Experiences with Carver rigid steel fork?
Quoted: 17 Post(s)
Hi,
I'm using an old steel Stumpjumper frame to build a bikepacking bike for a long term trip through Latin America and looking for a rigid steel fork to replace the Rockshox Mag21 fork. Ideally the fork would have both canti mounts and a disc rotor mount for ultimate flexibility, but I'm also open to canti-only.
I found a promising option from Carver bikes (bikeman.com) at Bikeman Carver Bikes Steel Rigid Mountain Fork, 1-1/8'' 410mm
but I haven't been able to find any reviews or forum posts about this fork so I'm hesitant to order it. I searched in this forum and it's been mentioned as an option a couple of times, but nobody had actually used it.
I'd really appreciate if anyone could share their thoughts/experiences about this Carver rigid fork. Or if you have a pile of old 1 1/8" threadless forks and might have one that would fit the bill, please let me know! Thanks!!!
Can't help with Carver fork information.
I've had 8 years so far out of my Soma Fabrications rigid replacement. Absolutely no installation, handling or maintenance issues. This is on a bike that I use for heavy touring and thrashing through the woods at times. They're a well respected company that does very well finishing their products. I lust for one of their complete bikes!
Likes For North Coast Joe:
Quoted: 17 Post(s)
Thanks for the recommendation! Looks like Soma still sells their 26" canti rigid fork:
https://www.somafabshop.com/shop/pro...40mm-80mm-3476
It's beyond my budget but I'll keep an eye out for a used one.
Bikes: There is always room for one more.
Quoted: 184 Post(s)
Liked 391 Times
I have the Carver rigid fork on this bike, no disc brake mounting tabs cantilever only. No issues or problems. It's not light but it's lighter than the suspension fork it replaced.
Don
Don
Likes For GeezyRider:
Quoted: 714 Post(s)
Liked 800 Times
The axle to crown length on the Soma is a bit too long to replace a Mag 21 fork. The Carver is a more reasonable replacement. Its a steel fork, I don't know what kind of problems you could have with it. The welds would have to be pretty bad to fail. At that price point, all of the forks will be of Chinese origin.
Likes For dsaul:
Quoted: 17 Post(s)
Thanks!
Quoted: 184 Post(s)
Liked 391 Times
I rescued this bike (late 90's Giant Iguana) from a dumpster at my Sister in-law's beach home. I never rode it with the original suspension fork so I can't compare it to that. All of my road bikes have steel forks with curved fork blades which helps to absorb road shock/vibration. With the 26x2.1 tires inflated to 65 psi on this straight bladed fork, it feels similar to my road bikes. I replaced the drop bars with a flat bar and I feel little or no vibration through the handlebars. It feels solid but not harsh if that makes any sense.
I haven't noticed any flexing or handling issues but I don't ride single track or anything technical on this bike. It is ridden primarily on various road surfaces with some riding on crushed limestone or gravelly/sandy trails and pathways. I replaced the original stem with a shorter one and it handles just fine and doesn't feel at all twitchy. For me, this was a good low cost option that I am well pleased with.
Hope this helps.
Hope this helps.
Don
Don
Quoted: 184 Post(s)
Liked 391 Times
I just re-read your original post and noticed that you are going to be bikepacking with your bike. I don't know how much you intend to carry but I think this fork would handle a loaded front rack quite well.
Best of luck. Sounds like a great adventure!
Don
Don
No experience with Carver, however I recently built a rigid 26er using a Sunlite fork: https://www.modernbike.com/sunlite-r...-fork-26-black
Super inexpensive and I have no complaints so far.
If you wanted disc capability down the road Origin8 has a fork that can handle either setup: https://www.modernbike.com/origin8-c...hreadless-fork
Likes For Synack42:
Quoted: 17 Post(s)
I'm still in the process of experimenting with bikepacking bags and racks, but I think it's likely that I'll use a mini front rack to support my day pack and fork leg cages for cylindrical objects.
I have the Carver Fork and it works well. I also considered the Soma fork but it was twice the price. I’m using it on a 2001 Marin Hawk hill. I went with the 410mm.
Quoted: 883 Post(s)
Liked 823 Times
+1 with above. Also, I used the Sunlite fork on my daughter's bike and it was adequate for her application.
