TRP HY/RD Road Hydraulic Disc Brake Set
Ii have them.. About 10k miles of mixed road/off road in all kinds of weather and conditions. Not as good as full hydraulic but better than mechanicals. Pretty much they are there and they work out of sight and mind. I never do anything with them except bled them once and replace pads when they wear. They use a B01S or equal sized type pad.
Likes For u235:
Have them on my winter bike and they have been excellent. Minimal maintenance beyond a change of pads. A few comments:
- I think the version 2 have ‘Mineral Oil’ marked on the reservoir, but I can’t see this in the online photos. May have to check on my bike.
- As standard the callipers are set to work with Shimano 11 speed STI levers (cable pull ratio). To use with older Shimano, SRAM or Campy a modification may be needed. There are videos on how to do this, alternatively there are replacement parts from JoeJack951 (searchable on this and Weight Weenies forum). The one-time only mod takes a few minutes.
- Compressionless brake housing will assist in performance. I use Yokozuna Reaction housing and cables.
- The set up instructions can be a little confusing. Some feedback comments around lack of pad self-adjustment may indicate incorrect set up. There are videos and set up guides on the web which may be worth checking out.
Some discussion at:
https://www.bikeforums.net/road-cycl...-build-12.html
Some discussion at:
Sunshine
Quoted: 11031 Post(s)
Liked 7,578 Times
As an alternative to consider- juintech f1 calipers. These are the flatmount style. R1 are the postmount style. And there is an x1 too(not sure what that style is for).
They cost $115-150 depending on which model you buy and from where.
I have f1 calipers on my gravel bike and they work great.
Juintech is lighter than the hy/rd and smaller too.
f1 $116. https://www.ebay.com/itm/Juin-Tech-F....c100930.m5375
f1 in red for f135- https://www.ebay.com/itm/Juin-Tech-F....c100930.m5375
Likes For mstateglfr:
Quoted: 126 Post(s)
Liked 11 Times
Some discussion at:
Some discussion at:
It does says mineral oil on ebay photos, but I am still suprised why they are so cheap when the price here is double:
https://www.bike24.com/1.php?content...C%7C%7C2%7C%7C
Also some sources seem to sell with it without rotors, although your eBay source does look to be the full kit.
Good luck with the project whatever solution you go with.
Quoted: 1975 Post(s)
Liked 232 Times
I ran them before going to all hydraulic discs. I've been running road disc for ~10 years now with the full progression from mechanical BB5,BB7, Hayes, TRP Spyre, TRP Hyrd, RS685, Red HRD, R8000 and they are good middle ground when paired with modern cable pull levers, or hacked with shorter lever arms from member joejack. The original pads suck but Shimano makes a compatible organic and metallic pad and the self adjusting pistons are nice to have. Make sure you use them with compressionless housing
Quoted: 126 Post(s)
Liked 11 Times
I asked TRP Cycling Components I TEKTRO USA for a difference between versions:
The first generation HY/RD has “mineral oil” printed on the side of the reservoir facing the wheel, and the second generation has “mineral” oil on opposite side of the reservoir. Yes, HY/RD needs to be used with levers using a SLR-EV pull ratio so 11 speed and 10 speed Tiagra levers will work.
Currently I have Tektro Spyre mechanical disc brakes and I must say they are pretty good, only on long downhills I would like to have hydraulics.
Bikes: 2014 Focus Mares AX 2.0, 2019 Cube Litening C:62 Race Disc Teamline
Quoted: 121 Post(s)
Liked 140 Times
I ran them up until recently since 2014. I had no end of piston related problems. Ended up swapping for Spyres and even though they are full mechanical, i like them more.
Quoted: 20810 Post(s)
Liked 9,456 Times
How much are the TRPs? You can get 105 levers and calipers for ~$260 at Merlin, 505s for closer to $200.
make sure your frame allows for cable actuated disk, my internal routed frame is designed for hydraulic, the bends at the chainstay was too sharp for cable
