What to do with this frame?
I’ve owned this frame since it was new in the mid 80s. A broken dropout was replaced some time the in early 90s. It’s been painted twice, once to match club colors, once as a rattle can job after the drop out repair.
A few years ago, sick of the rattle can job and having some money at hand, I was going to get it powder coated. The coater removed the old paint and then called me, telling me that they couldn’t paint a frame with pinholes. And there they were. Holes in the drive side seat stay.
So I took it home and put it away, only using it for checking hub widths, or other tasks where it’s useful to have a bare frame. But now, it mostly just hangs on the wall taking up space.
I don’t really need another frame now, so here’s the question: do I build it up, use it as grocery store rider until it breaks, then pitch it? Do I have the stay replaced, knowing that then I’ll have to have it painted, which could be the price of another frame? It’s not going to turn into yard art, and it’s not going to go back on the wall, to mock me as it’s done for years. Suggestions?
Photo of stay follows. Two holes below seat stay cap, under the line of discoloration.
Quoted: 1136 Post(s)
Liked 650 Times
Pinholes can be filled with braze but my first question would be the cause.
I would boroscope all frame tubes to check for internal corrosion. That will indicate if you should be replacing the stay entirely or if filling would be sufficient.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,869 Times
Any idea what caused the holes? Like is there more rust hiding inside? Those holes wouldn't concern me, but the prospect of additional rust, especially in other tubes would.
Edit: TenGrain beat me two it. That's just what I was thinking.
My Bikes
My Bikes
Quoted: 3464 Post(s)
Liked 2,831 Times
Shinibop? Had similar with a Colnago but the tube failure was near the dropout.
he had the stay replaced.
makes one wonder how it was long term stored?
rear wheel up?
unheated space?
This region is not a highly stressed zone, but is concerning.
assuming no chrome? Currently it prior?
rear wheel up?
unheated space?
Quoted: 28 Post(s)
Liked 60 Times
Looks like the SS caps were done with cast plugs (where the DAVIDSON logo is). Worthy of saving and it would be a fairly straightforward repair job to entirely unbraze the pinhole SS and refit a new SS (via brazing). The end cap plug would be easy to transfer between the old/new SS, probably biggest hassle would be the delicate brake bridge fitting. Only concern is if the pinhole SS is just "tip of the iceberg" of other internal corrosion on other tubes or if it was just limited to this one SS tube (possibly got filled with rainwater and sat for extended time)??
Thanks. Pretty sure it’s that stay only. I can hear thing rattling inside that tube, and not a peep from the others. But where would I find a boroscope?
I’d say the rust came from the time I lived close enough to hot springs to smell the sulfur but any of the all of the rattles come from that one tube.
Ask bulgie if he will warranty it. 🙂
Quoted: 4513 Post(s)
Liked 6,389 Times
Go see Dave at TiCycles for some of the best input in the business.
rear wheel up?
unheated space?
rear wheel up?
unheated space?
Position varied: wheels up, wheels down, one wheel up, depending on available storage space.
No chrome ever.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,803 Times
I have one (endoscope), you can pick up a cheap USB one on the interwebs.
It's worked for to inspect seat and down tubes, but the vent hole for top tubes is typically too small to fit. Of course, getting it up into a seat stay would be impossible, as the head of the boroscope is 5-6mm in diameter.
Replacement of a seat stay isn't too difficult, I've done it before.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,491 Times
I'd cover the tiny little holes (with a decal) and ride it as a sexy beater until it gets worse (which may be never).
Likes For SurferRosa:
Thanks for that clarification. A camera small enough to fit sear stays seemed pretty specialized. A camera for main tubes is something I can find. Checking them seems like a good first step. If there’s issues with the main tubes, the stay doesn’t really matter.
If one has rusted through, what are the chances the others are in similarly bad shape?
My guess is it is nearly 100% they are all pretty bad.
What are the consequences of a structural failure?
This is usually BAD!
When is a structural failure most likely?
Most likely when you put the frame under heavy load (are hammering your guts out). This failure scenario exacerbates the consequences of the failure.
Bikes: 1973 Colnago Super, Litespeed Classic , Automoto , Pinarello Gavia TSX,Eddy Merckx Corsa Extra,Eddy Merckx EMX-5 , 1982 Moser SL, Concorde TSX, Vitus 979 KAS. Diamant SLX,60's Meteor
Quoted: 235 Post(s)
Liked 947 Times
Throw it in the trash, You got your moneys worth out of it.
Likes For Mr. Spadoni:
Liked 2,831 Times
@majmt has a scope and the set up allows images
Liked 5,803 Times
blahblahblah chrome moly
Quoted: 1181 Post(s)
Liked 2,576 Times
I'm with SurferRosa , just ride it. There's a decent chance of it going many miles without drama, and all the likely failure scenarios I can think of are slow with lots of warning.
I probably wouldn't hide it under a decal though, I'd be interested in watching it to see if a crack developes.
I can see not wanting to invest in an expensive paint job though. And maybe your lifestyle doesn't have room for a rattle-canned rat-rod in your stable, fully understandable. Just spitballin'.
Edumacator
Quoted: 2441 Post(s)
Liked 3,137 Times
If the scope finds some rust, you can always flood the tubes with evaporust to stem the tide to get more life out of it!
Then rattle can to protect it and make it the grocery getter you suggested.
Thanks for all the input. The fate of the frame has been decided. Got a quote on the stay which was enough that I would feel obligated to get a good paint job done. At that point, I could buy a decent used frame, then I’d have to find the right parts. And then I’d need, and so on…..
So, frame is getting evaporust , a coat of clear rust oleum as I have some on hand and people should see the excellent work that was done by the person who wielded the torch, and then something removable, like putty or caulk stuck in the holes to prevent water entry but allow easy inspection of area. And then it will be built up and it will get ridden for a while longer.
Veteran, Pacifist
Quoted: 3901 Post(s)
Liked 4,844 Times
How many bikes do you own @Mr. Spadoni ?? A bunch? I would try to find a trade for something I wanted on another bike. Lots of people out there who love to resolve frame problems. Some for no other reason than to justify a hacksaw and endoscope. I find it funny, for some = a challenge.
Quoted: 1641 Post(s)
Liked 831 Times
It's a Davidson, it is certainly worth fixing/restoring. Especially if it is a "Signature" model which I heard was more of a custom build than a production line bike.
frameset built by "artisanal" American builders from that era will just increase in value in the future.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Likes For Chombi1:
