Down tube shifters
Down tube shifters
I am rebuilding an old steel racer with Huret shifters and an Allvit derailleur. This is a very amateur question but am I correct is saying that shifter only stays in it's given position by the screw on the shifter being tight enough. So the mechanics of it is shifting to a smaller cog is done by the derailleur pushing outwards as it naturally will and shifting to a bigger cog is done by the shifter pulling the derailleur inwards and the shifter itself holding in place. My issue is the shifter is not holding in place, when I pull it towards me it goes back to the full forward position and I think this is simply because the screw is not tight enough.
Yes this is correct assuming you have any washers and bushing for the lever correctly installed. The reason many levers have a d ring mounting screw is to make fine adjustments easy. You shouldn’t have to go beyond finger tight to get it to hold. Also, you don’t need a ton of cable tension when setting up initially. Just pull the cable taught and attach to the derailleur.
Likes For DOS:
Sounds like a missing or greased up friction washer. But sometimes the needed friction setting makes shifting harder. If your frame's rear is spaced at or can be cold set to 126mm then think about a 7-speed indexed upgrade. It should be possible to find a used Shimano DT shifter and a compatible derailleur. The indents do a good job of holding the setting without a lot of lever effort in shifting. DT index shifting is very reliable and easy to use as long as you are on drop bars.
“Friction” is key to the proper function of friction shifters! I’d check to make sure that the shift lever assembly is properly assembled and that the contact surfaces are clean, smooth and free of lubricant. As mentioned, some shift levers have a D-ring or tiny wing nut like arrangement to allow adjusting the degree of friction that holds the level in any given position. As also mentioned, if “finger tight” isn’t sufficient, something’s not right.
Quoted: 207 Post(s)
Liked 108 Times
Also, that is pretty much the last thing you worry about, after the FD and RD are clean and moving freely with decent spring tension, and all cables and and housings are replaced.
If the issue is really marginal - like if it's mostly working but you're having to occasionally tighten it up during a ride - then you could try hitting the threads of the bolt with a bit of a not-super-aggressive threadlocker like blue Loctite.
Likes For HTupolev:
Quoted: 1438 Post(s)
Liked 1,092 Times
Old fart
Quoted: 3571 Post(s)
Liked 3,367 Times
Make sure you have all the pieces and that they are installed in the proper order and orientation. You don't say what model levers you have, but perhaps this thread and its illustrations might help:
https://www.bikeforums.net/classic-v...n-diagram.html
