Quick Bike Repair
Bikes: Bianchi Brava 1986-1987
Quoted: 14 Post(s)
Quick Bike Repair
What are the critical things that one must carry in order to do quick repairs mid ride?
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Tools.
Likes For Cyclist0108:
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
This is interestingly phrased. I don't think many cyclists will expect to complete a quick repair mid-ride; rather, they'd be equipped to deal with the most common modes of failure so they can get home. If you're only going a few miles from home and don't mind a walk, carry nothing if you want. If you're attempting a long-distance ride without support, or facing a long wait for support, you may want to carry spare spokes so you can repair a wheel and get rolling to safety.
My carried kit at a minimum includes all the items I'll need to patch and reinflate a tire to deal with a flat. This is, so far, the most common issue on any of my rides, and isn't something you want to ignore and try to limp home. That means tire levers, a patch kit (or a spare tube) + a tire boot and a pump or CO2 inflator. Nice to have but not necessary is a rag to wipe your hands when you're done. If you have nutted axles, you'll want a 15mm wrench too.
The next most common failure for me is a loosening bolt, somewhere. A modern bike will be using hex head bolts, with 4mm, and 5mm being common for many critical parts, and 6mm for stem quills. Most other things you can limp home with. For older bikes, hex nuts and slot head bolts were common, and I've found a 6 inch adjustable wrench is a good size for tightening the nuts on the fly. Look at the bolts for your stem, handlebars, brake and shift levers, brake pads, cable pinch bolts, saddle clamp, and seatpost clamp, and you should be able to figure out which tools you'd need to carry to adjust them while you're away from your toolbox.
For self-sufficient touring, I want to be prepared for repairs likely to happen while just riding along. That means a spoke wrench and chain tool for broken spokes or chains, in addition to the tire levers, patch kit, pump/inflator, and hex wrenches. Other forumites with longer distance tours farther from civilization would recommend carrying more, in addition to supplies necessary for more involved repairs.
Likes For Unca_Sam:
The dropped
Liked 1,014 Times
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
What kind of "quick repairs" do you envision, carloscedeno ? Start with the failure mode and likelihood, and then work to the solution. Don't begin with tools.
I'll give you an example for reference: My touring bike has fenders for which there are stays that are tightened with a 10mm hex nut. On a extended ride, fender stay failure can be caused by picking up a piece of debris (like a stick, or even a plastic bag), and I might need to straighten out a bent stay. Also, these nuts can work themselves loose over time. I prefer not to Loctite them, because of the need to adjust or repair. The solution? Carry a wrench that fits 10mm. I use a short box wrench.
A second example is for cross-country mountain bike riding. Crashes happen, as do impact with rocks, roots and other obstacles. There may be a case where the derailleur gets smashed, its hanger bent, or the chain damaged. So, the solution to make the bike rideable to get back is to be able to (1) remove and straighten the derailleur, (2) replace the derailleur hanger, or (3) shorten and re-attach the chain. Necessary tools: 5 and 6 mm hex wrenches, chain breaker part of multitool, spare quick link, spare derailleur hanger (which also requires 3 mm hex wrench).
See how it's done?
If you inspect and maintain your bike, then you'll likely only face punctures. So needed: tire levers, spare tube, patch kit, means of inflation (frame pump, co2 inflator, etc.). I prefer the pump, but not exclusively.
See how it's done?
Quoted: 1074 Post(s)
Liked 295 Times
Start knocking doors on properties with discarded machinery on them. Ask if anyone there would be interested in trading a hammer for a repair patch and an angle grinder for a tube of vulcanizing compound or contact cement.
Likes For dabac:
Quoted: 283 Post(s)
Liked 262 Times
3 4 5 6mm allen key, tire levers, spare quickLink, spare tube, precut tyvek envelope for tire boot, mini-pump, $20 bill. Maybe small screwdriver for derailer adj. Minimalist- 5mm allen key. Ha, it's Friday, let's argue.
Likes For grizzly59:
The dropped
Liked 1,014 Times
Use angle grinder around the puncture hole, look for a chunk of rubber at the side of the road, and hammer that chunk very very hard on the hole to melt and vulcanize it over the hole and seal it.
If that didn't work, next time bring an anvil too and maybe, an even bigger hammer.
If you have a flat, you just go to the nearest bike rack, find a bike about the size you ride, take the angle grinder and... wink wink, nudge nudge, say no more.
Just kidding, bike thieves are scum. Even if it's a really an involuntary trade.
Quoted: 822 Post(s)
Liked 1,960 Times
Your best tool is your brain. Regular maintenance and changing consumables of worn parts like chains tires, brake pads, cleaning drivetrains, torqueing to specs, or paying the LBS to do it for you, will prevent most issues as long as you do not crash or get hit.
Spare tubes and a flat repair kit are a given.
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
spare tube, patches, pump, tire boot, tire lever if you need it, plugs if you're tubeless. a little bottle of spare tire sealant is not a bad idea either.
basic multi-tool with bits for most of the bolts on your bike.
it depends on the location and distance you are riding. if you're loaded down and touring into the wilderness many, many miles from civilization, I would think you'd want to bring a lot more. otherwise, the above should be more than sufficient.
preventative maintenance goes a long way. inspect your tires, chain, cables, brake pads, etc. regularly before riding.
the tools I use get used on other people's bikes more often than my own bike.
Likes For bruce19:
Quoted: 581 Post(s)
Liked 921 Times
-allen keys
-spare tube, patch kit, and pump
-chain tool
Unless my frame breaks or my bottom bracket spindle snaps I can make it home with these items and, sometimes, a bit of ingenuity.
-chain tool
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Add a cell phone with the Uber app installed.
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,993 Times
Habitual User
Quoted: 4946 Post(s)
Liked 8,085 Times
My tool kit for road rides includes: Multi-tool, tube, CO2, tire levers, and some sort of boot material (currently a $1 bill - probably needs upgrading). If all else fails, I also have my cell phone and a credit card.
Likes For Eric F:
Quoted: 2604 Post(s)
Liked 1,932 Times
The time I tried to boot a tire with a $1 bill it failed. Another time when all I had was a $5 bill, it got me home. Draw your own conclusions.
Liked 1,932 Times
Likes For pdlamb:
Quoted: 604 Post(s)
Liked 1,063 Times
Quoted: 1088 Post(s)
Liked 1,024 Times
just riding. Tube, patch kit, multi tool with allen wrenches and chain tool built in, co2 pump and that's it. If I break a spoke the multi tool will let me adjust the wheel to work, bent der hanger can be adjusted with an allen wrench in the der bolt for leverage or worse case, make it a single speed. All these will get you home.
Touring. I have a water bottle sized container that fits under the downtube. It also includes a cable cutter and z-bend tool so I can make any size spoke I need, I have a few cables wrapped in the bottom of the pack, a replacement hanger and the rest is the same. Never had a cable failure since I do regular maintenance and spokes haven't been an issue though luck and a stick can change that which is why I have the spoke tools. Any actual broken parts is just tough luck and no amount of tools will solve that.
Leading a 6 week trip of ten teenagers through California for AYH, we had a broken pedal spindle, torn off fender, tacoed, wheel, broken wrist, concussion, broken stem, that I can remember. What would be your minimum tool list for that?
Also got pulled over by the CHP.
SE Wis
Quoted: 2746 Post(s)
Liked 3,394 Times
I carry on my commuters
Spare tube
patch kit
multi-tool
tire levers
quik link (saved from old chain)
1 - shift cable
pump
misc zip tie tape small rag
Spare tube
patch kit
multi-tool
tire levers
1 - shift cable
pump
Likes For dedhed:
