Is charging a Giant energypak for only 30 minutes bad for the battery?
I started using my giant eroad pro for commuting to school and love it, but I'm running out of charge about 3-5 miles from my house on my way back. The problem is, is i only have a just under 1 hour from the time i arrive on campus and have to go to class(where i don't have a place to charge the battery), so I only have about 30 minutes to charge it, after i let it cool down. Is charging for this short of time(it's about 40 percent when i get to school), going to be bad for the battery? The battery is not hot to the touch, but after a 40 minute ride, does it even need to cool down before i plug it into the Giant smart charger?
The 30 minute charge should be plenty to get home, i'm just wondering if it'll be hard on the battery
Thanks
Thanks
Quoted: 166 Post(s)
Liked 252 Times
no problem, plug it in and charge it. if you are on a campus I would try and get away with charging in the class room. assuming there is room you can probably get away with it.
Quoted: 7348 Post(s)
Liked 2,462 Times
Rechargeable lithium batteries have many advantages over previous rechargeable batteries. One is that a partial discharge does not harm them at all, and in fact, they prefer that to full discharges. Partial charges are also harmless.
Likes For noglider:
Bikes: Workcycles FR8, 2016 Jamis Coda Comp, 2008 Surly Long Haul Trucker
Liked 6 Times
I was under the impression that the battery should sit for a little while before being recharged. Please correct if I am wrong.
If you are going to college see if you can find a professor or somebody else that works there. You may be able to use their office to recharge your battery for longer times. I wished more people rode bikes at the school I work at.
