Help with rear tire installation
I bought a knock-around fixed gear online to replace my recently stolen one. I'm currently building it but have run into a problem with the rear tire. The nuts on the rear hub are preventing the tire from fitting, and trying to remove them has proven impossible with my weak muscles. Aside from taking it to my local shop, any thoughts on how to fix the issue?
Thanks
Thanks
Quoted: 581 Post(s)
Liked 921 Times
If you are sure you have a proper fitting wrench (probably 15mm but I'm not certain about track and fixie parts) then the trick is to add leverage - find a pipe that can fit over your wrench and use it to effectively lengthen the wrench. The other possibility is to position the wrench such that you can use your foot to push down and loosen the nut. But a length of pipe (called a 'cheater bar') is the best solution. You'd be amazed at how easily a tight nut can come loose with along enough wrench.
Also, if using a 'combination' wrench (one side open, one side closed 'box end') then use the box end whenever possible.
Quoted: 6193 Post(s)
Liked 4,810 Times
Do you have a mini vulcanizing machine that you can build your own tire on the wheel without removing the wheel from the frame? If not, then go to a bike shop where they'll be able to remove the wheel and properly install the tire.
Sorry to not have the answer you seem to want, but if you can't get the nuts off the axle to remove the wheel, then I foresee many other problems.
If you want to proceed though, we can help, but you have to remove the wheel. A start will be telling us what make and model bike you have.
Likes For Iride01:
Quoted: 1819 Post(s)
Liked 1,693 Times
Thanks
Thanks
Unless perhaps you are talking about installing the wheel into the bike frame
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Welcome to Bike Forums.
I suspect your description of not being able to install a tire really means you can't install a wheel.
Tire installation is what you do after fixing a flat.
Are you're sure you are attempting to remove the Wheel retaining nuts and not the Adjustment cones for the hub?
If you are sure it IS the wheel retaining nuts.... These nuts are a regular right handed thread and loosen by turning anti-clockwise.
They may be tight and will need two wrenches one each side of the hub, But that would be unusual for a new wheel.
Barry
Bicycle Wheels Nuts look like this
Barry
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Likes For JohnDThompson:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Tire=the rubber part w/ the tread
Tube=the rubber part inside the tire that holds air
Wheel=the rim/spokes/hub
Rim=the big round thing
Spokes=obvious
Hub=the thing in the middle the spokes attach to
Please use proper terminology, it helps to eliminate any confusion.
Spokes=obvious
Expired Member
Quoted: 3674 Post(s)
Liked 5,432 Times
I agree. If you can't remove the wheel you are in over your head and need to take it to a shop.
Quoted: 194 Post(s)
Liked 204 Times
As to the wheel nut size, I have 13, 14 and 15 mm on my various bikes, all from the same manufacturer, so I automatically grab all three wrenches each time I have to remove a wheel
I assume that you are trying to turn the nut in the right direction, so with the bike standing securely upright and the wrench fitted parallel with the ground, put all your weight onto the wrench. If that fails then you can try carefully standing on the wrench - just make sure that the wrench is securely on the nut and stand on it without disturbing the wrench on the nut.
Liked 4,810 Times
Thanks
Thanks
If the hub of the wheel will not fit in the frame of the bike, then either the hub is the wrong O.L.D. (over locknut dimension) for the frame or the frame is bent.
If the nuts in question are a gray or silver color then someone ran them down too tight on the axle. Be careful trying to undo them, you might move those black nuts which again control the bearing adjustment.
You might have a hub with QR's, (quick release) and that will be another issue.
A pic might help, you can upload a pic to the Gallery here, and just let us know to look for it. Or put the URL of your pic in the plain text of your message and remove the https:// and put spaces before and after any . dot in the url.
