XT rd tension
Quoted: 1872 Post(s)
Liked 692 Times
XT rd tension
Hey all - is there any way to increase the cage’s spring tension? The chain is sized correctly but it sits on the cable in the lower cogs because the rd can’t keep it taut. I'm pretty sure it's the b-tension spring and not the cage itself.
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 1606 Post(s)
Liked 2,570 Times
I don't have one right here, but this video may help.
Ride, Wrench, Swap, Race
Quoted: 1562 Post(s)
Liked 1,288 Times
It is not unheard of for either spring to break, if perhaps you noticed a sudden loss of chain tension(?).
Bikes: are fun!
Quoted: 466 Post(s)
Liked 862 Times
I doubt it from the pic, but have you exceeded the RD capacity? Probably fine, especially if that’s a double, but worth confirming as a first step. How did you size the chain?
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,401 Times
Other question not related to chain length- is the RD cable adjuster missing or broken?
Liked 692 Times
I don't have one right here, but this video may help. https://youtu.be/1sZS49JmXK0
And here's the corresponding RJ video for the pivot bolt/spring: https://www.youtube.com/watch?v=bgiNuJNynMc
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 634 Post(s)
Liked 444 Times
You could try flipping the B screw around so that it screws in from the "inside" and the screw head rests on the B screw stop on the der. hanger. It would give you a little extra kick back on the der. Maybe not enough to make up for all that chain slack though.
Likes For tricky:
Quoted: 576 Post(s)
Liked 1,001 Times
That derailleur looks like it has a short cage, which was uncommon for that model. If it were replaced, maybe the spring tension wasn't set properly.
FWIW, here is my M737 in small/small; your chain looks long but its hard to see; a pic of big ring/big cog should be clearer.
Liked 692 Times
It took me a minute but I figured out why my RD looks different, it's because it has an XTR GS cage installed on it. It's not a short cage though. It has "Max 32T, Total 33T" printed on it.
2019 Salsa Warbird
2019 Salsa Warbird
Garage tetris expert
Bikes: A few. Ok, a lot
Quoted: 386 Post(s)
Liked 691 Times
https://www.disraeligears.co.uk/Site/...96_scan_2.html
I believe this is the "middle cage" version.
(Edit: not sure why the link is not working, but here's the main link: https://www.disraeligears.co.uk/Site/..._M739_SGS.html. Look under 'Documents')
Quoted: 576 Post(s)
Liked 1,001 Times
Quoted: 386 Post(s)
Liked 691 Times
That's awesome for seeing how the parts are put together. I'm not too hopeful that's the fix for this rd though, I think the spring is just worn. I think this might be a good solution though: https://www.youtube.com/watch?v=A7Coy083--0
Liked 692 Times
Oh for sure! Now that I have an idea how the parts fit together I'll give that a go first.
2019 Salsa Warbird
2019 Salsa Warbird
Liked 1,288 Times
It could be that a previous owner somehow over-tensioned the spring while trying to get it re-installed.
Sometimes people get confused as to how reassembly is done, and the cage gets twisted too far with the stop pin removed.
Perhaps also the spring is from different derailer than this setup, so the spring anchor holes aren't clocked right for this spring(?).
I have ran into an issue like this, and it was that the screw that is the stop for the Jockey Wheel plates was removed and was replaced but the cage plates had rotated causing very little tension on the cage plates and a drooping chain like that.
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Liked 1,288 Times
Oh yeah, that spring looks mangle-ated, definitely wound too tight at some point, gad.
Doesn't mean that it can't still be used, just has to be tensioned to suit it's new "configuration".
