Suggestions for long sleeve jerseys
Bikes: 2021 Giant TCR Advanced Pro 1+ Compact
Hi guys! New to this forum here
I was wondering if you guys had any suggestions on shorter length long sleeve jerseys, primarily when it comes the length of the sleeves. I recently purchased a specialized RBX long sleeve jersey and have noticed that the sleeve length is too long by about 2 to 3 inches.
The few long sleeve jerseys I’ve purchased through amazon were also the same. Also I like the arms fitting pretty snug, as it bothers me when extra fabric flaps around while riding
I’m 5’2” @ 170 lbs and generally find large to be the best fit at the moment for the current short sleeve jerseys I own.
TIA
TIA
Quoted: 6963 Post(s)
Liked 10,963 Times
TIA
TIA
Likes For Koyote:
Expired Member
Quoted: 3674 Post(s)
Liked 5,431 Times
Yeah, probably no surprise to you that a jersey that fits your middle will be too long, body and sleeves. You can roll up the sleeves but you'll have to live with the pockets down around your butt. I know this from personal experience.
I've found myself wearing my long sleeve jersey less and going short sleeves + arm warmers (often + vest) for more versatility; you might be able to find some in the appropriate size. Most of my rides have long-ish climbs so I'll pull them down if I get warm, and pull them back up for the descent. I also use them for my night-time soccer league; they are easy to discard as I heat up.
Quoted: 4560 Post(s)
Liked 2,802 Times
Check AeroTech. They made cycling garments for real world cyclists, not just toothpicks on wheels. A looser fitting medium might be a better fit in the sleeve.
Bikes: 2021 Litespeed T5 105, 1990 Gios Compact Pro 105
Quoted: 167 Post(s)
Liked 325 Times
Decades ago I got a long sleeve gray Pearl Izumi jersey that I wear on cold rides. An actual Made in the U.S. label.
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
Another option might be a "fall" rated thermal base layer underneath a regular short sleeve jersey. All my thermal base layers have significantly shorter sleeves, probably exactly to avoid bunching around the wrists. (I generally have the opposite problem though, of sleeves being too short.)
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
Likes For sfrider:
Liked 10,963 Times
+1 to short sleeve jersey + arm sleeves. I have the same problems finding proper length long sleeve jerseys, and they all seem to be too loose as well. I have a set of thin “sun sleeves” and a thicker pair of arm sleeves, then I’ll layer on top of that if necessary.
Quoted: 550 Post(s)
Liked 325 Times
Most long sleeve jerseys are club fit. Voler makes race fit, and Verge Sport has skin fit.
Liked 10,963 Times
OP has not been back since the day he started the thread. There seems to be a lot of this stuff lately. New poster wants advice or reassurance, starts a thread, gets a whole bunch of suggestions, and then never sees them.
Perhaps, in addition to requiring a minimum number of posts before putting up photos, there should be a minimum before starting a thread. Might cut down on the noise pollution around here.
Quoted: 6193 Post(s)
Liked 4,809 Times
Liked 2,802 Times
