Inner tube
Old 09-03-17, 04:07 PM
nickg01
Inner tube
I have a 28 x 2.125 or 700 x 45c tire. Will I be okay to run a 27.5 by 2.125 inner tube until I can get the proper inner tube?
nickg01 is offline
Old 09-03-17, 04:24 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,271 Times in 877 Posts
The ID is about 1-1/2" less.
I wouldn't.
https://sheldonbrown.com/harris/tires/index.html
Bill Kapaun is offline
Old 09-03-17, 06:20 PM
Berg417448
Troublemaker
Berg417448's Avatar
Bikes: Yes. The more the better.
Quoted: 46 Post(s)
Liked 44 Times in 23 Posts
It will probably be fine. I've run 26" tubes in 29" tires in the past with no issues other than being a little more difficult to install.
Berg417448 is offline
Old 09-04-17, 07:37 AM
Hoopdriver
On Holiday
Hoopdriver's Avatar
Bikes: A bunch of old steel bikes
Quoted: 394 Post(s)
Liked 14 Times in 12 Posts
You might have a slight issue with pinching when mounting as the tube will hug the rim tighter. Once installed, it should be ok if you are in a hurry to get going. Instead of going to the trouble to mount and then change later, why not just get the proper sized tubes now?
Hoopdriver is offline
Old 09-04-17, 10:26 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
You have my permission to try it. Is that what you needed?
fietsbob is offline
Old 09-05-17, 08:59 AM
chong67
chong67's Avatar
Bikes: Trek FX 7.4 + Sirrus Expert Carbon X1
Quoted: 148 Post(s)
I need help.
Outside of my bike says 700x30mm tire.
My inner tube got a hole and I want to replace it. It says 700x28/38C
Yes, I measure the stem and it is 42mm.
Can I get this: 700c x 18-25c 42mm Stem Presta Valve
chong67 is offline
Old 09-05-17, 11:02 AM
Hoopdriver
On Holiday
Hoopdriver's Avatar
Quoted: 394 Post(s)
Originally Posted by chong67
I need help.
I'd recommend a bit wider tube. Something like a 28/32 or 28/35. I don't think I have ever seen a 28/38
perros10
General Cycling Discussion
17
06-26-17 02:04 PM
ZachasaurusRex
Bicycle Mechanics
41
01-23-16 12:46 PM
Gresp15C
Bicycle Mechanics
9
01-08-16 10:41 PM
CuriousCurator
4
01-08-13 02:41 PM
Simko
Road Cycling
5
01-17-10 09:14 PM
