The Raliegh
Old 12-30-20, 05:51 PM
Rexirae
The Raliegh
Hi, I'm new so if I am posting to the wrong place please have mercy.
i have recently come into possession of a bike frame and forks that appear to be quite old and the metal plate on the neck identifies it as The Raliegh.
it also has Raliegh cranks and handlebars.
can someone tell me something about this bike?
( I before e except after c right ? Lol )
Rexirae is offline
Old 12-30-20, 06:24 PM
Murray Missile
Murray Missile's Avatar
Quoted: 637 Post(s)
Liked 1,281 Times in 609 Posts
We'll need pictures which you can't post until you have 10 posts. In the meantime you can put them in an album here and one of the more savvy members can share then for you. I've never done it myself. If there's anything left of it somebody here should be able to give you a positive ID. If these guys can't, nobody can.
Murray Missile is offline
Old 12-30-20, 06:27 PM
Kilroy1988
Kilroy1988's Avatar
Quoted: 981 Post(s)
Liked 1,844 Times in 609 Posts
The frame is probably from between 1890-1980, most likely painted black, and used to have two wheels.
Kilroy1988 is offline
Likes For Kilroy1988:
Old 12-30-20, 06:36 PM
steelbikeguy
steelbikeguy's Avatar
Quoted: 1829 Post(s)
Liked 3,375 Times in 1,580 Posts
any chance that you can tell us the color(s) of the frame?
names or words on any of the components?
Serial number? maybe under the bottom bracket (i.e. the part of the frame where the crank bearings are).
these would certainly help.
Steve in Peoria
steelbikeguy is offline
Old 12-30-20, 06:39 PM
Kilroy1988
Kilroy1988's Avatar
Quoted: 981 Post(s)
On a serious note, if you begin doing any research yourself, please be aware that it is spelled "Raleigh" rather than "Raliegh" as you have written it in the title and your first post.
Depending on the year, Raleigh was one of the largest or else the very largest manufacturer of bicycles in Britain for nearly a century. There are hundreds of Raleigh bicycle models ranging all types of uses, that obviously changed dramatically in form and function as technology progressed over time. Your best bet for getting fast results from us is to provide photos, so you should either continue posting or else make an album, as mentioned by others above.
Cheers, and welcome to Bikeforums!
-Gregory
Old 12-30-20, 07:18 PM
Insidious C.
Quoted: 463 Post(s)
Liked 336 Times in 213 Posts
There is a good chance you can identify your Raleigh from the catalogs here.
I.C.
Insidious C. is offline
Old 12-31-20, 05:26 PM
Rexirae
Album created
It is titled -
The Rally -
Lol
Thanks all for taking the time to respond, all are appreciated"(.g album 20167177 )"
Rexirae is offline
Old 12-31-20, 06:50 PM
Murray Missile
Quoted: 637 Post(s)
It's hard to tell from the pictures, we really need to see the whole frame but from the original color, head badge, chrome cable stop for center pull brakes and crankset I'm leaning toward the mortal remains of a 1979 Asian built Super Grand Prix. It may have looked similar to this one when new.
Old 01-01-21, 04:55 AM
barnfind
Quoted: 58 Post(s)
Liked 49 Times in 31 Posts
The late 70's Super Grand Prix was basically the same as a Super Course with a plain steel frame and a lesser set of derailleurs.
I still own my original 1978 model, which looks like the one pictured above, mine says Made in England on it yet. I think they went Asian after 1979. What always surprised me was how close the SGP and same year Super Coarse were in weight, only a few ounces different overall when comparing two 25.5" frame bikes. Personally, I always thought the SGP was the sleeper in that line up, it sold for a good bit less than the SC and rode very much the same. Mine came with a padded leather saddle, Suntour VGT derailleurs, and Weinmann concave rims with high flange Normandy hubs. The SC got low flange Atom hubs. Both have standard 68mm bottom brackets.
barnfind is offline
Old 01-01-21, 07:43 AM
CO_Hoya
Señor Member
Quoted: 284 Post(s)
Liked 297 Times in 150 Posts
Pic assist
Agree with above that a picture of the whole bike from the drive side would be most helpful.
CO_Hoya is offline
Old 01-01-21, 07:52 PM
Murray Missile
Quoted: 637 Post(s)
I think you're right, I was of the understanding the head badge with the hash marks at the bottom indicated an Asian built bike, I don't know for sure though. I think 1980 was when production started getting sent to Japan and Taiwan. The details visible were consistent with a couple 79 Super GP's I found pictures of but I've since come across pictures of later lower end models with that crankset, approximate color and center pulls. The ridge on the top of the fork crown has me thinking it' a lower end model. The SN didn't show up on any lists I could make sense of. His best bet is probably to see what's under the rattle can paint job.
Old 01-02-21, 07:40 AM
repechage
Quoted: 3464 Post(s)
Liked 2,829 Times in 1,995 Posts
Yes, Asian subcontracted.
they assembled better but were a bit deflating.
one knew the end was to come.
the early Asian bikes were called Rampar
A branding used for bikes and accessories early on in the 70’s.
the Rampar bikes started out as replacements for the Record. A bike that’s spec was falling fast behind others in its price point.
repechage is offline
Likes For repechage:
Old 01-05-21, 07:31 AM
tjfastback66
tjfastback66's Avatar
Bikes: a few
Quoted: 92 Post(s)
Liked 379 Times in 144 Posts
Hello All,
From the blue color of the headtube this appears to be a Raleigh Record. I sold many of these similar bikes in the early 1980's. If you look at the link and go to the 1983 Raleigh catalog see the Raleigh Record. Not so sure about "The Raleigh" badge however.
I hope that helps!
tjfastback66 is offline
Old 01-20-21, 08:09 PM
Hummer
Hummer's Avatar
Bikes: 1981 Raleigh GP, 1985 Norco Bush Pilot, . . .
Quoted: 241 Post(s)
Liked 187 Times in 136 Posts
Hello @Rexirae,
welcome to the forums.
Your Raleigh frame was manufactured in 1981 by Matsush¡ta/National of Japan.
The 1981 Raleigh Gran Sport model had a dark blue colour, with a lighter blue head tube.
Hummer is offline
