TerraTrike Rover 8spd Question
Bikes: Specialized Crossroads, Shogun roadie
Hi all, I live in NE Ohio and am nearing being able to purchase a trike. Catrike's, etc. are out of my price range and I think I have settled on the TT Rover. How does the 8spd handle hills(not mountains, just hills). I'm not in Olympic shape, but better than some. I will mostly be on the hike and bike, but also want to ride on the road. I know Peter C has a Rover and loves it, I was just wondering what everyone's thoughts were.
Quoted: 1572 Post(s)
Liked 643 Times
Number of speeds has almost nothing to do with how well a bike or a trike will handle hills. The short, quick test is the number of teeth on the largest rear cog. If everything else is similar my bet is you'll find the number of teeth on the big rear cogs are identical. Consequently hill climbing will be identical too.
mriley
Bikes: vintage Schwinn
I just bought a TT Rambler with 8 speed SA hub, just like the Rover. (The Rambler is a little lighter and I liked its looks - that's why I bought it instead of the Rover.) It handles hills just fine. Sacramento is not as hilly as Ohio, but there are some hills around Folsom Lake. Nothing I could not get over, and I'm 70 years old. The range of gearing is what's important, and I think the Rover is about 25 to 75, high enough for a trike. I think you'll be satisfied. Don't forget to use some kind of pedal restraint, like heel straps or clip-in shoes, just to prevent your leg being caught under the axle in case your foot is shaken off the pedal by a bump.
M Riley
M Riley
Thanks for the replies! I will definitely buy clipless pedals when I get the bike.
Can someone explain the difference in the Rover 8 and the Rover Nexus 8? I'm assuming better quality parts, but is there a significant difference? Can I shift gears while pedaling with the Nexus set up?
I'm not sure about the difference between the S/A and the Nexus. Probably reliability. Shimano seems to be the acknowledged leader in IGH tech. Either option gives a low gear of about 24". Most trikes have lower than that. At the other end, even the 80" is on the low side of normal. I tend to assume that the gears on a bike (or trike) reflect its capabilities. In this case, it just is not designed to go fast or to climb crazy-steep hills. But, that's what I would expect for a ruthlessly-cost-reduced model.
Bikes: (3) 1970's Raleigh Sports, (1) 1968 Robin Hood 3 speed, 1974 Raleigh Grand Prix, 1976 Raleigh Grand Prix, 1969 Peugeot UO-18, 1971 Peugeot UO-08, 1980 Giant road bike, 1954 Humber, 1940ish Hercules Popular, 1963 Dunelt, 2007 Trek 3700 mountain bike
From the TerraTrike web site: "The Rovers are also available with the newer, lighter and more mechanically advanced Shimano Nexus drives. These drives not only shave off added weight but allow you to shift under load." That means pedaling!
As for climbing hills she doesn't have any problem with them. She's 63 and in good shape. The SA hub on the Rover 8 is geared pretty low. I test rode her trike and found the gearing on the top end too low for me. So I bought a Tour II for myself. We both still ride our DF bikes but those trikes sure are fun!
Palmer
Quoted: 1671 Post(s)
Liked 1,826 Times
Going down through the specifications, the two 8-speed Rover models seem to be identical except for the rear hubs. Rover isn't clear if they provide the regular Nexus hub or the better "red band" model. The Sturmey-Archer 8-speed design, which debuted in 2009, is much simpler mechanically with far fewer parts, and it has a wider over all gear range with even steps that mimic the "alpline" gearing on all those millions of 'ten speeds' sold back during the 1970s. The Shimano 8-speed, dating from 2004, is a robust design with, frankly, random, uneven gear steps. As can be inferred from the specifications, the Sturmey hub equipped model has gears of 24, 32, 36, 41, 47, 53, 61 and 79 gear inches. The Shimano Nexus equipped model has gears of 20, 25, 29, 33, 39, 47, 55 and 62 gear inches.
mriley
People are getting all excited about the fact that Terratrike is now offering the Shimano 8 speed hub. I have used both the Shimano (on a DF bike) and the Sturmey Archer 8 speed hub on a trike. Both work fine. I have been happy with both. I have (or had) about 6000 miles on the Shimano and it never even needed adjusting, a fine piece of equipment. I have fewer miles on the SA, but so far it has been just as good. As the previous poster said, the steps on the Shimano are unequal, but I never found this a problem. With the SA, you have to stop pedalling when shifting, but I always did that anyway with any IGH to save wear on the internals. In short, go with either one, but personally I like cheaper.
MRiley
MRiley
Palmer
Liked 1,826 Times
I thought about this as I rode my Sturmey-Archer XRK8(W) equipped bike yesterday. Did I 'stop pedaling'? The cranks never stopped rotating, but I definitely slacked off on pedal pressure right as I shifted gears. I'd think that qualifies as 'stop pedaling', but maybe not in the way folks imagine when they hear the term.
I did have to think about this - I started riding derailleur equipped bikes in the 1960s, and picked up the habit of slacking off pedal pressure when shifting any multigear bike.
Look at it this way; I'm hitting you over your head with a big stick. Do you want me to stop, or just slow down?
Palmer
Liked 1,826 Times
mriley
"Stop pedaling" means don't move them. Some of the old SA literature suggests pedaling backwards if you are having trouble shifting - not necessary now, but the hub shifts better (and longer) if you stop moving the pedals. Not sure what the reason is.
M Riley
M Riley
Whether you pedal an IGH or not during shifting, is irrelevant. What is relevant, is how much 'load' or 'torque' you apply to the pedals during shifting that matters. Mating gears don't like to move laterally when their teeth are loaded, so simply backing-off the pedal pressure is enough to appease most gearboxes.
Bikes: 2002 Dahon Boardwalk 1, 2003 Sun EZ-Sport Limited, 2011 TerraTrike Path 8, 2018 Gazelle Arroyo C8 HMB
From the S80W manual:
From the current Rover manual:
From the previous Rover manual:
I believe the docs on my Path also said that soft pedaling (which would mean, spinning the pedals with minimal torque while shifting) was OK, but TerraTrike has backpedaled (pun fully intended) from that statement it seems. But, I would think that torque is the problem, not movement - I'd guess that TT just had too high warranty claims from people who thought they were soft pedaling.
Originally Posted by Sturmey-Archer
1.3 Gear Changing
Stop pedal and select the gear required, then go on pedaling. If the bicycle is stationary simply select gear required.
Originally Posted by TerraTrike
Shifting
Your Rover 3 or 8 will arrive with an internally geared hub in the rear wheel. In order to shift, STOP PEDALLING (coast), shift, begin pedalling again. The trike doesn’t have to be stopped to shift into another gear. However, it’s important that you DO NOT pedal when shifting. Pedalling while shifting can have a number of consequenses. If the hub is damaged or malfunctions because of improper shifting technique, it WILL NOT be covered under warranty.
5. You do not have to pedal your Rover when you are shifting gears. Actually, it is better not to pedal or “soft pedal” when you shift gears. Due to our use of the internally geared hub, you can even shift gears when the trike is not moving.
Quoted: 523 Post(s)
Liked 230 Times
SA 8 speed hub failure
It's interesting that there is a posting on Bentrideronline by TNRambler titled Internal Gear Hub Question IGH8speed. He lent out his trike equipped with the Sturmey Archer S80 8 speed hub and it came back with only 2 speeds. The information from Terratrike clearly states that SA hub failure will not be covered if the breakage is caused by improper shifting. How does one prove the problem is NOT caused by pedaling while changing gears? A replacement hub is at least $175.
There's a second set of posts in the trike section of bentrider with the title TerraTrike Path - Upgrade or Replace? by a poster with the name Zaphod Beeblebrox. Take a look at the replies about half way down the page from some people who have had either the Rover or Rambler with this hub. All hubs can fail eventually, especially if they have been abused or used beyond the limits they were designed for. Low mileage failure should be rare for a well designed hub though.
Palmer
Liked 1,826 Times
Yep. But also in that thread is a poster who got new internals warranted from Sturmey (their customer service has been great for most folks), and a link to a youtube video where a fellow took his non-functioning SA8(W) hub apart, cleaned it, relubricated it and then it worked fine (an approach which would be $175 less out-of-pocket than your suggested $175 replacement cost). Also, while SRAM and Shimano don't support their hubs with retail availability of spare component parts, Sturmey does. Many of the internal parts for their 8-speed hub can be purchased individually.
Anybody Know the hub width of the Single speed Rover at $699 ? Somebody told me it was the same as the Nexus 8's at 135mm. Have a special project and need a 135mm OLN width and do not want to spend as much as we will be gutting most of parts anyway. Thanks
Quoted: 523 Post(s)
Liked 230 Times
"Anybody Know the hub width of the Single speed Rover at $699 ?"
Ask this question of Ashley Guy of Utah Trikes www.utahtrikes.com. Until recently they were a very large dealer for Terratrike products until the company decided to ban dealers from selling long distance.
