Need help building bike.
What's up guys I'm trying to build my DeRosa road bike. I just need some help deciding what parts to use. I guess I'm looking for modern parts on this bike if possible. Any recommendations is much appreciated. As far as how much I'm willing to spend is something good, sturdy, just not too fancy.
THE SPECS:
The frame size is 58cm c to c and the top tube is 58cm c to c.
Head tube is 6 3/8".
The steerer tube threading is English/ISO/Italian (25.4mm x 24TPI).
Back spacing is 126mm.
BB threading is 36 x 24 Italian and has been faced and chased.
Thanks for the help!
THE SPECS:
The seat post diameter is 27.2mm.
Quoted: 5887 Post(s)
Liked 3,469 Times
If you want a modern build, you'll likely want to spread that frame to 128 so it can take a 130 mm rear wheel. Other than that any campy silver group would look good on that bike.
Likes For bikemig:
Habitual User
Quoted: 4925 Post(s)
Liked 8,039 Times
How modern? Is just integrated shift/brake levers enough, or are you looking to go to electronic shifting? If it's just integrated levers, how many speeds?
Likes For Eric F:
Habitual User
Liked 8,039 Times
Is this a go-fast bike, or something a little more relaxed? You will need to think about gearing, which will be largely based on the kind of riding you will be doing. What range cassette will you want? Double or triple chainrings? These choices will affect lever and derailleur choices. Are you intending to build the bike with just one make/model of components (as much as possible), or are you okay with a mixture of stuff? Wheels? Tires?
Budget will be the big determining factor.
Personally, I could see building an older DeRosa frame with 10-speed Campy Record, and some medium-profile wheels.
Likes For Eric F:
These are questions only you can answer - LOL.
Ok so the only thing I really wanted on the bike was a set of HED jet 9 rims. So yes maybe a little more on the faster side than casual. And I don't mind having mixed parts. I ride more on the fixie/track side of things that's why I'm not too sure.
I currently have a Cinelli mash with a Rear fixed Enve wheel, rotor cranks, front spin mtb trispoke with some raceface longbars.
Habitual User
Liked 8,039 Times
Quoted: 1946 Post(s)
Liked 2,004 Times
A picture of your frame would help. At one time my 82 Medici was my go fast bike and I had it spread to 130 and had a full Ultegra 6700 on it. It was awesome. If I were you and had a few bucks, I'd go 6800 with your Heds, carbon 3T cockpit and seat post.
Likes For Classtime:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Photo of the frame
would permit two big forks in the road to be chosen: black versus silver; Campy versus non-campy. The rest is just details.
OP, are you building your own wheels, so...hubs to match the chosen groupset?
Likes For Phil_gretz:
Bikes: 1973 Colnago Super, Litespeed Classic , Automoto , Pinarello Gavia TSX,Eddy Merckx Corsa Extra,Eddy Merckx EMX-5 , 1982 Moser SL, Concorde TSX, Vitus 979 KAS. Diamant SLX,60's Meteor
Quoted: 235 Post(s)
Liked 947 Times
Your biggest concern is getting a rear hub to match your freewheel/rear deraileur choice. Its either a Campagnolo or Shimano,They are not interchangeable so if your wheel hubs are already set up for Shimano your stuck with Shimano, and vice versa.
Unless you area able to swap out the Freehub Spline , which some older wheel hubs are not able to.
Once you figure out what hub Manufacturer your going to use, Lets say Campagnolo,,,you can buy something like this..
.https://www.ebay.com/itm/Vintage-90s...MAAOSwD0deTAoh
Likes For Manny66:
Bikes: Numerous
Quoted: 1676 Post(s)
Liked 3,084 Times
I put 8 speed Campagnolo on my ‘86 De Rosa. The rear hub is 128 mm so it plays nicely on a the 126 mm frame. It’s not a huge problem putting 130 mm hubs on a steel 126 mm frame IMO, but if you’re set on running modern 11 speed, I’d recommend getting the frame cold set to 130 mm.
Dont be tempted to “upgrade” to carbon fork. Keep the threaded steel with a quill stem. I think threadless stems are unattractive on bikes like these. There is a difference between English and Italian threading on the fork but it is minimal and many people consider the standards (for forks, not other stuff!) interchangeable. Italian is labeled, I think 25.4 x 24, and English 1 x 24. Thumbs up for keeping classic steel on the road!
Quoted: 567 Post(s)
Liked 562 Times
You are in LA so not a lot of climbing? What do you ride on your Vigorelli and Mash, and what do you like or find missing on those groups, wheels, saddles, bars, etc.? A picture would help, some frames look good with modern black groups other not so much.
Likes For easyupbug:
it all depends. Since I was thinking of Hed rims I thought of having them build them for me. I believe campy is the only thing that fits on this frame but then again I'm not entirely sure.
Liked 2,004 Times
Very cool frameset.
i think the Heds only come as complete wheels
and you choose Shimano or Campy.
Campy, Shimano, or SRAM will fit equally well. For a first road bike, I recommend very race worthy Ultegra. Shimano is very robust/flexible with other manufacturers. Campy not so much. Campy is Fancy.
Quoted: 1372 Post(s)
Liked 1,747 Times
Were the frame mine, a matched Campagnolo group would be the only way to go. There are several groups on Ebay right now, some with stupid prices, some with close to acceptable. Anyway, a nice looking and wonderful working group on my long gone Cyclops...
Likes For randyjawa:
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Or search locally for a donor bike with the group you want. Sell the frame when you are done.
All of my builds have started with finding a donor bike. Sometimes you can find a deal so good that the proceeds from the sale of the frame can cover the cost of the entire bike. At that point, other than your time, the upgrade is free. I've got several personal builds, and that is the case of all of them. But I am very patient, and I am flexible on the group.
Likes For wrk101:
Liked 2,004 Times
This is modern. 700 bucks for Ultegra R8000 which would look great with your Heds.
Habitual User
Liked 8,039 Times
Just curious...Where did you get that idea? Lots of climbing is available in the LA area, if that's what you're looking for.
Quoted: 567 Post(s)
Liked 562 Times
I did not notice you were from Altadena where you would have some climbs, all my time was Long Beach where it was a haul to any real climbs.
