Help! Narrow axle- no QR fits!
The Drive Side is Within
Help! Narrow axle aperture - no QR fits!
Help! Where can I source a basic 126mm skewer that is slightly thinner than usual? Maybe threaded along the entire length?
I have a set of wheels with an oddly narrow axle. The skewers will insert only as far as the threads.
They’re unused (now I know why!) and soon as new so I don’t want to replace the axle and re adjust everything.
Can anyone point me in the right direction?
Randomhead
Liked 3,696 Times
any branding on the hub?
Likes For unterhausen:
Quoted: 1106 Post(s)
Liked 1,327 Times
Skewers are narrow enough as it is, so my advice is no matter what don't try machining one down.
Likes For oneclick:
Likes For Narhay:
Quoted: 2363 Post(s)
Liked 1,749 Times
^^^^^^ +1, check for bent axle. See what happens when you try to insert the skewer into the other end of the axle.
Likes For madpogue:
Quoted: 355 Post(s)
Liked 345 Times
Can you see all the way through the axle? Can you put a small rod through it? Might it have debris inside? If the axle is bent, it is already stressed and may break. Something not right here. But may be best to replace the axle with known good axle. An all threaded skewer shaft may be a bit weaker overall.
Likes For mech986:
Liked 1,327 Times
I have never seen a skewer that was threaded more than just enough for the nut - and if I had one, I'd swap it out for one that wasn't.
A broken skewer usually results in other broken things.
Likes For oneclick:
Liked 1,327 Times
If they're bent, they'll likely be bent at one end - he said the skewer goes in as far as the threads. He should try putting the skewer in from the other side; if it the axle is bent, the skewer will still stop, but farther in. He should be able to eyeball the skewer for straightness.
Likes For oneclick:
Likes For Narhay:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3886 Post(s)
Liked 6,482 Times
Assuming nothing is bent and the threaded portion of the skewer will insert, you could (in theory) file the remaining portion of the skewer to fit.
What's unused and "soon as new"?
They’re unused ... and soon as new.
Autocorrect obviously.
Thanks for the suggestions everyone. I did run it from the other side (was CERTAIN I had tried that, ha) and it worked. Looks like the issue is not a bent axle, but a burr on the inside of the non drive end of the axle. I’ll ream it out and see if that works.
cheers.
these four little marks seem to be part of the problem. They caused the axle to burr in a little bit.
Can’t tell y’all how many runs down to the basement wheel
storage room for different skewers I took on Sunday morning!
cheers.
The bicycle, the bicycle surely, should always be the vehicle of novelists and poets. Christopher Morley
Likes For Standalone:
