Excellent water bottle cages - cheap
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
I've gone through a few different water bottle cages, mainly aluminum and steel versions. However, I've found my favorite. It is not only the lightest and most flexible, its one of the most secure and cheapest.
I paid $5 at ....
wait for it
Wallmart
Its called the 50Strong water bottle cage made from plastic (yes, but if you think about it, it is the perfect material for this application: weaker than any frame material so any hits won't break the frame with an accidental hit to the cage, flexible, lightweight, cheap and won't corrode or mar frame)
https://www.walmart.com/ip/50STRONG-...Black/38389221
I highly recommend these made in the USA cages!
I paid $5 at ....
wait for it
Wallmart
Likes For Symox:
Quoted: 6966 Post(s)
Liked 10,965 Times
What is going to hit the water bottle cage? I’ve never ever had that happen, nor have I ever heard of it happening.
Likes For Koyote:
Quoted: 529 Post(s)
Liked 255 Times
I had one similar to that, but probably different, and it broke. Somebody put a young child on my bike. She stood on the water bottle holder, and that was the end of it. It didn't break from carrying bottles.
I like bottle holders which can take various sizes of bottles. For example, I can put a 1.5 liter bottle in my bottle holder. The one shown above, can probably do that too, as the plastic is flexible.
Expired Member
Quoted: 3674 Post(s)
Liked 5,433 Times
Wouldn't look good on my bikes. Does sort of resemble carbon if you squint....
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,532 Times
Yeah, plastic/nylon works. I had a pair of the Arundel Sport version of their Dave-O bottle cage on the bike for a little while, til replacing with CF editions. Many of the plastic ones out there like the Wally linked version look like takeoffs of the Arundel design fwiw.
Likes For Sy Reene:
Quoted: 18416 Post(s)
Liked 15,556 Times
I
Quoted: 804 Post(s)
Liked 2,985 Times
where's the Bling?
Quoted: 345 Post(s)
Liked 237 Times
The bling will be still in your wallet with the money you saved
Likes For Symox:
Quoted: 3952 Post(s)
Liked 7,298 Times
Likes For tomato coupe:
Quoted: 4560 Post(s)
Liked 2,802 Times
I've used 50Strong cages on a couple of bikes for two years. They work fine on the downtube -- just enough tension to hold the bottle but easy to use. Enough colors to suit most bikes.
However the 50Strong cages lacked sufficient tension to reliably hold my 24 oz bottles on the seat tube -- hard jolts on pavement or gravel would dislodge the bottles. So I switched both bikes to different cages with more tension on the seat tubes only. Those cages -- Tacx and some brand I don't recall -- had a little too much tension to easily grab and replace the bottle on the downtube.
So now I have mismatched bottle cages to go along with my mismatched bottles, and mismatched color accents in cables and bar wrap.
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
Quoted: 1851 Post(s)
Liked 679 Times
Despite the cost, I love Arundel cages. I have one set of Dave-O cages that have been on their fourth frame. The first two frames they were on broke in crashes. Sure, they were $50 each, but they've lasted for a very long time, and I've never lost a bottle with them.
Over the years, I've tried other brand cages - largely to try to save money - and I usually end up replacing them with Arundels.
Quoted: 874 Post(s)
Liked 2,288 Times
On my vintage road bikes I use vintage cages , mostly Reg . On my wife’s new Electra Townie ebike we had Trek put a plastic handlebar mount with an insulated Camelback bottle . She likes the set up and the plastic seems strong enough.
Meanwhile, I spent ridiculous, indefensible $120 on a set of King Cage titanium cages for one of my bikes. It turns out they're probably my favorite cages ever and are worth every penny.
Likes For Hiro11:
Quoted: 345 Post(s)
Liked 237 Times
I use Cameback Podiums. They are excellent and fit securely in the 50strong. Also they aren’t hard to get the bottles out of the cage when riding. I use the 50strong on both the down and seat tubes
Likes For Symox:
Quoted: 874 Post(s)
Liked 2,288 Times
My wife is using the Podium for dirt and the Bontrager handlebar mount and loves it. Easy for her to access while riding and she likes her water cold and that seems to work for her.
Bikes: MBK Super Mirage 1991, CAAD10, Yuba Mundo Lux, and a Cannondale Criterium Single Speed
Quoted: 344 Post(s)
Liked 297 Times
I have the Planet Bike button cages on a couple of my bikes. $7 currently on various sites.
I've had some plastic cages, but I find that some bottles are slightly off-standard sizes, so with metal cages I can flex the arms a bit to get a tighter/looser grip on the bottles as needed.
https://cdn.shopify.com/s/files/1/00...g?v=1536877168
Likes For Leinster:
Liked 15,556 Times
Likes For indyfabz:
Bikes: 2019 Custom All City Gorilla Monsoon 2016 Synapse 2020 Orbea Gain M201 2020 State Bicycle All Road Bicycle Nomad SE
Quoted: 14 Post(s)
Thanks for the idea, do you ride rode, mountain, gravel? I have found the cheaper plastic ones are ok but if my bottle is slightly different they don’t spread much and in the cold (over time) tend to crack. The other problem I found with these are some fit fine, then others are very tight and I’ve launched bottles on my MTB and gravel rides. I too added King Cage titanium cages on one bike and after thousands of miles they have not moved one bit. It’s like anything else to me, you get what you pay for in many cases. If you want an inexpensive cage these are real good, but there is nothing wrong with a King Cage IMHO.
Liked 10,965 Times
My shop has a pair of them in-stock. Every time I am there, I pick them up and marvel at the light weight. But I just can't pull the trigger, especially when the SS King cages are $40 for a pair.
Likes For Koyote:
Quoted: 2952 Post(s)
Liked 3,106 Times
I got these from the LBS for my CX bike. Almost as good as the Specialized ones, but half the price. https://bikesmart.com/collections/bo...cts/domestique
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
A good water bottle cage IMO not only holds the bottle securely (going back uphill to fish a water bottle out of a ditch gets old quickly), but also doesn't hold it so tight I can't easily get it out when riding (especially on a long hot climb), while being usable without taking my eyes off the road. I never had luck with cheap cages though, and in 2008 or so got a set of Arundel Mandibles (or at least very similar looking). When I got a new bike in 2019 I got a pair of S-Works Rib Cage II's for it, which was purely a cosmetic choice. The Arundels would have worked just as well, it's just the design looked a little dated. Or, possibly, I was just ready for a visual change. Sure, the ribs were rather pricey, but relative to a new bike no big deal, and it also let the shop make a little money as well. They went through a fair bit of work to get me a test ride. But sure, relative to having the luck of encountering a cheap one that works really well, it's all just a splurge on cosmetics.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
Bikes: 2014 Cannondale Supersix EVO 3, 2015 Trek 520, 2017 Bike Friday Pocket Rocket, 2022 Moots Vamoots Disc RSL
Quoted: 285 Post(s)
Liked 267 Times
It's been 40 hours since this thread has been started... and nobody has asked how many grams they weigh??? I need to justify what I paid for my water bottle cages in some way.
Honestly, I'm kidding. If they're working for you, good for you!
Likes For Bassmanbob:
Liked 2,802 Times
I don't recall trying my smaller non-insulated bottles. It's possible those would hold more securely in the 50Strong cages on the seat tube.
Likes For canklecat:
