What level of bad is this...?
Edumacator
Quoted: 2436 Post(s)
Liked 3,119 Times
So, I got this pile of stuff locally...not sure why it intrigued me...it wasn’t that great a deal.... anyhow,
...what level of confidence would you have in building this frame into something useful? I am sure at some level I know it would be silly to ride this thing...
A bit scruffy...is this carbon or the alloy?
How did this inner fork get rug burn?
More rub burn...did someone use 48s or something?
Scruffy fork
Head tube...cool looking. Might be the only functional part...not. Cool cable route though...
Dramatic down view of the stays...
Looks like carbon fiber
Scruffy fork
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Trek's bonded carbon models seem to linger on CL locally. I don't think building it would be silly at all, if you don't have concerns about the fork. The 2100 was the 'entry' level bonded frame, with a 2200 and 2300 rounding out the line up. I once had half an inclination to grab one with the green lugs and stays to use for fixed/single speed, until I realized that this bike was built with vertical dropouts.
I've seen griping about harsh rides, due to the vibration dampening carbon being used in the exact wrong places to do any dampening, but I have no experience with it myself.
It should make a fine rider with a 7 or 8 speed wheelset, if you have the parts.
According to vintage trek, this could be a 1993 2100, and was equipped with Shimano 105.
The dropped
Liked 1,014 Times
Also, these pictures remind me of when my kids were toddlers and they wanted to show me something small, so they'd shove it up my nose to show me.
Likes For Unca_Sam:
Some Weirdo
Bikes: '86 Schwinn Prelude, '91 Scott Sawtooth, '73 Raleigh "Grand 3"
Quoted: 223 Post(s)
Liked 141 Times
I wouldn't trust that fork. Bit too much tire rub. Clean the frame and check for delamination between the carbon and the aluminum joints. I thought I saw some at the top of the seat tube. Also check closely around that headtube where the housing goes in. If the frame looks good, replace the fork and ride to failure. Don't forget to post whole-bike pictures!
Somewhere, a village is missing its idiot.
Quoted: 405 Post(s)
Liked 430 Times
One of the strongest, best-built bonded carbon frames ever made. Joint failures on bonded Treks are almost unheard of. Good score. As long as there's no actual damage, build it up and ride it 'till it dies.
--Shannon
PS: The clear-coat bubbly - flakey thing is quite common on these. It's not a problem, just ugly. But, then, they're kinda ugly bikes anyway, so who cares... they ride nice.
--Shannon
Bikes: my precious steel boys
Quoted: 438 Post(s)
Liked 603 Times
IIRC the 2100s (and their cousins in the Giant Cadex and Specialized Allez Epic) were popular enough that we'd probably hear about it if they had a spate of bonding failures.
Quoted: 1627 Post(s)
Liked 630 Times
Yeah, I had a Trek 2100 and I want to find another one that's actually my size to see if it's a as good as I remembered.
At 19 lbs, it was the lightest bike I ever owned. I'm sure I could get that down a bit, with parts I've accumulated since then.
Those photos remind me of the one time I took acid. It didn't go that well.
Edumacator
Liked 3,119 Times
Yeah, the fork and scruffy delamination are what give me pause. I was going to paint the carbon bits, possibly replace the fork and build it up as a fixie/1Xsomething for part of my student bike give away program with upright bars. Wondering if it would be safe.
Likes For Ex Pres:
The dropped
Liked 1,014 Times
The fork is the biggest concern. If you use a straight edge or a flexible ruler, how deep are the rub marks?
Passista
Quoted: 866 Post(s)
Liked 721 Times
My answer would be biased, for I have an instinctive mistrust of carbon.
looks fine to me, both the fork and other bits. If it were a personal ride, I'd swap the fork to 1" carbon for a smoother ride. If you're going to turn it into a singlespeed and flip it, leave the fork as-is. Overall I wouldn't put a lot of effort into it, as I don't have a high opinion of the ride quality of early carbon-tubed, lugged bikes.
Check out www.djcatnap.com for articles on vintage Japanese & French bicycle restorations, components and history.
Edumacator
Liked 3,119 Times
just picked up another...
Edumacator
Liked 3,119 Times
i have none myself but if the consensus was that they are pretty safe for a student I’d build one up as a prize for them.
Edumacator
Liked 3,119 Times
1x, maybe. Fixed? Not unless you like expensive solutions or hacks like the magic ratio. Painting? The clear coat, bare carbon tubes are kind of the point for this series. Moving from drop bars would mean more outlay for DT shifter boss cable stops. (Does anyone use flat bars and DT shifters?)
