Which new wheel do I need?
I hit a tractor recently and bent my front wheel, and need to fit a new one, it is a Mavic CXP 22. And the tires I use are a 700x23c. Can you recommend any good value front wheels that will work with this size?
thanks again!
thanks again!
Likes For Outrider1:
hi there milomcc
many thanks for this great idea.
food for thoughts - i am happy to read this
Likes For apollodriver:
Quoted: 1770 Post(s)
Liked 1,296 Times
Mavic Aksiums are not expensive and bullet-proof.
Likes For bruce19:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
You want to intentionally ride a bike with mismatched wheels. For what? A savings of $20. I would never do that. Find other places to save the $20. Skip beer for a week. Mow someone's lawn. Anything.
Likes For Phil_gretz:
Is there a problem with mismatched wheels or similar size? Isn't the point of a bike to be ridden?
As for a recommendation, the OP asked for a 'value' wheel, which indicates a limited budget. That, in turn, indicates a probable unwillingness to replace a rear wheel that is functioning well. A desire for value also probably means the OP won't be interested in buying a used or NOS CXP22 wheel or rim from ebay or having his LBS rebuild his wheel with new rim and spokes.
Before making a recommendation, though, I'd verify some things like budget, how much time the OP is willing to stay off his bike, whether he can build his own wheel.... I'd verify rear DO spacing. I'd probably mention Craigslist for local used wheels and Velomine.com for Mavic and Sun wheels - and I apologize to OP for not doing that in my first post. Craigslist may even offer a wheel with the right hub and a CXP22.
Velomine has some low cost Mavic wheelsets. They may be willing to sell a front wheel, especially one of their low-priced wheels with Sun rims. If budget is really tight and he can't build his own wheel, his LBS may be his best bet for lowest cash outlay.
Biking has always been a low-medium budget priority for me, and I've never had a lot of disposable income. My wheels match now, but I rode for 30 years with different rims on front and back. Obviously I enjoyed the ride.
I'll assume you don't think I should have retired from biking until my budget allowed me to discard a perfectly good rear rim or, worse, wheel.
Bikes are for riding.
Yes, I'd replace one wheel on my car if the specs were right, if I needed only one wheel. I don't have a dual sink bathroom, but I would want to keep the faucets the same, even if I had to replace only one, but if the budget were tight and I didn't contemplate selling the house in the near future, I might argue for mismatched faucets.
If I have to choose between function and appearance, I've almost always chosen function. I think that's almost always the better choice.
Likes For philbob57:
Quoted: 581 Post(s)
Liked 921 Times
Making sure your wheels are matched is an act of slavish obedience to style over substance. For every one second you waste concerning yourself about matching parts you are missing two seconds of riding.
To the OP:
There are many many wheels available with the correct 700C rims. You probably want a narrower one (like ~13-18 mm inside width) if you are using 23mm tires.
You can either visit an LBS and see what they have, look on craigslist/kijiji/facebook for people selling wheels, or order something online. Or you can order another rim and swap the hub and spokes over. If you get one that is dimensionally similar to the original Mavic rim, you can tape the rims together and move the spokes over one at a time.
To the OP:
Likes For ClydeClydeson:
SE Wis
Quoted: 2751 Post(s)
Liked 3,409 Times
Likes For dedhed:
Quoted: 325 Post(s)
Liked 109 Times
Yes. i've done this before, once because I needed a functional wheel to be able to drive my car, and another time as a stylistic choice.
The premise of this question is flawed, as it assumes a power dynamic that does not exist in my marriage. My wife and I take time to hear each other out on all matters. So in the event that I wanted to install non-matching sinks, as long as she understood my POV and it was well reasoned, she would most likely support my decision. Otherwise, she would voice her concerns and we would talk about it, as people in a healthy relationship do.
That some people are vain and overly fixated on appearances, to the point that they put form over function? Yes, I have met Apple, Rapha, and Cervelo fans in the wild.
Would your wife allow you to put mismatched faucets in a dual sink bathroom?
You get the point, I hope.
Quoted: 325 Post(s)
Liked 109 Times
https://www.amazon.com/WheelMaster-7.../dp/B000AO7DBA
At 36 spokes, it's probably over-built, but it should work.
Zip tie Karen
Liked 1,542 Times
As for power dynamics, or whatever nonsense you've been taught...pfft. Real men don't deal in that. At all.
I cannot imagine a scenario where I would have any input on faucets unless it would be concerning durability, serviceability, or some nuance of the plumbing or some such. If my wife wants gold leaf on the master vanity, well, then we'll have a sensitive conversation sharing our points of view and then hugging it out. Sheesh.
My wife and I have the sense not to debate trivial things. She has her domain expertise, and I have mine. We're complementary, as God made us.
Quoted: 325 Post(s)
Liked 109 Times
Wow, you sound extremely secure in yourself and not at all like someone that is projecting false machismo as a compensating mechanism. I applaud your resolve. Let us know if you can get permission for a bike ride weekend, mmkay?
Likes For BoraxKid:
Liked 1,296 Times
I think the question may be...is it a matter of function or aesthetics? I have been riding for over 40 yrs and, although I generally ride matched wheels, I have ridden mismatched wheels with no issues.
Quoted: 1953 Post(s)
Liked 2,192 Times
It comes down to hubs. You will have to decide if your current hubs are a lot better than the hub in the cheap wheel; most likely it is. That would be the determining factor for me.
If I had a decent damaged front wheel, and was budget minded, I would look for a cheap used wheel that would get me by until I found a replacement rim and lace it to my existing hub.
I have always run matched wheels, but have no issue running an interim mis-match.
On the matched/mis-matched discussion. There is probably an argument to purposefully run mis-matched rims especially if different size tires are being used; front to back. It is readily accepted to have different spoke count, why not a narrower rim in front for a narrower tire.
John
John
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2628 Post(s)
Liked 5,756 Times
Don’t care to enter into the form vs function, vain vs practical debate, but want to know the backstory about hitting a tractor.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 250 Times
Don't ride with mismatched wheels. If you do it will suddenly become very quiet, the clouds will open up, and a bolt of lightening will come down and blow you to kingdom come.
Quoted: 7666 Post(s)
Liked 3,537 Times
As far an form and function .... its a freaking bike wheel. ALL bike wheels have approximately the same form ..... a few more spokes or fewer, except for those all-carbon- tri-spoke wheels from Spinergy (are they still around?) Oddly, every serious time-trial bike i see has mismatched wheels ... what do the pros, know, right?
I just realized last night that my Cervelo clone (and be careful talking about Cervelos---they Are special ) has different wheels front and rear---both Vueltas, but different models.
However ---- the bike Always had "mismatched" wheels because (as with most of my bikes) it has a 20- or 24-spoke front and a 24- or 28-spoke rear wheel. Oh, noes!! Mismatch? The form varies, so they will not function!!!!
And any one who uses the phrase "real men" in any sort of an unironic way ... I pity that person and hope for his eventual enlightenment.
