Nexus 3 speed issues
Bikes: Most of my bikes are Single Speed Conversions
Quoted: 267 Post(s)
Liked 3,067 Times
A few years ago I bought a new wheel set with a Shimano Nexus 3 speed hub .
I’ve never been able to get it shifting correctly.
I’ve attempted to set it up and adjust the shifter without any luck .
I read some hubs came with the wrong length spring guide pin ( I think that’s what it’s called , the spring wrapped pin that goes inside the hub) , so I ordered what is supposed to be the correct pin and it’s the same length as the one that came with it .
Didn’t help .
Not using the yellow line to adjust the shifter , I was able to get it to shift up and down , once . Then it quit .
I removed the wheel and put it aside again .
Fast forward to today .
I’d like to give this wheel set and hub another try . I’ve been reading the Shimano manual and ,
I’ve read the shifter unit could be the problem , so I’ve ordered a new , complete shifter and cable assembly .
Those of you that are familiar with these hubs , what are my chances this will fix my problem or am I throwing more money down the rabbit hole . I’d love to have a lower gear on my Electra Cruiser for the hills around here .
Didn’t help .
Senior member
Quoted: 945 Post(s)
Liked 662 Times
The shift rod is specific to the axle length. The pin should protrude 14mm from the end of the axle at the point where it meets resistance when inserted. If this measurement is off, it is the wrong rod.
Likes For Dan Burkhart:
