Addiction LXXVIII
#1602
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
For most of the last 20 years I was the only one at the job who had any carburetor experience at all. The younger guys weren't even born when GM stopped using carbs. I stopped working on customer carburetors around 2000 or 2001, I think. Just too time consuming and people's expectations are too high. I still did carb work for the shop owner's fleet of old cars.
I don’t know crap about cars anymore but I do know how to sync a set of SU carbs by ear. 👍
Keep the chain tight!
#1603
Should Be More Popular
Quoted: 22590 Post(s)
Liked 8,924 Times
#1604
Super Modest
Liked 4,620 Times
You share a birthday with my 18 year old grandson who was diagnosed with ankylosing spondylitis at 13 or so. We went over, put his presents on the front porch, rang the doorbell, backed off 10’ and then sang happy birthday when he came to the door.
#1605
Quoted: 8275 Post(s)
Liked 9,031 Times
Now we have direct injection. High voltage injectors spray fuel into the combustion chamber under 1200psi. What could go wrong?
#1606
Quoted: 20810 Post(s)
Liked 9,456 Times
#1608
Administrator
Quoted: 11960 Post(s)
Liked 6,629 Times
Happy Birthday from BillyD, anyway! I can’t speak for the filter.
#1609
Bikes: Shmikes
Quoted: 10165 Post(s)
Liked 5,852 Times
Likes For MoAlpha:
#1610
Bikes: Shmikes
Liked 5,852 Times
Hey, @datlas. My wife is having asymptomatic PACs or PVCs by palpation, several a minute. She's healthy and fit, but totally stressed from trying to manage and save her group practice in the midst of this chaos. Should I make it about me by panicking?
#1611
VFL For Life
Bikes: Velo Volmobile
Quoted: 28595 Post(s)
Liked 1,855 Times
#1612
Liked 8,924 Times
Fun fact: metoprolol succinate is one of the few "XL" medicines that can be cut. The absorption is attenuated by the drug itself, compared to the shorter acting metoprolol tartrate.
#1613
Bikes: Shmikes
Liked 5,852 Times
Nope. Ignore. Cut caffeine and stress management. If it really starts to bother her she could take a 1/2 metoprolol succinate 25mg daily, as long as she does not have asthma.
#1614
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
We will hit 41°C today and tomorrow, and have been at or above 38 for quite a few days. Our Coronavirus cases continue to rise. Yucatan ranks 4th highest per capita in the country. Hot weather doesn't seem to be the panacea some have hoped for.
#1615
Liked 8,924 Times
I would not worry too much about it. What does she do for work??
#1616
Bikes: Shmikes
Liked 5,852 Times
Psychologist. Does only assessment these days, but manages a big multi-specialty psychology practice.
#1618
VFL For Life
Liked 1,855 Times
#1619
smelling the roses
Liked 901 Times
And now I will venture out for my daily visit to the other property, a five minute walk away. I've been going at 5ish, as things cool down a bit, and feel like I"m in grand central station. I imagine that won't be the case now.
#1620
Quoted: 3357 Post(s)
Liked 3,636 Times
There's a brand new episode of "Funky Electrical Problems From Your 2011 Chevy Colorado" that aired this morning.
Driving in to work, I had no turn signals at all indicated on the dash. No aural indications of the lights switching on and off, either.
I parked my truck and turned the key to the "off" position, and nothing happened. The truck kept running and everything stayed on. I cycled the key to "on" and then back to "off". Worked normally.
At lunch I went out to check to see if anything was actually happening with the lights on the outside. Turned hazards on, all four corners lit up properly.
Switched on left turn signal, left side lights flash.
Switched on right turn signal, left sight lights flash...
Likely have a sticky contact somewhere in the switch. Possibly in the ignition switch as well? At least I have a project for the weekend though
#1621
Liked 3,636 Times
The internet is so incredibly useful sometimes. From another forum:
Something very strange started happening two days ago with the turn signals on my 2006 3.5L Colorado WT. First I noticed that no matter which way I flipped the turn signal level, it was always flashing the left signal, both the actual lamp and the dash indicator. Then yesterday for a couple of hours I lost turn signals completely, but I noticed that if I left the lever right or left the turn signal warning indicator would come on like normal even though no turn signals or dash indicator was showing. Today I'm back to the original problem. Signalling left or right always flashes the left signal and dash indicator.
Has anyone seen this before?
UPDATE: I had a look at the circuit diagram and realized that the turn signal switch is a two-wire device rather than the standard 3-wire SPDT type. Apparently this switch has two resistors inside that both connect on one end to ground. The switch connects the other end of one of the two resistors to the control unit, which detects whether to activate the right or left signals by the resistance detected to ground.
This means that a loose connection that raised the series resistance could fool the control unit into thinking it should activate the left blinker when the right one was selected.
#1622
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
OTOH, I must give kudos for dropping an "aural" in casual conversation.
#1623
Liked 8,924 Times
Nothing against any lurking pharmacists there....but on a daily basis I get SEVERAL messages from pharmacists stating the patient's current (and longstanding) medicine is not available due to backorder/shortage.
That's it. How about telling me what CLOSEST medicine they have that insurance will cover?
No. So I either have to call them to ask that, or play "read their mind" and order what I think is the next best choice. Often times insurance won't cover that. Or it's backordered.
Sigh.
Sigh.
#1624
Liked 3,636 Times
Had the wiring from the "door open" switch on the driver side fail twice, about a year apart. I checked my initial repair and it was fine, it failed in a different spot
I have an intermittent ground somewhere around a junction box that will cause the AC/heater fan blower to be intermittent. It's favorite time to fail is, naturally, on the highway on a hot or cold day with no good place to pull over and jiggle it until it works again.
Now turn signal switch and ignition switch issue.
Truck has 110k miles And it's on it's second engine.
#1625
Liked 8,924 Times
I hope she is eligible to get one of those small business payroll loans from the feds that turns into a grant if certain conditions are met. We have applied for them. Fingers crossed we can all survive.
Likes For datlas:
