Rack surgery
Bikes: 1966 Paramount | 1971 Raleigh International | ca. 1970 Bernard Carre | 1989 Waterford Paramount | 2012 Boulder Brevet | 2019 Specialized Diverge
Quoted: 129 Post(s)
Liked 77 Times
Rack surgery
I'll share this short story and a shout out to fellow forum member, @gugie, not because it's especially pertinent to C&V, but because it's probably of more interest to this group than any other.
So, several months ago I ordered a L'Avecaise from from Jeff Lyon. Let me just say that he's a joy to work with and the frame, after several pensive months of waiting, arrived back in June and I'm very happy with it. It's been the easiest build ever, and I fitted fenders in - literally - no time at all. What a pleasure it all was...until I went to install the VO front rack.
Ugh. Look at that angle... and no amount of bending got it anywhere close to level. Enter Mark Guglielmana (dang, I hope I spelled your name correctly.) He offered to do a bit of surgery to the rack stays.
A bending to level the rack out, a little close measurement, and a little cross country flight for the rack to the Pacific Northwest, and a little surgery later, this is the result:
A big thumbs up and a happy smile creasing my face!
Nice, please share detail shots of his brazing/welding handiwork.
Quoted: 3814 Post(s)
Liked 3,345 Times
Yet another splendid success for Gugieficazione!
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,803 Times
Note to anyone looking to just bolt up a rack designed for handlebar bags: Go to an LBS to purchase one so you can do a test fit. Off the shelf handlebar racks attach at 3 or 4 fixed points on your fork. There is no "standard" dimension, especially if you have to account for fenders.
Not going to lie. I clicked this thread because I assumed it was about breast enhancement
Quoted: 129 Post(s)
Liked 77 Times
Here she is, prior to the rack enhancement.
Bag is ordered. I'll make photos of the rack when it's not 195 degrees outside. (The silhouette shot above was merely to emphasize that the platform wound up being precisely the amount of level that I wanted.)
Liked 5,803 Times
Typically I take a few pix of work in progress, but Atelier Gugie is backed up a bit, and I neglected to do so. When I took this on, I thought it would the same job as I did for @rhm not too long ago - a mod to this style:
. That was pretty easy, I had the desired measurement, and just added a longer stay, pinched off the end in my vise, silvered the end and drilled a hole in each stay, then trimmed it and spliced it together with an internal piece.
This rack used the cantilever attachment style, so I had to save the end pieces, and splice a section in the middle. Here's the original rack:
Since the rack had already been bent a bit to try and make it work (argh, I feel for you Mark!), getting a square cut was difficult, but manageable. I had promised a "can't tell from a few feet away" fix, the double brazes on each end made me worry that it wouldn't be quite as good as advertised.
Customer happy, I'm happy!
Quoted: 129 Post(s)
Liked 77 Times
@gugie is underselling himself. By the time he got them, the stays had a slight curve to them - yet one has to look closely to see the joins where he spliced in additional tube on the stays.
The rack I purchased is a VO v1.0. Ironically, it appears that the VO v2.0 replaces the static center post with an adjustable version (Think: Jim Blackburn rack.) Anyhow, the new version would probably have minimized or entirely eliminated the leveling out issue that v1.0 presents. I point this out in case anyone else decides to monkey around with a VO front rack.
Alls well, that ends well though. And once my Berthoud bag arrives tomorrow I can simply chalk the VO rack experience up as one more blog posting on the Early Morning Cyclist.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I will try to remember to do that. As @gugie mentioned, mine was a relatively simple job. This was partly because he's a busy guy and I didn't want to mooch too much of his time, so I started by making my rack fit by my own means; I cut off the bottom 4 cm of the struts, inserted some scrap metal to make it the right length, and put it on the bike as a test fit. Once I had everything to the right dimensions, I sent it to Mark to unbotch the mess I'd made.
So as I say, I will try to remember to post a photo of his work. But you won't see anything. It's prettty close to seamless. :THUMB:
www.rhmsaddles.com.
www.rhmsaddles.com.
Oh, I totally understand the time consuming nature of this craft. I always find it inspiring when I see custom work done in a tasteful manner. Great job guys!
Veteran, Pacifist
Quoted: 3901 Post(s)
Liked 4,844 Times
The front rack I bought years ago had front supports that were adjustable to level the rack. Unfortunately I cannot remember the brand.
Quoted: 129 Post(s)
Liked 77 Times
Just to be clear, I had to keep moving my bike around just to find light that would allow the seams to even show up at all. They are there to be found if you go looking for them, but otherwise nada.
Veteran, Pacifist
Liked 4,844 Times
@AZORCH - glad to see orders for Jeff's work from across the country.
Liked 5,803 Times
Quoted: 129 Post(s)
Liked 77 Times
$1600 for a full rando frame and fork from a long time builder. Smokin' deal. Great guy. Would not hesitate to recommend one.
He's also a very interesting and funny guy to chat with. No matter how you dice it up, it's a win all the way around for me.
Quoted: 821 Post(s)
Liked 256 Times
Crazy good prices.
Pretty framesets, for sure.
Reminds me of Roland Della Santa's prices.
Definitely under market trends.
Looks great.
Perfect surgery job...
Liked 5,803 Times
They're working on a cure for that...
Liked 3,345 Times
I'm thinking we should start a drive to have your middle name changed to Fabbricazione.
We can all clean parts and repack bearings but scratchbuilding is a WHOLE nothuh thang!
Randomhead
Liked 3,701 Times
I assume there was some bike that rack fit on, but I'm really confused as to what it would look like. 68 degree head angle?
I had sort of assumed that angling the rack back would be best. However, I have recently seen something that said the old French guys angled the rack forwards a little. I don't think it's a big deal, but the way a randonneuring bag is made, it's not going to fall off
multimodal commuter
Liked 574 Times
For what it's worth, here's another solution to mounting that same rack.
I cut some spacers from steel tubing, somewhere around 2 cm long, and used longer bolts. I know it's not a great solution, but it's good enough that I haven't had to think about it since mounting it. Maybe I should take it apart and send it in for gugification.
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 129 Post(s)
Liked 77 Times
