Sutherland's Handbook - torque specs (3rd or 4th ed)?
Does Sutherland's 3rd or 4th edition of the manual include recommended torque specs for Campagnolo components (crank bolts, chainring bolts, etc.)? Thinking about nabbing a copy as a reference, mostly for 70's through mid-80’s C&V builds and maintenance.
Thanks.
Thanks.
The original Campagnolo specs, or Barnett's would be better choice for that, I think. Sutherlands gives no torque specs that I am aware of. Barnett's does.
Can confirm Sutherland’s 5th edition does NOT list torque specs. Don’t expect earlier editions do either.
Old fart
Quoted: 3590 Post(s)
Liked 3,400 Times
Sutherland's 6th edition does give crank mounting bolt torque values:
Señor Member
Quoted: 1491 Post(s)
Liked 1,093 Times
Only mention of torque in Sutherland's 3rd is for Sturmey Archer brake arms.
Thanks, everyone, for your speedy and helpful replies. I've been going with some of the recommendations in Zinn's book and the Park Tools torque chart, but they're not that specific to the old Campy bits. I'll check out Barnett's, thanks for the tip @jiangshi. (I haven't seen a copy of the original docs that came with bits such as the crankset -- going to do some research into that. Thanks for that suggestion, too).
Disraeli Gears
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
Inhale, a smooth snug following by near instantaneous expulsion of air. A grunt is too tight.
Warren's 11th edition.( I use Sutherland's Fourth)
