 style rim that he just started selling. I'm not as concerned about the rub as I am about the little chip places that have appeared on the rim. I told Mike what my weight was and we were pretty sure that wouldn't be a problem. The wheels turned out great. I guess the simplest thing to do would be to lose all that weight I need to lose.
(sorry--mod error. Post restored.)
Dirt-riding heretic
Quoted: 5 Post(s)
Liked 8 Times
And sorry about messing with your post-- "edit" and "reply with quote" are right next to each other.
Dirt-riding heretic
Quoted: 5 Post(s)
Liked 8 Times
If you're having problems with an overly flexy wheel AND the clearcoat is cracking, it could be a sign of extreme badness. Might also not, but one of the reasons you pay a guy like Mike to do your wheels is so that you get answers to those questions.
I dont think its from rocks because there are quite a few of them and the front still looks like it did the day I got it. This is probably the 4th time if ridden on them.
Dirt-riding heretic
Quoted: 5 Post(s)
Liked 8 Times
It's a serious problem with your rim until proven otherwise. Don't ride on it until Mike evaluates it.
