Movement forward & back & side to side on specialized roubaix front forks
Hi all, I have a 2017 Specialized Roubaix which is great but recently it has developed side to side and forward back movement/play in the front forms in addition to the up down which the Future shock delivers. Has anyone else experienced this and got a solution please?
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Sounds like the stem is loose. If you don't know how to fix that, bring it back tot he shop you bought it from. They should adjust it for free.
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,204 Times
Jlec67: It’s an easy fix if you have experience with a bike. But in asking the question, I feel it might be something better addressed by your bike shop.
Stuart Black
Stuart Black
On Your Left
Liked 2,433 Times
Doesn't the stem and end cap hold the headset in place?
Quoted: 6944 Post(s)
Liked 10,944 Times
Not really. You loosen the stem bolts to adjust the headset (by adjusting the end cap bolt) and then torque down the stem bolts...But they don't "lock in" the headset adjustment, and hence a loose headset can cause problems even if the stem bolts are torqued properly. So, a headset can go wobbly even if the stem is torqued properly. Ask me how I know.
On Your Left
Liked 2,433 Times
Liked 10,944 Times
Likes For Koyote:
Quoted: 1579 Post(s)
Liked 1,187 Times
Jlec67 , take your bike in to the shop ... sooner, rather than later.
Likes For badger1:
Headsets usually DO NOT come loose. There is the possibility that you were adjusting your stem and insufficiently tightened the stem allowing the headset to gather slack. The top cap doesn't hold the headset in tension. It will hold it there while you tighten the stem. It the stem is loose it can pull the cap-lock slowly outward. This is a DANGEROUS condition and I recommend having the shop look at it since you have a lifetime warranty.
There is a third possibility - the steering tube is pulling out of the fork. Or perhaps is broken or breaking off. While this is very rare you should have the shop look at it to eliminate that possibility.
Bikes: Modified 26 inch frame Schwinn Varsity with 700c wheels and 10 speed cassette hub. Ryan Vanguard recumbent. 67cm 27"x1 1/4" Schwinn Sports Tourer from the 1980's. 1980's 68cm Nishiki Sebring with 700c aero wheels, 30 speeds, flat bar bicycle.
Quoted: 131 Post(s)
Liked 141 Times
Trailangel you are so right. Any bicycle with suspension components is a wearing out continuous maintenance headache. So many suspension bikes start having wheels that lean a little due to wear and don't trail right. Lots of cheaper suspension bikes have these problems but I've seen it in pricey suspension bikes also. Being cheap I would confidently try to repair the bike myself. If my confidence fades then to the shop with it.
Quoted: 1247 Post(s)
Liked 1,321 Times
Likes For Atlas Shrugged:
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,029 Times
Quoted: 131 Post(s)
Liked 141 Times
I've had to replace a front fork on a Trek 4500 bicycle. This fork locked up due to no maintenance a couple of years after I bought it used. I soon found out that this fork needed regular maintenance. If you look at the maintenance requirements for your suspension components you will find that they need a regular schedule of maintenance. Anything that moves at pivots or on stanchion tubes is a wear item. If your suspension components are kind of rare then the cost of maintenance goes up. I could not replace the original fork on the Trek and had to carefully spec a replacement. The original used a stem and the new is an Ahead Set type. So I had to replace the stem also. That is when I started noticing how many suspension bikes did not trail well. A lot of them are actually quite a ways out of trail. Wheels that are not dished right will cause trail problems but the problems I see go beyond what wheel dish problems can cause. I see this less in expensive bikes.
Liked 4,204 Times
Lower end forks like those that come on the Trek 4500 aren’t as high a quality as the ones I use but even those don’t require constant maintenance. In fact, many of that type of suspension fork can’t be serviced. There simply aren’t parts available. When the fork fails, it’s easier and cheaper to just replace the fork...with a high quality used fork.
If you are going to rigid, you have to take the suspension into account but for a Trek 4500 with a threaded headset, I doubt that the suspension correction is going to have much of an impact. That kind of bike had an 80mm suspension fork on it which doesn’t make much enough of a difference to even consider a suspension corrected rigid fork.
Both forks have a “stem”. The threaded one is a quill stem and the threadless one has a threadless stem.
However, a frame issue has nothing to do with a loose headset.
Stuart Black
Stuart Black
Quoted: 131 Post(s)
Liked 141 Times
However, a frame issue has nothing to do with a loose headset.[/QUOTE]
Quill stem is the correct word. I am a fan of quill stems. You are right on tracking instead of trail. Trek had a 1 1/2" threaded steerer tube. These were only on the market a couple of years when ahead set came along and everything went unthreaded. I could not find a new 1 1/2" threaded steerer tube suspension fork, only 1 1/2" unthreaded ones. My wife did not want a solid fork. I thus was stuck with buying the right ahead set type steerer bearings and the appropriate 1 1/2" unthreaded fork along with an ahead set stem. Finding the right size steering bearings and cups was a maze of measuring because several different headset bearing standards have been sold over the years. The Trek has been a favorite bike of my wife's for years now so it got repaired.
Liked 4,204 Times
Quill stem is the correct word. I am a fan of quill stems. You are right on tracking instead of trail. Trek had a 1 1/2" threaded steerer tube. These were only on the market a couple of years when ahead set came along and everything went unthreaded. I could not find a new 1 1/2" threaded steerer tube suspension fork, only 1 1/2" unthreaded ones. My wife did not want a solid fork. I thus was stuck with buying the right ahead set type steerer bearings and the appropriate 1 1/2" unthreaded fork along with an ahead set stem. Finding the right size steering bearings and cups was a maze of measuring because several different headset bearing standards have been sold over the years. The Trek has been a favorite bike of my wife's for years now so it got repaired.[/QUOTE]
I will almost guarantee that the Trek 4500 didn’t have a 1 1/2” headset at any point in time...especially if it had a threaded headset to begin with. It had a 1 1/8” external cup headset. The conversion is relatively straight forward and finding a headset isn’t all that difficult. Internal bearings are kind of funky but external cup is fairly easy. I’ve done the conversion many times.
Stuart Black
Stuart Black
Quoted: 131 Post(s)
Liked 141 Times
My bad Trek 7100. I recently repaired and sold a Trek 4500 which had ahead set technology.
Liked 4,204 Times
Still only a 1 1/8” external cup headset.
Stuart Black
Stuart Black
Quoted: 131 Post(s)
Liked 141 Times
Your are right again. All that happened was a threaded 1 1/8" threaded suspension fork was replaced with a 1 1/8" threadless suspension fork with appropriate headset change and change to a threadless stem. Memory fails me again.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
All of you are posting about loose headset this and that...with the future shock there is a possibility that the FS unit has worn out and is moving. As posted previously the headset adjustment is completely unique to the future shock. On the first gen FS there is a top cap and screw but they don't adjust the headset. On the newer adjustable units there is not a screw on top to hold the cap on, nor is there a top cap. There is the dial that controls the lockout on the FS. The headset is adjusted w/ the 2 screws on the side of the steerer tube. This can be adjusted perfectly but there is still movement that looks just like a loose headset. The FS unit can wear out and have slop as someone posted earlier (future slop). It is very easy to replace and it seems like many times Specialized will warranty it.
Likes For cxwrench:
