Let's see your Marinoni
Phyllo-buster
Quoted: 2299 Post(s)
Liked 2,059 Times
84 Gianella made by Marinoni
Quoted: 1374 Post(s)
Liked 1,762 Times
'84 Special, badly in need of repaint, relatively successful 650b conversion:
Fuggedaboutit!
Fuggedaboutit!
Quoted: 22 Post(s)
Bikes: 1938 Raleigh Record Ace (2), 1938 Schwinn Paramount, 1961 Torpado, 1964? Frejus, 1980 Raleigh 753 Team Pro, Moulton, other stuff...
Quoted: 26 Post(s)
Liked 11 Times
Good grief, are all Marinoni owners 11 feet tall?!
Now look here, sonny---you don't want to throw down with me when it comes to crappy paint! I'll out-crap anybody!
Hard to see from the photo, but mine was a Portland, OR frame that came with uncountable sub-paint rust spiderwebs. I sanded about a dozen spots down to metal, then hand-mixed mis-matching paint and hand-brushed the scabbed areas, badly. There were so many spiders on the front half of the top tube that I stripped it down to metal and rattle-canned it, in a not-even-near match blue. So the frame is scabrous, and the front/rear top tube halves don't match for color, or texture. I also inexplicably badly hand-painted a line between the two halves, thinking it would make the transition look smoother, but which only makes it look worse. The line/strip doesn't match the other two colors, so it's a mis-matched tri-color top tube. Then, since I evidently don't understand surface or primer prep, big hunks of the underside of the repainted half stuck to my rubber-coated frame hooks, leaving a big patch of exposed primer/metal.
Decals are flaking off, seat tube front reads simply "MARINON." That's what his friends call him. Drive-side down tube "I" is mostly gone.
BOOM!
*drops mic*
*walks off stage*
BOOM!
*drops mic*
*walks off stage*
Fuggedaboutit!
Fuggedaboutit!
Oh, BTW, I like the extended head lug, especially for a human of your height. I'm thinking that's kind of early for a '93 frameset, no? Mr. Marinon ahead of his time a bit? Or am I just getting old and forgetful? Rivendell's first frames were shipping in '94-'95, which is when it first entered my consciousness...
Fuggedaboutit!
Fuggedaboutit!
Quoted: 22 Post(s)
Been piecing this together since early spring and now that fall has arrived it is finally rolling. In the next few days I need to take some decent pictures to post up. A few more things I would like to do with it, tires, radial lace the front wheel…..you know it never ends!
1985 Marinoni, Marinoni Special, Serial Number: P513
The tube set is Columbus SL with a Columbus SP down tube. The fork crown and bottom bracket are Hitachi. The standard engraving on the lugs and Nagasawa inspired, Hitachi cast fork crown, produced by the lost wax method were the traditional ‘M’, but for a slight price increase could be ordered with either the Fleur-de-lis or Maple leaves. Customizing the tube set was a common practice for Marinoni, his blend to give the frame a little more stiffness. Another thing that Marinoni did that no one else did was to stamp the serial number on both the bb and the fork steerer tube. When Marinoni first started making framesets up until the mid-eighties, he was strictly building for racers and not the general population. His location up in Terrebonne, Quebec Canada was off the radar. You had to know of someone who knew someone to find out where he was.
Frame and Fork
1985, Marinoni Special, 54”, Columbus SL/SP double butted chrome-moly, Campagnolo Forged Dropouts
2014, Dropout Adjusting Screw Set
2014, CR-MO Seat binder Bolt
2014, King Ti Cages X2
2014, Ergopower Blocks EC-RE001
Handle Bars
2010, Zipp Contour SL 42cm
2014, BBB Cycling Extender BHP-20, modified
2014, Cinelli Milano Bar End Plugs
2014, White Lizard Skins DSP 2.5mm Bar Tape
Stem
2014, Deda Superleggero Stem, Black/White Decal, 110mm
2014, Stem Spacer, 10mm, Al.
Shift Levers
1985, Simplex SLJ 6311 shift levers
2003, Campagnolo Chorus, 10 Speed, Ergopower shifters
Headset
1985, Campagnolo Super Record, 25.4 x 24
Cranks
2013, Campagnolo Super Record, 11 Speed, UltraTorque 172.5mm
2014, Campagnolo Super Record, 11 Speed, UltraTorque External BB Cups, Italian 36mm X 24tpi
Brake Levers and Calipers
1985, Campagnolo Corsa Record aero/non aero Brake levers
2008, Campagnolo Chorus Skeleton Calipers
Saddle
2014, San Marco Regal E, Red Saddle, Xsilite rails, 230g
Seat Post
1987, Campagnolo Chorus Aero 575, 26.8, (1st Generation)
Cassette
1998, Chorus MK2 9 Speed, CS-19SP, 13 – 26
Chain
2014, KMC X10 SL Superlight
Wheels
1998, Campagnolo Athena hubs, Mexico 68 rims, 32 hole, 485g, Wheelsmith SS 14 gauge spokes, radial front, cross 3 rear, 213g per 32 units, Duristan™ Brass nipples
2006, Campagnolo Chorus hubs, Velocity Aerohead rims (O/C rear), 32 front 36 rear, 425g, Wheelsmith double butted SS 14/16 spokes, cross 3, 172g per 32 units, Duristan™ Brass nipples
Tires and Tubes
Specialized Turbo Sport 700c X 23mm
Derailleurs
2003, Campagnolo Record, rear, short cage
2010, Campagnolo Super Record, 11Speed modified with Veloce cage, front, braze on
Pedals
2013, Shimano DuraAce SH-PD9000
Cables
2014, Ashima Reaction Shifter Cable Kit, black
2014, Ashima Reaction Brake Cable Kit, black
Incidentals
Cable and Ferrule
Touch Up Paint
Cateye Strada Wireless Cyclocomputer, CC-RD300W
Head Set bearings
Measurements
Saddle to bar drop 10.0cm
Working on this!
Paint and Frame Restoration
Two Wheels Restorations, Pietro Masdea
Marinoni Fire in the Frame trailer https://www.youtube.com/watch?v=f-nZgOQk_EE
Frame and Fork
Handle Bars
Stem
Shift Levers
Headset
Cranks
Saddle
Seat Post
Cassette
Chain
Wheels
Tires and Tubes
Derailleurs
Pedals
Cables
Incidentals
Cable and Ferrule
Touch Up Paint
Head Set bearings
Measurements
Working on this!
Quoted: 503 Post(s)
Liked 466 Times
This is essentially a thread bump, because I really hope it keeps getting Marinoni entries so that we can see the evolution or variations in his designs over the years.
I'm fascinated that the "modern" features on my 1987 frame (post #4 ) - vertical rear dropouts, fastback seat stays, and rear brake housing stops - don't show up until notably later Marinoni. Never have seen another full chrome rear triangle (and everywhere under the paint). It has longer 43.5mm chain stays (love 'em!) and threaded fender mounts in the steerer tube and rear brake bridge. Anybody else have those?
When I wrote about about the serial number, Simonne M didn't indicate that this was anything other than a stock frame when it was sent to the the original LBS.
Long has your Marinoni triggered jealousy in me, having seen very few with sport-tour/tour designs. If I ever get around to getting mine repainted, I'm seriously thinking of having some sport-tourish braze-ons installed before the repaint. Chroming is out of the question, as is lengthening the chainstays; doubt I'd want to pay the upcharge to change to vertical drops. Yours came so well sorted-out straight from the Marinoni workshop.
My Marinoni-fu is imperfect, but my understanding is that any vintage frame with a "Special" decal on the left chainstay was a custom order. Yours doesn't appear to have a Special decal, so it may be a stock frame, but it clearly isn't a stock road racing frame. They'd never use that geometry and include all those braze-ons for a stock road frame.
I don't think you're seeing "modern" features so much as contemporary sport-tour/tour features. Using vertical drops on a non-race frame with longer chainstays and fender mounts wasn't unusual in '87, especially for a North American builder. Schwinn Paramount touring models through the '70s had brazed-on rear brake casing stops, while the racing models used uninterrupted housing and clamps. The fastback stays don't strike me as particularly non-racing, but plenty of British builders used them throughout the '60s and '70s so they don't seem any more modern than wraparounds. I could only guess whether he thought fastbacks were better for non-race uses, or if he was just trying to add more visual distinction to that model.
I'd love to see more Marinonis posted here, especially some less-common models. I have a Boston/Terry-type small front wheel Marinoni buried somewhere, I've never seen another of those. The serial number scheme is very different from mine and yours, I always wondered if maybe Marinoni outsourced these.
Fuggedaboutit!
Fuggedaboutit!
Bikes: yes
Quoted: 1281 Post(s)
Liked 644 Times
Not a Marinoni, but Jocelyn Lovell apprenticed under Marinoni. I've posted about this bike elsewhere, I've done some more work on it but haven't taken updated pictures yet. I'll get to it. For the record it now has a selle turbo saddle; bar tape, and I had to go back to the Shimano 600 RD because the spring on the campy is shot.
But it's in good enough shape that I took it on an 80 mile club ride a couple weeks ago and me and the one other guy on a C&V bike rode at the front of the pack and had no issues keeping up with all the fancy new bikes.
Marinoni of pretty much any flavor is my grail bike and I will get one someday when budget a circumstances favor me. I think they're gorgeous, their owners rave about them, and they are uncommon enough around these parts that I'm pretty sure no one else will have one. Don't ask why a guy from Kansas has a thing for 70s-80s Canadian bikes but I do.
Quoted: 113 Post(s)
Liked 16 Times
1981 Pista Special - I still own and will not part with. SP with ovalized downtube. I'll post several more that I have owned, though some photos are on an old laptop that is fried and I haven't tried to recover the HD yet.
1 Super Record bike, 1 Nuovo Record bike, 1 Pista, 1 Road, 1 Cyclocross/Allrounder, 1 MTB, 1 Touring, 1 Fixed gear
Quoted: 113 Post(s)
Liked 16 Times
1992 Special - no longer own
Quoted: 113 Post(s)
Liked 16 Times
a repainted '79/'80
apparently I don't have any good photos, this also featured the maple leaf cut out.
Quoted: 113 Post(s)
Liked 16 Times
An '88 special. fleur de lis cut-out. it this was a 60 I would still own it. full 1st gen chorus.
Quoted: 113 Post(s)
Liked 16 Times
apparently I only have this sellers NDS photo of an '89 corsa.
Quoted: 113 Post(s)
Liked 16 Times
Also had this 96 corsa for my partner for a little while.
I don't regret selling any of them, but i would love to find and early to mid 1980s machine or even a later 1970s in my size. 61/62. Something with eyelets and clearance for a 28 or 32 with finders would be lovely.
Quoted: 1624 Post(s)
Liked 2,661 Times
