Loose BB in carbon frame
Hi all
I have an issue with my carbon frame. I have the shimano R9100 bottom bracket.
I had some creaks which I narrowed down to the bottom bracket. I removed the drive side cup and moved to remove the non drive side one.
However, when I tried to unscrew it, the cup was turning but without unscrewing
I then went over one the drive side and screwed it back on. As I tried tighten it, I saw that it too started having the same behavior (turning without screwing) and at the same time
I noticed that as I was turning the drive side cup, the non drive side cup was also turning.
I am pretty sure that the BB shell has become unstuck. I cannot explain it any other way.
Now, I have 2 questions
1.The 2 cups thread in opposite directions, If I find a 2nd BB tool and use it to stop the shell from moving, I believe I will be able to remove both cups, by using the 2nd tool and applying opposite force.
I believe the shell is turning after applying a specific amount of force, so it is not completely unstuck in a way that it can be turned by hand. Assuming, what I propose with the 2 BB tools works, in theory I would be able to tighten the 2 cups firmly and since the cups
are pressing against the frame, will I have any issues with this loose BB shell?
2. Can the BB shell be glued?
Many thanks
Many thanks
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
There are some specific loctite compounds that may help (similar issue with Trek BB90 in which the carbon gets ground out a bit and bearings move).
Might just be time for a new frame. I've never heard of an entire bb shell coming out, but I guess stranger things have happened.
Quoted: 763 Post(s)
Liked 1,731 Times
Bikes: 89 Paramount OS 84 Fuji Touring Series III New! 2013 Focus Izalco Ergoride
Quoted: 285 Post(s)
Liked 74 Times
I have a loose PF30 Al shell in crabon. It allows the cranks arms to move quite a bit. I checked out Calfee and didn't directly ask them but they state up front they don't do alloy to carbon bonding. I tried to work some epoxy into the crack but it didn't do much. At first it was just on the drive side but now the NDS is also loose.
scott s.
scott s.
Quoted: 1109 Post(s)
Liked 1,200 Times
scott s.
scott s.
Likes For Camilo:
scott s.
scott s.
bike whisperer
Quoted: 1527 Post(s)
Liked 718 Times
Where's the naming and shaming of the companies who made these two frames?
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Likes For Kimmo:
Unfortunately there is no warranty since the bike is some years old. In any case, I am waiting for a 2nd BB tool I ordered, in order to try my theory
Hi all
UPDATE regarding the issue I posted, that may help others in the future.
The problem was due to an adaptor installed like this one.
/www.amazon.com/FSA-BB30-to-BSA-Adapter/dp/B004N99NG6
This adapter was turning actually, since it was not glued and not the original insert from the factory.
I got the bike second hand, so this was probably done from the previous owner.
Anyway, the bike shop sorted it out.
Likes For tombell:
Quoted: 850 Post(s)
Liked 344 Times
Hi all
