What's the worst thing to use to clean vintage decals?
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
Several of the decals on one of the new bikes have what appears to be medical tape over the 531 decals. Normally my bikes are already disintegrated by the time I get ahold of them. I know they are usually super delicate paper stickers, so I am not sure what the best course of action would be. Usually I'd use a little high test alcohol, but wondering if some baby oil might be better.
Any suggestions?
Any suggestions?
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,180 Times
Any suggestions?
Any suggestions?
Best, Ben
Voltaire
Voltaire
Bikes: Subject to change at any given moment but currently is...... Colnago Mapei, Colnago C40, Wilier Triestina Carbon, Wilier Triestina Ramato, Follis 472, Peugeot PX60, Razesa, Orbea Terra, Soma Pescadero and 1/2 owner of a Santana tandem.
Quoted: 331 Post(s)
Liked 782 Times
I’ve used WD40 for similar projects with success. However I’d hate to have you use it and have it destroy your decals somehow ?
52psi
Quoted: 790 Post(s)
Liked 802 Times
Flamethrower?
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
try some rubbing alcohol or maybe goo gone.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Likes For Cyclist0108:
Off grid off road
Worst? Hammer and chisel might do it.
Not worst: Water and hand soap, vinegar or lemon juice, or olive oil.
Usually work for me unless caked-on oily grime on mechs.
weapons-grade bolognium
Quoted: 985 Post(s)
Liked 2,378 Times
Start with water - place a moist paper towel on there and let it sit. Sometime, this will soften the adhesive and you can "roll" it off but rubbing with a finger.
Likes For thinktubes:
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Stay away from commercial cleaners like Spray-Nine or even WD-40, especially on old decals. Dawn dish soap and water is my go-to.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3886 Post(s)
Liked 6,482 Times
Flamethrower?
Likes For SurferRosa:
small ring
Quoted: 437 Post(s)
Liked 925 Times
This is C&V after all. Those other methods are too high tech.
Although, Germany did use flamethowers in WWI
59 Allegro Special -- 72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
Quoted: 964 Post(s)
Liked 1,451 Times
My goodness, the threads these days!
Set an original Campy brifter box on fire (with the brifters still inside) and burn it off. Then scrape off the charred residue with a brake disc. But you should throw away that fork anyhow. It is definitely bent.
[/thread]
To avoid posting something that lacks substance, I can say that acetone is harsher than most other solvents you could try. I have had good luck with ethyl acetate (commonly found in non-acetone nail polish remover) to remove rattle-can paint while leaving original finishes untouched. Isopropyl alcohol is less harsh, and I would say goo-gone is a step lower still, on the totem pole of harshness.
[/thread]
Quoted: 3015 Post(s)
Liked 3,802 Times
I was thinking nuclear blast, but then I thought black hole. If you are going to take something down, you might as well take the solar system with it.
1. Water and Dawn
2. If that don't work, Goo Gone
3. If that don't work, alcohol
4. If that don't work, acetone
1. Water and Dawn
Quoted: 964 Post(s)
Liked 1,451 Times
3.5. Ethyl acetate, which is in many brands of non-acetone nail polish remover. Trust me, I'm a chemist.
Quoted: 3810 Post(s)
Liked 6,691 Times
Has anyone suggested a Sawzall?
Otherwise, trust the chemist.
Likes For nlerner:
Liked 2,180 Times
Any suggestions?
Any suggestions?
The adhesive on the tape looks like it has dried out and may be hard to lift without removing the decal. Waterslides have a water-soluble glue on them which makes removal of the tape difficult/impossible.
Is the tape residue on the area that the tape has been hard or is it still reasonably pliable? If so you might try rubbing the tape off by starting on an area that does not have any decal underneath (low heat from a hairdryer may soften it a bit) it to see if it will rub off....if so continue with care.
But I am afraid that you will need to purchase some replacements...the ones on the frame seem beyond saving.
Good Luck, Ben
BTW, the title of the thread elicited the hilarious responses that were on point....worst/best?
Voltaire
Voltaire
Likes For xiaoman1:
señor miembro
Liked 6,482 Times
Old wigs and a magic 8 ball.
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,097 Times
You guys are pretty creative. I was just gonna say a wire brush.
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
Lighter fluid, the kind that comes in a yellow bottle- Ronsonal.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4680 Post(s)
Liked 5,798 Times
Use a gun.
Take the cannoli.
Take the cannoli.
Likes For gugie:
