Cracked frame 2016 Trek Emonda
Bought this 2016 Emonda in mid 2017. There were no marks, scuffs, anything (it looked brand new), when I bought it 2nd hand. In late March 2019 I noticed cracks in frame (pictured) under seat pole, on both sides of frame. I'm perplexed how this has happened. No drops, no accidents, treated well etc. Has anyone else seen similar cracks on other Trek bikes? I found out later that the lifetime frame warranty only applies to 1st owner. Trek Australia have said they're not willing to do anything under warranty. They also refuse to assist in any other way such as providing store credit of any amount on purchase of new bike.
Is this acceptable that a 3 year old frame has cracked when there are no signs of damage to bike (apart from cracks)?
I have had this bike serviced several times at Trek previously. I've been told on each occasion that the bike is in good condition.
Finally, if the original owner did something that has now caused the cracks, would it take 2 years to be noticeable?
Advocatus Diaboli
Quoted: 4735 Post(s)
Liked 1,532 Times
Sounds like a run o'the mill asplosion.. FYI, you can't post pics until you have another 10 or so posts on BF
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
I have a 2015 Emonda SLR with 22,000 miles. Zero problems not caused by me.
Which frameset is yours?
Should Be More Popular
Quoted: 22598 Post(s)
Liked 8,925 Times
You are not the original owner so warranty does not apply. Sad.
Wasn’t it @waterrockets who had an issue with a Trek frame defect and could not get it replaced since he was not original owner??
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
Can you contact the original owner? He might want that bike you "borrowed" from him back for a few weeks.
Mechanic error or did you adjust the clamp? Send it to Calfee and don't look back.
Quoted: 20810 Post(s)
Liked 9,456 Times
Are the cracks just cosmetic/in the paint? Wouldn't be surprised if that were the case.
Regardless, no, you're not entitled to any type of warranty support/coverage; it's one of the primary benefits of buying new and shouldn't be expected when buying used.
On Your Left
Liked 2,433 Times
Quoted: 24 Post(s)
Liked 42 Times
I also wouldn't be surprised if it was just a crack in the paint or clear coat (or whatever finish they use).
If it is a true carbon crack, it could be repaired. I snapped off a seat stay on a Cervelo carbon frame about 5 years ago in a crash. The seat stay was broken all the way through. I sent it to a carbon frame repair place (can't recall who I used) and they repaired the frame. As I recall it cost about $300. I have since used it outside for the last 5 years and it has been perfect. They just rewrap the area with carbon fiber and epoxy. It would probably be stronger than the original carbon.
Quoted: 18377 Post(s)
Liked 4,512 Times
Quoted: 275 Post(s)
I didn't read all of the comments, but, did you do the tap test? The squeeze test?
Looking at this... doesn't look good.. But I've had some ugly cracks that wound up just in the paint.
Although, I should state for the record that I, personally am super paranoid, especially after my latest crash.. so, I see a crack I'm not taking ANY chances. It's unfortunate this happened to you.
Liked 4,512 Times
Trek Decoupled Frame?
It is hard to say what I'd do. I agree with @motosonic, that perhaps a little more testing.
Then, I can't say what I'd do.
How aggressive of a rider are you? If super aggressive/racing, then likely replace.
I'd be tempted to mark the ends of the cracks to monitor for progressing, then keep riding. Perhaps use the bike on a trainer, or for more mundane rides, at least until you determine your comfort level.
Wrap with Hemp?
Wrap with Hemp?
Quoted: 663 Post(s)
Liked 496 Times
In that particular area it would be difficult to get complete compaction of the plies causing air pockets that would result in the tendency to get some movement in the frame. I suspect it is not likely to get a catastrophic failure judging from what is visible but I would monitor the area regularly. The other course of action would be for a repair shop to grind down into the carbon to reach the solid laminate and build up with proper plies.
There is a video of a well known carbon frame where the investigator cut the frame open which revealed such air pockets. I did not bookmark the video and don't wish to search for it now. It only takes a little lack of care to get very poor result.
Quoted: 3240 Post(s)
Liked 2,086 Times
Others have stated to ride and watch.
Personally I would just lay out $400 for a Chinese carbon and walk the parts over. You'd likely need a new -bracket if that Emoda is press-fit. I'd go BSA and new crank.
Bikes: 2023 Canyon Aeoroad CF SL, 2015 Trek Emonda SLR, 2002 Litespeed Classic, 2005 Bianchi Pista, Some BikesDirect MTB I never ride.
Quoted: 647 Post(s)
Liked 136 Times
Meh, I'd keep riding it if it were me. If you're not a super heavy guy, and aren't riding on cobbles, or off road, I'd just keep riding it and monitor it for crack propagation. My 2010 Trek developed a few of these hairline "cracks" and it didn't bother me. I kept an eye on it, and it never became a problem. I wasn't even convinced they went all the way through the frame. Your photos look a little bit worse, but not by much...they may just be surface cracks and not all the way through...
Quoted: 647 Post(s)
Liked 136 Times
LOL the majority of the "very helpful" comments are either "keep riding/keep an eye on it/it can be repaired", and you end up buying another frame and trash this one.
