New chain + new cassette = noise in the smallest cogs only?
longtime noob
Bikes: 2018 Trek Domane SL 6 // 1999 Trek 5000 // Burley Encore X
Quoted: 46 Post(s)
Liked 63 Times
I just installed a new Shimano chain and cassette on my bike and I'm getting some chain noise... but only in the three smallest cogs on the cassette, in both the big and small chainring. There's no skipping per se... just a constant grinding. Thoughts on what the cause might be? (Searching reveals lots of "you need to replace the cassette and the chain at the same time" responses, which obviously isn't the issue here.)
Thanks!
Thanks!
Quoted: 211 Post(s)
Liked 199 Times
Did you replace it with the same size cassette and chain ?
I JUST had a similar issue. ( new cassette and new chain )
But I increased the size of my cassette to 12-28 from 13-23
Making the chain shorter by one more link helped resolve the issue 90%.
Still need to " fine tune" the RD though.
There are people on this forum that are much more knowledgeable than me. They helped me........................ and without their expertise and time, I would still be trying to figure it out.
I cannot THANK them enough....they are the BEST !!!!
I'm sure they will respond and have more detailed answers than I provided
Some pictures might help
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
Did you try playing around with the barrel adjustor and limit screws?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Just stop. You don't just randomly tell someone to 'play around w/ the barrel adjuster and limit screws'...that is terrible advice.
New chain and cassette, old chainrings? Now you know where your problem is. Slightly/somewhat worn rings are trying to hang onto the chain as it leaves the ring(s).
Likes For cxwrench:
Quoted: 1438 Post(s)
Liked 1,092 Times
Likes For dsbrantjr:
Likes For mack_turtle:
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
drivetrains are relatively complex with a lot of moving parts and parts that wear out. without seeing it in person, I can't narrow down what among the two dozen possible issues is causing this.
one theory to consider: which cassette cogs do you use the most? smaller rings generally wear out faster because the same amount of force can be placed on fewer teeth when used, so there's more force per tooth on that cog. it's possible that if you used your smaller cogs more than the others, those wore out before the others. for most cassettes, that means you have to replace the whole cassette. that's just one theory.
Quoted: 1818 Post(s)
Liked 1,693 Times
longtime noob
Quoted: 46 Post(s)
Liked 63 Times
I'm going to follow dsbrantjr;'s guidance and will report back with pictures if I'm still having an issues. And, most importantly... no, I never planned on "playing around" with any RD adjustments.
n00b
Quoted: 428 Post(s)
Liked 466 Times
derp. I missed that somehow. apologies.
what about the derailer hanger alignment? there's no reliable way to eyeball that, as a misalignment can be in more than one axis and might be just enough to throw it off but impossible to see. use a hanger alignment tool to make certain.
Quoted: 6191 Post(s)
Liked 4,807 Times
When do you notice this noise in the smaller rear cogs? If it's while you are riding a putting out a fair amount of power at speed, then it might just be the way the rollers have to engage the smaller sprockets. I notice this more with freshly cleaned cassettes at times I'm doing a fast ride in peaceful conditions on a smooth surface. I feel it more than I hear it. Don't know that I've ever noticed it when the bike is on a stand just running through the gears.
edit....
Were the spacers between some of the cogs that you might have missed or messed up when putting on the new cassette?
edit....
Thanks!
Thanks!
