27 inch wheels - how come?
Cyclists who’ve kept your c&o rides with 27inch wheels (either original steel or aluminum) how come you’ve chosen to go that route rather than swap in 700c?
Quoted: 796 Post(s)
Liked 522 Times
They work just fine and there are plenty of tire options - there is a whole thread on them - so I will turn the question around why switch? The only reason I really see is to get a bigger tire and even then you may have issues with brake fit so for me its what are you really gaining after spending $$$ on new wheels and possibly brakes ?
Likes For biggs682:
Quoted: 702 Post(s)
Liked 671 Times
I have several older bikes that require brakes with long reaches, 700C rims are slightly smaller in diameter than 27" so the brakes will not reach them. Not only that, rims don't go bad unless abused so I don't see the point of changing them unless there were absolutely no tires available to fit. As long as there are 27" tires, I will keep my 27" rims.
Likes For branko_76:
Quoted: 2362 Post(s)
Liked 1,747 Times
Why? Um, wheels aren't free.
Likes For madpogue:
Quoted: 767 Post(s)
Liked 1,898 Times
Doesn't really matter much either way. I've done the 27 to 700 swap, and motivation was broader tire options. Brake reach can get iffy, but not always.
I built my '73 Super Course into a 3 speed using the original Weinmann 27" wheels - laced an AW to the rear rim. The bike had very, very low mileage on it. Rims in great shape - might as well use them. No real downside as I can get nice tires in 27, and as a 3 speed there's no intention on it being a go fast machine.
My smile is just as wide whether on 27" or 700.
Likes For BFisher:
Shifting is fun!
Bikes: Yes, please.
Quoted: 2193 Post(s)
Liked 4,587 Times
I ride large bikes and their proportions just look that little bit better with the the larger wheels.
Lol that is indeed the truth! Had to replace my rear steel wheel with polished aluminum. Figured I’d stay at 27 so I wouldn’t need to buy two wheels at once - front wheel was mismatched and figured this way I could buy one fancy VO wheel for the rear and save up to get a matching front wheel later. Figured I’d just as soon not deal with the whole conversion issue.
Also, something about keeping the bike at its original specs and geometry appealed to me. Don’t know how much that matters or if it’s more just my goofy sense of sentimentality for the bike as a piece of history. Ride feel, stand over height, and aesthetics/proportions, etc. all felt great as-is and I wouldn’t have to deal with any unforeseen conversion complications.
Now that I’m looking into different tire options I’m thinking 700c might’ve been nice but buying another rear wheel just to have 700c feels like a waste. I think I’ll just switch to Pasela skinwall tires and be done with it.
Likes For Bicicletta89:
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I am waiting until they come back in style. After the marketing hype machine gets through with them they will be called “30er” and they will be hot
Likes For trailmix:
Quoted: 3804 Post(s)
Liked 6,643 Times
The options in 27” tires are far fewer than in 700c, and none is as good. For a bike that’s going to do more than be a weekend cafe rider or go to the occasional vintage bike show, 27” wheels just don’t cut it for me.
Bikes: Raleigh Classic 15, 84; Miyata 912, 85; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 159 Post(s)
Liked 133 Times
Because they're there.
Likes For John Nolan:
Here in bike-happy Washington, D.C., a massive percentage of the bikes on the road are vintage, and most of those are being used by young people about my age (I'm 31) who seem to be taking very good care of them.
I also wonder if the massive demand for bikes during the pandemic has likely forced a lot of previously idle vintage bikes back into circulation, a good opportunity for even more people to rediscover them
Extraordinary Magnitude
Quoted: 2607 Post(s)
Liked 1,696 Times
I've switched one bike FROM 700c TO 27" to work with a set of brakes I really wanted on a build.
I've switched one bike from 27 to 700c- and I really like it. I'm in the process of doing that with another bike- in both cases, it's for the wider/more plush tires.
In reality- the choice for 27" tires is really small, and the choice for plush tires is really, really small. If there is any choice at all... I haven't used the light casing Swift/Sand Canyon tire- if they even exist anymore...
Commence to jigglin’ huh?!?!
Ride, Wrench, Swap, Race
Quoted: 1562 Post(s)
Liked 1,288 Times
Some bikes, like the Schwinn Varsity and Continental, have particularly high bottom brackets, which is compounded by slack frame geometry that reduces the frame's forward reach by several centimeters. The rider thus my prefer the reach of a larger frame size, but then have problems with the standover height. This unusual instance begs for the use of small-diameter wheels (to the extent that 4mm matters).
Another consideration is the leverage of the braking system. A 4mm smaller-radius rim will reduce the leverage on a bike with caliper brakes, but will increase the leverage on a bike with cantilever brakes. This difference is noticeable, as the 4mm is around 10% of the arm length in many cases (the vertical distance from the pivot to the rim).
A 27" wheeled bike may look different and have a lower bb (and thus balance differently on a kickstand) with smaller-diameter wheels unless the tires are made plumper to restore the OD of the 700c tire.
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
I’ve got an MTB, and a ‘modern’ 700-wheeled ‘fast’ bike, so 27x1-1/4” (32mm) suits the bill for townie / path-bike use just fine.
My ‘76 Bridgestone had nice, straight aluminum Araya rims and high flange hubs that just needed fresh grease, so I’m fine running on 27’s.
Quoted: 630 Post(s)
Liked 1,264 Times
If the 27" wheels are good I keep them, if they aren't and I don't have any good 27's then I go 700 but so far I've had plenty of good 27's when I needed them.
Likes For Murray Missile:
Quoted: 360 Post(s)
Liked 323 Times
I have a perfectly good set of 27" wheels that are original to my Schwinn Voyageur. However, I also had a set of perfectly good 120mm rear spaced 700c wheels that would allow me to use wider tires on the Voyageur. Since I had the 27" wheels already, I figured what the heck and put the 27" wheels on my 68 Super Course which is set up to be an upright ride.They work just fine.
Andy
Andy
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3870 Post(s)
Liked 6,461 Times
27 inch wheels, how come?
How come you don't love me like you used to do?
How come?
How come I replaced you before I learned to love you?
Did I ever love you?
Why'd I ever leave you?
How come?
How come?
How come?
How come?
How come?
How come?
How come?
Likes For SurferRosa:
It is as if someone asked Leonard Cohen about wheel sizing.
Likes For trailmix:
Quoted: 796 Post(s)
Liked 522 Times
Quoted: 796 Post(s)
Liked 522 Times
I've been wondering about this too...Saw some old posts on Velo Orange's site from a while back by folks unhappy that they weren't selling 27" wheels. Now they're selling the new swanky 27" weels that I got for my rear wheel replacement.
Likes For ryansu:
