gatorskins 28mm
gatorskins 28mm
Gatorskins 28mm are what I use to commute 33miles every other day. The tires are at 100psi and I'm 300lbs. Is there a better tire for less flats and better ride than the Gatorskins? Thanks
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
32mm would be better if you have the clearance on the bike.
Quoted: 18378 Post(s)
Liked 4,512 Times
There are two gators...
Gatorskins & Gator Hardshells.
The hardshells are supposed to be slightly beefier, although I can't tell a lot of difference between the two. I've had the occasional flat with both.
What types of flats are you getting? How frequent? Every flat should have a diagnosis.
I like the gator hardshells, but I'm still exploring.
There is a class of TOUGH tires:
There are also tire liners. I've stayed away from them as I tend to avoid flats, but they may help. I've seen the Panaracer “Flataway” tire liners recommended as being tougher than other lines.
Tubeless tires are becoming more popular, and in theory a sealant should be able to seal many things causing flats.
One can also use sealants in tubes. Slime (green goo) will last more or less forever, but doesn't make a good permanent seal. Other latex sealants will apparently make a permanent seal, but require periodically adding more.
- Pinch flats (snake bites). Underinflation, and running over sharp debris. Also, a slow leak from some other cause can show up as a pinch flat.
- Goatheads and thorns.
- Radial Tire wires... those little things are invisible and wicked!!!
- Glass
- Something else?
- Schwalbe Marathon Plus
- Michelin Protek Max and Protek Cross Max
- Panaracer Tourguard.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Duplicate thread. Closed.
Please see this thread if interested.
https://www.bikeforums.net/clydesdal...l#post20151045
