Wrap top to bottom or the reverse?
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
Before you roll your eyes, and type a heated response about my parentage give me a minute.
Cloth bar tape is top to bottom, modern is bottom to top for obvious reasons. Last night I ordered some Newbaums padded cloth bar tape which seems like it might me in-between, for those that have used the padded cloth do you wrap traditional or modern?
Quoted: 1951 Post(s)
Liked 2,013 Times
Cloth bar tape is not top to bottom according to my tradition. What is obvious to you is not obvious to me. And padded cloth is not traditional in any sense -- so whatever.
I am usually pulling down at the drops and out to the sides rather than toward the middle. To this end, to stop the tape edges from furling upward I always wrap bottom to top.
Likes For Narhay:
Quoted: 211 Post(s)
Liked 199 Times
Bottom to top is what I do.
In the 70s it was top to bottom. But it was with pretty thin bar tape. With the excess that could be pushed inside the bottom tube with the silver end piece
I use padded tape now
Love and need the cushion 🚲🚲🚲🚲🚲🚲
Likes For bikemike73:
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
Quoted: 1608 Post(s)
Liked 2,216 Times
Lots of bar wrapping direction police but no law. You have the freedom to do what you want and accept full responsibility for your choice to you only. Be happy and enjoy the ride! Oh you are in Southern Germany I spent a year near there across the boarder in Austria. What is the tradition in that neck of the woods? Which way to \they wrap the alpen horns, bell to mouth or mouth to bell?
Likes For SJX426:
I've done both but usually bottom to top finished with twine. I've actually started top and bottom when doing a harlequin design with two colors top and bottom and solid around the brakes tucking (and taping) the ends under the hoods. May not last as long (I'm easy on the bars) but it looks cool.
Before the police chime in, I've since moved the brake housings behind the bars. (although I can't say it's better)
Likes For IsleRide:
Quoted: 4806 Post(s)
Liked 3,931 Times
+1 I never studied my grip but I do know my tape lasts far longer if I go from the bottom. I still wear out cloth tape from the heels of my palms, but it is wearing right through the fabric, not peeling back the edge,
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,801 Times
When Benotto was the tape of choice when I worked at a bike shop, we always started at the top and shoved whatever was left into the bars and capped them off. That works for thin tape.
Thicker tape doesn't work well that way, so I started at the bottom and finished off at the top with tape. At some point the tape would start to unfurl. A buddy of mine was doing the
, so I started doing that. Twine has come undone for me, so I started shellacing, which locks everything in place, and it doesn't matter which way you roll from. It's the most labor intensive way to wrap a bar (leaving out the cool harlequin finish as shown above), but it's been the most durable for me.
I can't remember if I've ever done the "start from both ends and meet under the brake leve hood" method and leave off the shellac as a test. I should try that on my next bike. It would seem that the trick there is to make sure the wrap is very tight on the top so your hands won't unwind it.
I've taken to double wrapping my bars. Last round's cloth goes underneath. Since it is held in place by the next later, it doesn't need to be continuous so I just cout out the bad sections. I am going to try a first wrap if innertube strip next time. (This aging stuff sucks but I'll take it over the alternatives.)
Liked 3,931 Times
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
i've tried inner tube wrapping on a friend's bike (he was in his 70's). i found it hard stretch or even get it to look good without bumps where it overlapped. double cork tape was easier and looked "normal"
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
There's a tube under that tape..no bumps
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,601 Times
I am not acquainted with that particular Newbaum tape, but, FWIW, my findings are that top to bottom works well as long as the tape isn't too stretchy. With thicker tape, you'll need different caps to deal with that. They usually come with the tape.
If the tape is stretchy, it'll work loose if you wrap top to bottom, and the other way around works better. You will have to learn to live with finishing tape, though ...
A couple of examples. What happened when I wrapped thin stretchy tape top to bottom. It worked loose:
What happened to thick, padded non-stretchy tape wrapped top to bottom. Nothing:
RUSA #3100
Bikes: Yes
Quoted: 237 Post(s)
Liked 505 Times
I am waiting for "rules for bar tape" or the "taping orthodoxy" posts to start.
Edit: I'm also wondering, if you do it "wrong" and it works just fine, is it still wrong?
https://utahrandonneur.wordpress.com
Likes For Oldairhead:
Quoted: 1372 Post(s)
Liked 1,752 Times
For cushion tape, I always wrap end to center...
For most cloth tape installation, I wrap center to end...
However, when using these Gaslo end caps on my sixties Torpado, I will wrap from end to center (gotta do it that way to hold the cap in place)...
The Galso end caps have four tabs each that fit on the outside of the handlebar ends...
The same goes for cloth tape and Barcons, end to center...
Quoted: 838 Post(s)
Liked 1,082 Times
My go to is Newbaums regular cloth: Top to bottom with no tape or twine (not needed with this)
I ordered their new padded tape thinking it would be the same, but it gave me ridges, so I did bottom to top instead. I think it's just a little too thick to do top to bottom and look clean imo.
Then I decided it was too thick looking for me anyways and got rid of it.
Quoted: 1591 Post(s)
Liked 1,020 Times
I've only recently learned there are rules. I've always gone bottom to top because that's what I've always done.
And if you use an Italian Road Bike mirror it seems like it would be harder to install going the other way.
Liked 5,801 Times
I'm wondering what the Velominati say on the subject...
225mm isn't long enough? wow. do you use riser/dirt drop style quills, then?
With careful placement I think you could avoid uneven bumps.
Anyway, with age, (72) I've given up the race posture but not drop bars. A higher bar means I don't need as much (or any) cushion. I like the feel of tight cloth on the bar.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
On the real, tape however you want! When I last did Newbaums it was drops to center but that wasn't padded just harlequin wrapped before we figured out we needed 4 rolls total to do a 3 color wrap but it still came out nice though my side wasn't so good but for a first effort and being super nervous it turned out ok.
Expired Member
Quoted: 3674 Post(s)
Liked 5,437 Times
OP, I get what you are asking. I think that since it will appear to be traditional cloth tape, you should first try wrapping it in the traditional method, top to bottom. If it's too thick to cleanly tuck the end, wrap it the modern way and maybe some twine.
Quoted: 4560 Post(s)
Liked 2,802 Times
Both. Either. Depends on the bar wrap and whim. If I want to skip the look of tape, top to bottom and secure the ends with the bar end plug. Haven't encountered any problems with unraveling, peeling or the feel of the wrap when done carefully with the appropriate bar wrap.
Liked 3,931 Times
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
I know Nitto calls the 225mm "length" but I call it "height". Length to me is either horizontal distance from center of bar to top of stem/centerline intersection (traditional Cinelli, etc.) or center of bar along the stem centerline to the steerer centerline (threadless stems). Those "225mm" stems don't come longer than 130mm horizontal. I have just two bikes that work with 130s. The rest are up to radically longer (along the horizontal).
