Nuovo Record RD rebuild questions
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 641 Times
On two of my winter projects, the derailleurs are NR's. If it matters, one pat-72 and one pat-73 so each one year "older" that the bikes they were on. All broken down as far as wrenches and screwdrivers will allow, ultrasonic cleaning on the loose parts, then vibratory tumbling w/walnut shells, then Blue Magic and then Wolfgang's sealant. So, moving towards reassembly.
(a) with all parts, especially springs, out -- the parallelograms have no play but perhaps a wee bit stiffer in action than I expected (well, they got better after some actuation to work out some residual walnut-shell debris). I wonder "how stiff is stiff" and is there a way, and particular with what product, some lubrication in those riveted pivots might be done?
(b) one RD has the dreaded cracked pulleys, and the other probably will eventually. What is the current best practice for replacement? I'd prefer a new product if anywhere near affordable, rather than looking on eBay for some obscure Suntour/Shimano/whatever RD just for parts.
FD's are next, I might have questions on those too. And I fear I am really going to hate getting the various springs back in place correctly!
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
aged to perfection
Quoted: 840 Post(s)
Liked 1,262 Times
good questions. Of course deep clean everything and use a toothbrush to get the crud out.
as for lubricating of the pivots - you'll want something that can penetrate inside the pivot pin and the tunnel in the arm.
the parallelogram should move freely and return under spring tension.
Another thing - when you put the lower pivot together - Campagnolo used to ship these with a big blob of grease in the spring.
Also the 810/1a plastic bushing does get loose, and that can have an averse effect on shifting. Note not all models have this part, but if yours does, be careful not to crush the little keying tab when re-assembling.
I personally would not worry about the cracked pulleys unless you are prepping the bike for concours judging. They run fine. Replacements are available, including the Enduro Bearing pulleys.
repechage might have more to add here.
/markp
/markp
Quoted: 1304 Post(s)
Liked 1,912 Times
Tiger,
I am doing NR rear derailleurs this week. I find that a small bit of oil will loosen the stiffness you are feeling. I use Tri-flow for this part of the rebuild. All threaded parts get a covering of light grease before re-assembly and then wiped off after installed. It give me a bit of reassurance that the parts will not seize un the aluminum body. Same light grease where to spring rides inside the body, and on all pivot points. I also grease the tension spring and inside of the spring body and especially where the threads of the grub screw go together.
I use Chaser Tech sealed bearing pulleys that are hand fitted and ground to correct width spacing. They can be ordered with spacers for 5mm bolts and need to be shimmed for correct spacing in the cage. HTH, (or I can post pics of the process) MH
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3891 Post(s)
Liked 6,491 Times
One RD has the dreaded cracked pulleys.
Been there. You may find this helpful. When I disassembled mine, I did not pay attention to which hole the cage tension spring was in (step 7).
Likes For ManekiNico:
Quoted: 3464 Post(s)
Liked 2,831 Times
I am unsure about the benefit of walnut shell tumbling with these anodized assemblies.
I do not know the particle size, hopefully not ready to muck things up.
assuming springs out, and adjusters out, the degradation of performance often comes from racking of the movement. If it is loose in “twist”
there is wear lurking.
from the description of the cleaning, I would really want to get as much lubricant into and around the pivot bushings. A graphite suspension lock lubricant would be my choice and that needs to be worked in by movement as much as possible. Then when the black is visible at the far side, introduce some more substantial oil. Lock lube often dries off leaving the graphite.
Very free movement but no slop is what I would want. With slop? Ask Jim Merz his price, he has tools. Will not be cheap. Most of these mechanisms are 50 years old now.
Quoted: 987 Post(s)
Liked 641 Times
Both of these RD's have that bushing, thanks for the warning.
Tiger, I am doing NR rear derailleurs this week. I find that a small bit of oil will loosen the stiffness you are feeling. I use Tri-flow for this part of the rebuild. All threaded parts get a covering of light grease before re-assembly and then wiped off after installed. It give me a bit of reassurance that the parts will not seize un the aluminum body. Same light grease where to spring rides inside the body, and on all pivot points. I also grease the tension spring and inside of the spring body and especially where the threads of the grub screw go together.
I am unsure about the benefit of walnut shell tumbling with these anodized assemblies. I do not know the particle size, hopefully not ready to muck things up. from the description of the cleaning, I would really want to get as much lubricant into and around the pivot bushings. A graphite suspension lock lubricant would be my choice and that needs to be worked in by movement as much as possible. Then when the black is visible at the far side, introduce some more substantial oil. Lock lube often dries off leaving the graphite..
I thought he had left the forum a while back.
Liked 1,912 Times
Tiger,
I have a number to work on and they almost all look even worse than this first example, it came in pretty clean and will not take a lot of work. The second one is after cleaning with new jockeys on. Smiles, MH
This one is pretty clean for what it is. It still has not been serviced in along time, and it is due for a good going over.
When they are finished they are a bit brighter and with new jockeys they will run better. What you can't see is the machined down spacers for the inner side of the bearing race. The Chaser come with a 7mm diameter inner race hole and the spacers reduce the hole to 5mm which is the campy bolt spec.
Quoted: 4513 Post(s)
Liked 6,389 Times
@tiger1964
Jim was gone for awhile, he's back now, for now it seems.
He's posted some very cool projects, even cooler than normal.
https://www.bikeforums.net/classic-v...e-project.html
Quoted: 380 Post(s)
Liked 541 Times
Shimano pulleys have always worked just fine for me. Dirt cheap and last forever.
BITD I did have a set of Bullseye red pulleys on the red Grandis for the kool factor
Thread derailleur
Bikes: Merlin Extralight '94 & Cannondale Supersix '15
Quoted: 367 Post(s)
Liked 465 Times
On a vintage Nuovo Record, any of you use the Shimano set with the Centeron pulley?
The 8sp Dura Ace duo match the old Brev. Int. or Italy in size. In my book, these DA ones represent the gold standard.
Unsure if the readily-available inexpensive versions utilize the same Centeron lateral movement.
Wondering if that lateral movement plays well with older 5 & 6 speed shifting.
At any rate, I just saw ten bucks shipped, on eBay, for the cheap ones. (Actually, $9ea for two sets.)
New Shimano Rear Derailleur Pulley Set TY05/15/20/22/30 CT92/MJ05 | eBay
Quoted: 987 Post(s)
Liked 641 Times
On a vintage Nuovo Record, any of you use the Shimano set with the Centeron pulley? The 8sp Dura Ace duo match the old Brev. Int. or Italy in size. In my book, these DA ones represent the gold standard. Unsure if the readily-available inexpensive versions utilize the same Centeron lateral movement. Wondering if that lateral movement plays well with older 5 & 6 speed shifting. At any rate, I just saw ten bucks shipped, on eBay, for the cheap ones. (Actually, $9ea for two sets.) New Shimano Rear Derailleur Pulley Set TY05/15/20/22/30 CT92/MJ05 | eBay
señor miembro
Liked 6,491 Times
Any of you use the Shimano set?
Liked 1,912 Times
Tiger,
Starting a NR today. Parts are disassembled and ready for a bath. And then new lube and re-assembly. Th threads for the adjuster bolts and grub screw will be chased and straightened out before re-assembly.
SR,
I normally toss the original jockeys in a bag until there are a bunch and then send them off to some unsuspecting victim. In your case these can be had for cost of shipping. I am going to use green for the replacement set on this rebuild.
Center of bearing set is 7mm and I always ask for the bushing set to get to the Campy 5mm bolt. The bushings will need a slight modification for a great fit, but it is only a few minutes to do.
Smiles, MH
SR,
Smiles, MH
Likes For Mad Honk:
Quoted: 969 Post(s)
Liked 1,632 Times
Yep... But other then my wall hanger ya certainly don't want to look at any of my bicycle Group Sets. I have got so many Knock Off, ChiCom, Generic, Off Label parts on my bicycles I should be ashamed... But I am not.
I do wish there were Cheap, Knock Off, Campy Pullys though. And come to think of it, all the Campy Rear Derailleurs I own have at least one cracked pulley. Go Figure...
Likes For zandoval:
señor miembro
Liked 6,491 Times
Maybe there's a way to fill the wheel cracks with something like black Sugru for aesthetics.
Likes For SurferRosa:
Liked 1,912 Times
Today's derailleur is finished with it's bath and has been lubricated and now just await the pulleys to be installed. I will do some aesthetic work and put them on first thing tomorrow. I was reminded that my vacation is only two more weeks of bike work and them back to a Golf Professional. Time seems to fly when you're on break. Smiles, MH
All cleaned up and ready for some green bling. Man was the solvent dirty from this one, and the cage plates had something on them that turned the aluminum black. So some extra time with a buffing wheel and polishing compound to bring them back.
Likes For Mad Honk:
Quoted: 987 Post(s)
Liked 641 Times
Today's derailleur is finished with its bath and has been lubricated and now just await the pulleys to be installed. I will do some aesthetic work and put them on first thing tomorrow. All cleaned up and ready for some green bling. Man was the solvent dirty from this one, and the cage plates had something on them that turned the aluminum black. So some extra time with a buffing wheel and polishing compound to bring them back.
If you or anyone has hints on installing 98/A, especially the short end of the spring, I am curious!
vintage motor
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Quoted: 164 Post(s)
Liked 102 Times
I thought the pulleys were supposed to be cracked.
Liked 1,912 Times
Tiger,
I install the spring with the main portion outside the body and use slight pressure on the spring to start the grub bolt. Pretty easy with a pair of slip joint pliers. Then a pair of thin nosed pliers to pull the spring back inside the body. I use Dualco grease guns here and I can pin-point the grease for the contact area between the spring tip and body. Or a small dab of grease on the tip of a thin blade screw driver. Smiles, MH
Dualco grease gun for easy lube in side the body.
All blinged up and ready for more service.
Likes For Mad Honk:
blahblahblah chrome moly
Quoted: 1181 Post(s)
Liked 2,576 Times
As Mad Honk said, install the spring with the pusher end outside the paralellogram. I find it easy enough to snap it into its working position by hand.
The previous Record (steel/bronze) mech, and the Gran Sport before it, had a spring that was intended to be easily popped out tool-free. The idea was, if your cable breaks, you can still ride the bike in any gear, if you pop the spring out. Then it'll just follow under whatever gear you put it in. I've even been able to shift while riding, by reaching back with my toe (pointy toe old-fashioned cycling shoes)
They took away that feature for NR and SR, but only the tool-free aspect. You can still pop the spring out, but not with just fingers.
Zeus kept that feature for their Campy-clone rear mechs long after Campy had taken it away.
Liked 1,912 Times
My week end project:
Smiles, MH
Smiles, MH
Liked 2,831 Times
Shades of a stolen catalytic converter
cut off chain…
cut off chain…
Quoted: 987 Post(s)
Liked 641 Times
OK, I ordered some of the sealed-bearing pulleys, the price seems so reasonable. I probably should have tried a set of the eBay Shimano's as a comparison.
OK, I can do this. Indeed, I did it last year, too many projects ago. My big Q was where to insert the short end of the spring. Interesting you mention the Record and Gran Sport -- I have a project with one of the latter to deal with and, alas, my wife's bike with a Record was stolen.
Yikes -- I've seen photos of BF-109 aircraft dredged out of Dutch lakes after 80 years that didn't look that grungy. Like I said, I've led a sheltered life when it comes to bikes (Ride in the rain? Are you nuts? ) Wishing you luck on the re-hab!
As Mad Honk said, install the spring with the pusher end outside the paralellogram. I find it easy enough to snap it into its working position by hand. The previous Record (steel/bronze) mech, and the Gran Sport before it, had a spring that was intended to be easily popped out tool-free. The idea was, if your cable breaks, you can still ride the bike in any gear, if you pop the spring out. Then it'll just follow under whatever gear you put it in. I've even been able to shift while riding, by reaching back with my toe (pointy toe old-fashioned cycling shoes) They took away that feature for NR and SR, but only the tool-free aspect. You can still pop the spring out, but not with just fingers.
Liked 1,912 Times
It was on my Trek 770 bike that was a factory build for the team members. In storage with six other bikes when an arson fire happened. In all about 11K in damaged bikes, that fortunately was covered by my homeowners policy. Now I am trying to rehab some of the damage. It looks rough, but you have before picture. Now to get the after picture. Yellow, orange, or red pulleys? Smiles, MH
