made a bike rack for twin tandem bikes
Quoted: 9 Post(s)
Here is what I made.
I took an existing 2" hitch mount bike rack, got rid of its vertical column, took 2 Thule roof mount racks, cut them in half, welded two L shaped support frames with 1" steel tubing, then fabricate them together into this.
The rack in the back can also be adjusted to take a normal bike, by moving the "Thule" half rack down about 2 feet.
Added 2 "horizontal stabilizing bars", to prevent too much flex when driving on highway.
Bikes: 2010 Bob Brown Cycles tandem, 2019 Co-Mo Carrera tandem, 1980 Richardson tandem, 2014 Cervelo R3, 2018 Specialized Roubaix, 1985 Bianchi Campione, 1983 Trek 720, 2020 Trek Fuel EX8, 2021 Salsa Mukluk
Quoted: 72 Post(s)
Liked 116 Times
That's one way to do it! It appears to be pretty stable without the bikes nosing out too far on each side. As you've stated, I would've been concerned about the "wind flex" as well, but it looks as though you have that covered. Great job!
I admit i'd be very worried to be behind you on the highway. but give you a huge thumbs up after I went to pass...
