Need a wheelset recommendation for Trek Domane
Quoted: 10 Post(s)
Liked 9 Times
I have a 2019 Trek Domane SL5 that I really like, but after swapping out the groupset and getting new wheels on my old 2005 Allez Elite, I have realized how heavy the Domane feels. They are about 1.5lbs apart in weight, but even before I fixed up the Allez Elite, I felt the Domane was a little heavy. Well, it IS a bit on the heavy side, and that's fine, but before I'm ready to decide that I just need a lighter bike, I'd like to move to something other than the stock wheels and tires(2100+ grams wheels, 32mm tires). I'm going to switch to 25mm Continental GP 5000's with tubes, but need a wheelset recommendation. I'm not racing, so nothing over about the $1500 mark. It seems the obvious choice is the Aeolus Pro 37's, but wanted to see if anyone has another strong opinion here. Thanks!!!
Quoted: 20808 Post(s)
Liked 9,450 Times
Those new Aeolus wheelsets do look pretty nice in terms of features and value - if you're not completely sold on tubeless and you're a Trek rider, to boot, they'd be at the pointy end of my list. (I was in a similar position a few months back and ended up with the Zipp 303S, but I've been running tubeless for years and was comfortable with the commitment to continue to do so.)
Quoted: 4717 Post(s)
Liked 1,882 Times
Those Bontrager wheels are pretty nice with a very nice warranty, but you could get slightly lighter wheels for less money. Light Bicycle has a very similar wheelset available, for about $400 less.
https://www.lightbicycle.com/site/share-cart?id=2036
There's a long thread about LB here https://www.bikeforums.net/road-cycl...le-wheels.html
Bikes: Trek Emonda SL6 .... Miyata One Thousand
Quoted: 63 Post(s)
Liked 29 Times
I opted for HED Belgium Plus rims with Chris King R45 hubs .... weight is approx 1639g .... these are bombproof with excellent hubs, are tubeless ready and have the same aerodynamics as Flo30
Bontrager Aeolus Pro 37 weigh 1505g
Likes For dim:
Pizzaiolo Americano
I got a set of the Aeolus Pro 3V for my Domane. They are decently light (1575g) and are nice and wide. I am loving them so far. The best part is I only paid 1050.00 for them new. Great value in my opinion.
Likes For Pizzaiolo Americano:
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 266 Post(s)
Liked 447 Times
I’ve had a set of non V 5s for a couple of years. I run then with tubes but they come with the tubeless stuff. Good wheels and look cool. They at 19mm inside width so a stretch for my old Madone. But with the Domane you won’t have any problems.
I'd consider the HED Jet 6/9+ combination from mybikeshop.com. 60mm front and 90 mm rear. Lighter than what you have and waaaaay more aero. I emphasize aero over than weight, but this set would be better in both regards.
Or a set of Flo carbon wheels. Use the code PODCAST for 20% off. I just ordered a set of their 64 mm / 77 mm for my wife's 2020 Domane SL5.
Quoted: 325 Post(s)
Liked 109 Times
Just get some Fernwegs and put some Gatorskins on them. You'll be light, fast, great grip, and protected from flats. Done and done.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4365 Post(s)
Liked 3,001 Times
Fernwegs for a $1500 price point? This is like a troll with reading comprehension problems. As to the Gatorskin part, that's causing enough laughter over at the other thread. no need for duplication here.
Likes For MinnMan:
Pointy Helmet Tribe
Bikes: R5, Allez Sprint, Shiv
Quoted: 519 Post(s)
Liked 627 Times
I suspect he is deliberately trolling us. The earlier thread made me wonder - this has given it away.
Likes For guadzilla:
I personally was thinking about going with the Zip 303 S on my Domane https://www.sram.com/en/zipp/models/wh-303-stld-a1
Liked 9,450 Times
Likes For WhyFi:
Quoted: 10 Post(s)
Liked 9 Times
Thanks everyone! I'm going to go with the Aeolus Pro 37's, more out of convenience than anything because I can get them when I pick up my Domane from the shop, but also because their warranty is solid too. You all opened my eyes a bit to some of the options I hadn't considered though - those LIght Bicycle wheels look like a steal! I also considered those Zipp's, but they're less available. Should be quite a difference from what I understand - first carbon wheels!
Likes For SeattleRider57:
Reynolds AR58x or AR41x. Lifetime warranty, good hubs.
www.mp-aviation.com
www.mp-aviation.com
Liked 3,001 Times
I was late to the carbon wheel party, but I'm totally sold now.
Bikes: Trek Domane SL7 Disc, Cannondale F29
Quoted: 385 Post(s)
Liked 322 Times
SeattleRider57 Is your bike a disc or rim brake version?
I highly recommend going with a 25mm wide rim, like the Aeolus Pro 3Vs, if you're running disc brakes. If not, so sorry...
As mentioned already, you can get a much lighter, much less expensive, and extremely high quality wheelset with way better specs than the 3V from Light Bicycle... which I did. My LB WR50 wheels are considerably lighter than the Pro 3Vs that came on my 2020 Domane SL7 and are deeper (50mm vs 35mm): Dear Diary: My 2020 Trek Domane SL7 Must Go on a Diet
Likes For PoorInRichfield:
I have been riding the Aeolus Pro 37 this summer and they have been great for the money. I also have a set of LB WR38 and yes they are lighter and better in my opinion but more money for the specs I got.
Liked 3,001 Times
I bought a set of Roval CL50’s for my Tcr. I can’t say enough good things about them, fast, light, and smooth. I bought them on black Friday when my lbs has 25% off so I paid 1250 for them.
Liked 1,882 Times
A freshly greased 18t is very quiet, and a 54t with very little grease will be very loud.
