Bigger computer needed?
Bikes: Specialized Roubaix Comp, Specialized Crosstrail
I’ve been using a Garmin 830 for a few years, but it gets more difficult to see the screen, especially following directions on the map. Eyesight is not what it was. Thinking about upgrading to a 1040. Do you find it more helpful? I looked at DCR’s review and I probably don’t need all the information that is available on it, i like the bigger screen. What is your experience with it?
No experience with actual use, but I compared the 1040 Solar with the Wahoo Element Roam, the new version, and preferred the latter’s visibility. You can easily zoom in and out to increase or decrease the size of the characters. I’ve been using it for a week now, and have no complaints, except that the dual band GPS doesn’t seem to improve tracking as much as they claim.
ignominious poltroon
Quoted: 2249 Post(s)
Liked 3,453 Times
The Edge Explore 2 is now on sale for $250. It has a similarly large screen and a subset of the functionality of the 1040/840/540, but it might have everything you need.
Likes For Polaris OBark:
Quoted: 6215 Post(s)
Liked 4,824 Times
If your eyes are getting old and you need readers, then you'll probably eventually have trouble with the 1040's bigger screen as the condition progresses and you go from needing 1.25x magnification to over 2.5x magnification.
You might consider tinted or clear bifocal safety glasses. They are inexpensive and if you keep several spares at the house, you won't mind if you drop them and they get run over by friends you ride with.
https://safetyglassesusa.com/collect...safety-glasses
If nothing else, they might allow you to delay a new GPS purchase till they come out with the Garmin Edge 1060 plus. Of course then you'll have to weigh whether you want to hold out for the Edge 1070! <grin>
Quoted: 3250 Post(s)
Liked 2,095 Times
The fewer the data fields, the larger each data field. Maybe just display speed, ride time and distance ?
Likes For Steve B.:
Quoted: 242 Post(s)
Liked 458 Times
While I do not own a 1040 I've recently played around with one for a few days. I was setting it up for a customer so I set up all the pertinent data and created the varied data screens. It is certainly a large display and the customization ability is amazing. It is certainly larger than the 830/840, I have both and use the 840 daily, and doesn't look too large on a bike handlebar of stem mount. It is no different than the 840 just a much larger screen.
I prefer the 840 because size does matter to me and the cost is less which is also important.
Quoted: 2606 Post(s)
Liked 1,939 Times
Cut out a row of data fields and see if you still need a bigger screen. You can always change pages if you really need or want to see all those fields, but perhaps you'd be better off getting your head up and watching your road/trail/surroundings.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
I think what the OP is explaining is that he is having trouble following the map, not seeing data screens so I think the suggestion to use bifocal safety glasses is a good one. Something I did was get the stick on bifocal lenses on Amazon to put in my Oakley sunglasses. I also lately have been riding with a pair of butt ugly prescription safety sunglasses my employer provided.
Quoted: 828 Post(s)
Liked 1,666 Times
You can set up several screens in the 1040, each with only one or two data fields, then scroll through the various screens. The data will be bigger.
For that matter, you can probably do the same with the 830, but there is no way to make the map larger.
Quoted: 1952 Post(s)
Liked 2,016 Times
If you don’t need the latest training metrics, get the Explore2. I’m happy with mine.
Likes For DirePenguin:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2596 Post(s)
Liked 5,673 Times
I also use photocromic lenses with bifocal inserts which are removable. Getting custom lenses for the inserts was cheap because declined all the special treatments and coatings. Thought it would screw up my distance vision while riding but made distance and close much better and no issues with the line between the two.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
just another gosling
Quoted: 3897 Post(s)
Liked 1,947 Times
Same here. I just bought a 1030 on ebay, works great, solves the visibility problem, didn't break the bank. There is a definite learning curve, whole different user interface.
Results matter
Results matter
