Just Got a 4iiii Power Meter. Do I need my Cadence Sensor?
Old 01-13-20, 05:24 PM
illjustride
illjustride's Avatar
Bikes: Trek Emoda, Surly Ogre
Quoted: 68 Post(s)
Liked 59 Times in 31 Posts
Hi everyone. New here. Psyched to join and spread knowledge in cycling and learn along the way. I just bought a 4iiii Ultegra power meter for my bike. I'm wondering if I need the cadence sensor attached from my old arm on the new arm as I heard that they also have a cadence sensor build in. Just wanted to clarify and ask if anyone can help with this.
illjustride is offline
Old 01-13-20, 06:00 PM
saverin
Quoted: 14 Post(s)
Liked 4 Times in 2 Posts
No. Power meter will provide cadence. You can search for a cadence sensor on a head-unit and the same ANT ID will show up for both power and cadence.
saverin is offline
Likes For saverin:
Old 01-13-20, 06:34 PM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 18883 Post(s)
Liked 10,646 Times in 6,054 Posts
To determine power at the crank arm, it needs to know how hard you're pressing and how fast you're turning the pedals over. And PMs all promise somewhere in the ballpark of 2% maximum error, which they can't achieve by relying on an external cadence sensor, so they have their own.
Not all PMs have a cadence sensor because if you measure at the hub, you don't need cadence. But yours does.
Seattle Forrest is offline
Old 01-14-20, 10:42 AM
NoWhammies
NoWhammies's Avatar
Quoted: 800 Post(s)
Liked 512 Times in 306 Posts
Welcome to the forums! I have a 4iiii PM as well. Great device. Can't speak highly enough about the unit (even if the L/R issue has yet to be sorted via a software update). I had the same question as you when I installed my PM. The good news? No need for a cadence sensor. The PM will handle that for you. As @saverin mentioned, you just need to bring the field up on your bike computer. Cheers.
NoWhammies is offline
Old 02-28-21, 10:19 AM
Bofferdinger
Cadence to Garmin, how?
Hi,
I get the power to my Garmin but I’m not able to get the cadence. The ANT ID shows up on power but not cadence.
Would love to solve this so that I can remove my Garmin cadence meter.
Thanks
Bofferdinger is offline
Old 02-28-21, 10:43 AM
colnago62
Quoted: 741 Post(s)
Liked 412 Times in 230 Posts
Originally Posted by Bofferdinger
Hi,
Thanks
Have you tried riding yet? I have a garmin I use with an SRM and I think once power was connected, the unit automatically found the cadence data.
colnago62 is offline
Old 02-28-21, 11:56 AM
Bofferdinger
Hi,
Thanks for your response.
Yes, I have and it didn’t show up on the head unit but did appear when I transferred to Garmin Connect and Strava.
Old 02-28-21, 01:59 PM
WhyFi
WhyFi's Avatar
Quoted: 20791 Post(s)
Liked 9,436 Times in 4,663 Posts
Hi,
Did you add the cadence field to your screen?
WhyFi is offline
Old 02-28-21, 02:33 PM
Bofferdinger
Yes, and there is no problem getting it on the head unit when the Garmin cadence meter is paired.
Old 02-28-21, 02:39 PM
tomato coupe
Quoted: 3936 Post(s)
Liked 7,256 Times in 2,935 Posts
PowerTap hubs give you cadence.
tomato coupe is offline
Old 02-28-21, 02:42 PM
woodcraft
woodcraft's Avatar
Quoted: 1814 Post(s)
Liked 923 Times in 569 Posts
Un-pair/re-pair often helps. Remove & un-pair the Garmin cadence sensor as maybe it is getting in the way?
woodcraft is offline
Likes For woodcraft:
Old 02-28-21, 03:21 PM
Bofferdinger
Garmin cadence meter is unpaired. I have tried it with the 4iiii as well but will give it another try.
Thanks
Old 02-28-21, 03:37 PM
Bofferdinger
Did a full reset of the Garmin (which obviously unpaired everything) and it still did not pick up the cadence meter when I searched for it. However, it now relays the cadence info to the head unit. 🤷‍♂️
I guess all info is relayed through the power meter connection/pairing and all it took was a full reset of the Garmin for it to work somehow.
The old “Have you tried Alt-Ctrl-Delete?”.
Thanks for all answers.
Thanks
Old 02-28-21, 04:15 PM
Iride01
Iride01's Avatar
Quoted: 6163 Post(s)
Liked 4,780 Times in 3,298 Posts
Any time Garmin's give you a strange or what you think is strange issue, then do a reset. I've known some people with other types of Garmin devices that do a reset every time they do an update. Knock wood, I haven't had to but just a few times.
Iride01 is online now
Likes For Iride01:
Old 02-28-21, 04:27 PM
rubiksoval
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times in 711 Posts
Powertaps measure cadence, too.
rubiksoval is offline
Old 02-28-21, 06:43 PM
WhyFi
WhyFi's Avatar
They don't connect as separate devices. At least, mine doesn't (crankset), and neither does yours, it seems.
WhyFi is offline
Likes For WhyFi:
Old 03-02-21, 07:27 AM
colnago62
Quoted: 741 Post(s)
Mine doesn’t either.
Likes For colnago62:
