[Nexus 8] Riding without left hand-side dust cap?
Quoted: 573 Post(s)
Liked 118 Times
[SOLVED] [Nexus 8] Riding without left hand-side dust cap?
Hello,
To stick a Shimano Nexus 8 gear hub into a Brompton (OLD 112mm), I'm thinking of removing the left hand-side "dust cap unit" and shave 12mm (132mm → 120mm; 3.68mm could be further saved by replacing the LHS lock nut with its RHS, thinner alter ego, and achieve an OLD of 116.32mm).
Do you think it's reasonable to ride without it in a moderately rainy region (Western Europe), even if it means squirting fresh grease on the bearing balls more often?
If not, is some kind of cap available?
Thank you.
Thank you.
The dust cap does not only protect the hub from rain. It also protects it from DUST.
If dust gets in, it mixes with oil/grease and starts sanding parts down when they turn. It doesn't seem like a good idea to me.
Quoted: 194 Post(s)
Liked 204 Times
Or, if you are or happen to know someone with decent engineering skills, you could try devising some kind of alternative.
For example, many bikes from the cheaper end of the market had pressed aluminium dust shields on either end of the BB as the sole protection against the ingress of dust and/or water, as do the coaster brake hubs from Velosteel.
I have never examined a Nexus in detail but, heh ho, life is short and engineering the final front door.
Quoted: 573 Post(s)
Liked 118 Times
Another thing that must be addressed: After removing those parts on the left side, the hub will be moved to the left, so when cold-setting the frame, it should be pulled asymetrically so the right stay lies further to the right.
Quoted: 573 Post(s)
Liked 118 Times
Got a reply from gear hubs expert Aaron Goss: "It is fine. We have done it. Yes grease more often."
Passista
Bikes: 1998 Pinarello Asolo, 1992 KHS Montaņa pro, 1980 Raleigh DL-1, IGH Hybrid, IGH Utility
Quoted: 866 Post(s)
Liked 720 Times
I think it's not really a dustcap, but it's there to cover the splines if you don't use a roller brake.
Quoted: 573 Post(s)
Liked 118 Times
It's how Shimano calls it: "Left Hand Dust Cap Unit (Y-34R 98100).
Regardless, it then opens a new issue: Using that trick, the rim would now be way too far to the left :-/
Likes For Reynolds:
