what is the best way to polish Shimano 1050 Cranks
Old 08-04-17, 09:15 AM
Classtime
Classtime's Avatar
Quoted: 1952 Post(s)
Liked 2,013 Times in 1,112 Posts
I recently acquired a pair of 1987 Ironmen and the Cranks are not shiny. I realize they shouldn't look like Ultegra or Dura Ace but I would like them shinier than this. How have you polished your 1050 Cranks? (These are two different bikes)
File Type: jpg
File Type: jpg
Classtime is offline
Old 08-04-17, 09:43 AM
specialmonkey
Fillet-Brazed Member
specialmonkey's Avatar
Bikes:
Quoted: 184 Post(s)
Liked 18 Times in 13 Posts
It looks like some of the anodizing is gone which could make cleaning or polishing (to a shine) difficult.
Your best bet may be to just clean with a degreaser and maybe go over with aluminum polish.
There's always this thread:
https://www.bikeforums.net/classic-vi...ng-thread.html
You could also consider having the anodizing removed, cleaning and polishing, and possibly re-anodizing.
Good luck. Great looking bikes, I love the colors, reminds me of the Kodak Portra colors.
specialmonkey is offline
Old 08-04-17, 10:00 AM
16Victor
16Victor's Avatar
Bikes: 1974 Schwinn Paramount, 1980 Raleigh Competition GS, 1986 Vitus 979, 1988 Trek 360, 1991 Trek 7000 MTB, 1999 Burley Rumba tandem
Quoted: 96 Post(s)
Liked 7 Times in 1 Post
Soak in a lye solution to remove exiting anodizing.
Polish with your favorite compound. Wax.
Repeat polishing/waxing yearly.
BTW I like PB Blaster and a brass toothbrush for the rusted chrome chainring nuts/bolts.
16Victor is offline
Old 08-04-17, 01:38 PM
randyjawa
randyjawa's Avatar
Quoted: 1372 Post(s)
Liked 1,752 Times in 939 Posts
Do this in short bursts, flushing with water ever few minutes. That lye will eat the anodizing and it will, if left in too long, eat the aluminum also. Then to polish...
Start with # 600 wet/dry paper, used wet and sand away. Then move to 1000 grit and sand away. Then to a finer and than to a finer grit. Soon, they will bounce light like a mirror. Or, just pick up one of these at a Yard Sale for five bucks, buy the cloth wheels and polishing sticks(three grades to choose from, I choose soft metal, followed by high gloss)...
randyjawa is offline
Old 08-04-17, 03:43 PM
Classtime
Classtime's Avatar
I made a black stem shiny with oven cleaner and sanding/polishing but was hoping there was a magic trick to get the 105 Cranks looking good.
I guess some of the anodizing is gone, but not all of it, and that's why just polishing hasn't worked. I scrubbed a section with 0..0 Steel wool and it got real smooth but then polishing only gave it a sheen.
Thanks all.
Old 08-04-17, 04:39 PM
Hudson308
Mr. Anachronism
Hudson308's Avatar
Quoted: 526 Post(s)
Liked 256 Times in 165 Posts
Oxalic acid will also remove the anodizing. Dilute as directed. Takes a few days, but shouldn't hurt the aluminum.
Hudson308 is offline
Old 08-04-17, 06:09 PM
Kevindale
Kevindale's Avatar
Bikes: 1980 Koga-Miyata Gentsluxe-S, 1998 Eddy Merckx Corsa 01, 1983 Tommasini Racing, 2012 Gulf Western CAAD10, 1980 Univega Gran Premio
Quoted: 600 Post(s)
Liked 11 Times in 11 Posts
The anodizing on these parts is aluminum oxide, which is harder than aluminum alloy. I don't think there's any way oxalic acid will attack aluminum oxide, but not bother aluminum alloy. If your component already has some anodizing removed, there won't be any way to control the process.
Kevindale is offline
Old 08-04-17, 08:16 PM
plonz
plonz's Avatar
Quoted: 656 Post(s)
Liked 469 Times in 302 Posts
I love using my buffing machine but haven't worked up the courage to try using it with a drive side crank arm. I still polish the spider section the manual way you describe.
plonz is offline
Old 08-04-17, 09:34 PM
sdn40
Bikes: 88 Cannondale Criterium
Quoted: 291 Post(s)
Liked 147 Times in 91 Posts
Could those be hard water spots ??
sdn40 is offline
Old 08-05-17, 11:45 AM
CountryBiking
CountryBiking's Avatar
Bikes: '85 Centurion Ironman, '86 Novara Corsa ST, '84 Centurion Pro Tour
Quoted: 42 Post(s)
Is it "Ironmen" or "Ironmans"??
CountryBiking is offline
Old 08-06-17, 08:37 PM
Hudson308
Mr. Anachronism
Hudson308's Avatar
Quoted: 526 Post(s)
My comment comes from recent experience with a set of Mavic anodized rims. Maybe the anodizing is a different material than his cranks. I was soaking them in OA to clean up some rusty eyelets, and forgot about them for a few days. The OA stripped the anodizing, but doesn't appear to have etched the surface of the rim.
Old 08-07-17, 09:22 AM
Classtime
Classtime's Avatar
School starts again in a week. For now, you what I means.
The lye bath and sanding will be postponed. I played a little with 00 steel wool and then some #7 polishing compound and got a "good for now" shine.
File Type: jpg
Old 08-08-17, 01:03 PM
gabe3366
That looks pretty good. I'll have to try that on my bike.
gabe3366 is offline
Old 08-08-17, 07:01 PM
Kevindale
Kevindale's Avatar
Quoted: 600 Post(s)
Attachment 575066
Was the wheel turning all that time, or did you end up just stripped the anodizing off just a small section? Is the rim still usable?
Old 08-08-17, 07:08 PM
Hudson308
Mr. Anachronism
Hudson308's Avatar
Quoted: 526 Post(s)
The anodizing dissolved only on the section that was submerged. I'll likely strip it all off now, so I can still salvage the MA40 rims.
Old 08-13-17, 11:58 AM
OldsKool19
Bikes: Peugeot UO-9
Quoted: 11 Post(s)
autosol can help with the shine as well
OldsKool19 is offline
Old 08-13-17, 01:08 PM
Classtime
Classtime's Avatar
Which Autosol product would you recommend for these Cranks?
Old 08-13-17, 01:49 PM
texaspandj
texaspandj's Avatar
Quoted: 1605 Post(s)
Liked 583 Times in 380 Posts
Looks good to me.
texaspandj is offline
Old 08-13-17, 05:52 PM
OldsKool19
Bikes: Peugeot UO-9
Quoted: 11 Post(s)
Autosol Metal Polish - 100g. Tube https://www.amazon.ca/dp/B003PHLTOG/ref=cm_sw_r_cp_apa_SwoKzbAGCDMQA
Old 08-13-17, 07:15 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
"Good for now"? I wish any of my C&V Shimano cranks looked that nice!
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
eschlwc
Classic & Vintage
32
08-09-13 05:56 PM
mixtemaniac
Classic & Vintage
16
05-31-11 12:08 AM
don compton
Classic & Vintage
3
03-07-11 08:13 PM
O Rly?
Classic & Vintage
13
09-28-10 07:27 PM
JonnyHK
Framebuilders
18
05-07-10 01:32 PM
